Old 03-09-2024, 02:15 PM   #26
novaX522
Re: Front sway bar install
Originally Posted by Hupper7 View Post
And one other question. The bolts going on the trailer arm, are they positioned on each side of the ‘C’ shaped bar?
When I picked them up at POL, the salesman told me that would be the position.
Just checking in with someone who has installed them.
Yes they are
novaX522 is offline   Reply With Quote
Old 03-09-2024, 02:21 PM   #27
Hupper7
New Member
Thanks again.
Fairly new to this forum and I’ve learned a lot.
Hupper7 is offline   Reply With Quote
Old 03-09-2024, 02:55 PM   #28
Hupper7
New Member
Another question…
Do I have to lift the front end for the front bars?
Is it just to get clearance?
My truck rides high and I can reach everything without jacking it up, but want to know if it’s critical.
Old 03-09-2024, 05:36 PM   #29
novaX522
I think I only needed it up so I could drill the holes in the front a arms
Old 03-09-2024, 07:05 PM   #30
72SB
you want the truck on its wheels when tightening end links
72SB is offline   Reply With Quote
Old 03-10-2024, 09:34 AM   #31
MS66
MS66's Avatar
Originally Posted by Hatzman View Post
You put a 70's C10 on a 2500 chassis? Any pics?
No sir. What that post is referring to is that I removed all of the front sway bar and frame brackets from a mid '80s 2500 square body truck and installed it onto my '68 C10. World of difference for a whopping $25.
The original rivets on the frame brackets can be a booger to get out if you don't have a grinder to cut the heads off with. Most salvage yards won't let you use anything that can produce sparks. Much easier to grind them off, but they wouldn't let me use the grinder so I had to drill the rivets out doubling the 20 minutes it usually takes to get the bar and brackets off. This last bar I removed had a good set of Energy Suspension bar mounts and bushings installed on it. BONUS
MS66 is offline   Reply With Quote
Old 03-10-2024, 02:30 PM   #32
Hupper7
New Member
Thanks!
I’ll call POL tomorrow to make sure.
I can reach everything as it sits now
Old 03-19-2024, 07:57 PM   #33
Hupper7
New Member
Hello!
Thanks for your pictures and help.
Got them installed a few days ago and almost burned out my drill going through all that steel, but finally had a chance to take it for a quick spin today and I can definitely feel the difference.
Old 03-19-2024, 09:54 PM   #34
novaX522
Hello!
I know what you mean. I enjoy driving through the roundabouts now!
Old 03-19-2024, 10:00 PM   #35
Hupper7
New Member
Ha!
