1969 250 i6 soft fuel line size
Hi all, I’m going to replace the soft rubber fuel line that runs between the tank hard-lines and the fuel pump on my 1969 250 i6. There is a stretch of soft line that’s maybe 18inches long - really old and brittle on my truck.
Before I order, I just wanted to confirm what was the oem softline size? Can anyone confirm? Thanks Luke |
#2 | |
The Older Generation
Re: 1969 250 i6 soft fuel line size
I6 is 5/16" ID. Small block and big block are 3/8" ID. Any auto parts store should have it. .
Thank you for the confirmation! I thought it was 5/16”
So you’re saying that even i6 and v8 hardliners have different diameter? Gas tanks are identical however? I’m asking because at some point I may want to do a v8 swap. |
#4 | |
Active Member
![]() Join Date: Jan 2015
All v8’s have 3/8 sending unit to carb |
![]() ![]() Join Date: Jan 2005
I believe V8s with a two-barrel carb also had 5/16 line. That's how my '68 was.
That’s helpful
How much power will a 3/8” line support before it becomes a bottleneck? |
Who Changed This?
![]() Join Date: Jan 2013
Smart money would be to buy the sender with the 3/8" line if you are replacing it, and use an adapter to reduce the line the rest of the way. No point in buying things twice, and an adapter is cheap. FWIW, I put a 4 barrel carb on my '64 Malibu with a 283 and a powerglide trans. Same 5/16" fuel line got me to 120 MPH. How fast and quick do you want to go?
#8 | |
![]() Join Date: Jul 2000
However, GM must have had a good reason to use 3/8" line on 4bbl engines, because they typically reduce costs wherever they can.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
