Old 03-21-2024, 03:10 PM   #1
Nickelcharlie
Tips on installing an ignition switch!
Thank goes out to Bandit 130, geezer#99, and Dead Parrot for responded to my previous post about my truck dying intimately without any warning. I am siding with Dead Parrot. I am thinking it is my old ignition switch that is mounted on top of the column.
Will someone clarify where the slider hole on the ignition switch needs to be before placing it over the actuator rod?
As I understand, place the slider bar in the ignition switch all the way to the right into the accessory position. Hold the key in the accessory position then drop the hole in the slide bar over the rod so both the ignition switch and the key are in accessory mode before tightening the bolts holding the ignition switch? Is this correct? Thanks.
Nickelcharlie is offline   Reply With Quote
Old 03-21-2024, 05:20 PM   #2
Bandit130
Bandit130's Avatar
Re: Tips on installing an ignition switch!
There are several youtube videos that are helpful.
https://www.youtube.com/results?sear...gnition+switch
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
