03-24-2024, 01:09 PM | #1 |
Junior Member
Fitting rocker to pillar to footwell
My front is pretty rotten so I dont have anything to work from, do any of you have an exploded view or maybe pictures of your resto work so I can see how I need to get these together. I've pretty much got it sussed I think but it would be nice to have some reassurance.
Thanks as always |
03-24-2024, 04:21 PM | #2 |
Re: Fitting rocker to pillar to footwell
I recently finished doing exactly what you are in the midst of on my 66. Hopefully yours went together easier than mine and what I mean is there wasn't one single piece that didn't need to be modified. On both sides I did front and rear cab floor supports, front and rear lower pillars, inner and outer rockers, footwells and part of the floor and not one escaped needing modification. Some were slight and some were severe. The bolt holes on that lower pillar on the driver's side needed to be elongated with a die grinder while the passenger side was so bad I cut the bolt flange off, welded on new and drilled new holes. You look look to have it locked down fairly well. 👍 My only suggestion is to tack it together where I indicated to see if the rocker is the right distance from the bottom of the door. The tacks can be removed to reposition because once it's burned in its too late.
03-24-2024, 07:35 PM | #3 |
What he said
Your work looks stellar, but hang the door, to know for sure
03-24-2024, 07:48 PM | #4 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
03-24-2024, 09:57 PM | #5 |
Hey that's a good idea too. But to be honest if I never have to do body work again I can die happy.
03-24-2024, 10:53 PM | #6 |
Here is a member's site with a bunch of videos that may help you.
https://www.youtube.com/@MAYCOCustomRestorations/videos
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-25-2024, 08:04 AM | #7 |
I’m getting restless looking for another truck I can curse at while redoing it
