recommended oil weight
I have recently purchased a 71 C-10 with a 396 with the following options.
396 ci engine, Pro-Form 750 4 bbl, Street Dominator Hi-Rise aluminum intake, roller rockers, Bowtie aluminum heads, Hooker Super Comp big tube headers, HEI distributor. The engine is approaching 500 miles and I think i need to do an oil change since the engine should be broke in by now. I have not been able to locate the original builder to find out more about the cam etc... My question to all would be What oil weight should be used in this engine knowing the information above. Hope to post some pictures later on. |
![]() Join Date: Apr 2008
Re: recommended oil weight
10w30 should be fine but I would use an oil made for engines with flat tappet cams(probably have to look at specialty brands) or regular oil plus an additive.
Does it say on the oil that its made for flat tappet cams or do i need to check the website of the oil manufacturer?
It should say on the oil.
![]() Join Date: Mar 2003
I have the original 396 in my '68 with 125k and I use 20/50 valvoline
Use rotella or delo diesel oil or you will wipe the cam. The oil for gas engines does not have enough zddp anymore. You get 15/40 in diesel oil which is fine I only use rotella only in everything I drive including my silverado 5.3. Also the diesel oil is detergent so your motor will stay clean. I have pulled down motors with high miles after I have used rotella and they are clean inside.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
![]() Join Date: Sep 2009
15/40 rotella in my 402
![]() Join Date: Jul 2013
Wow, this is one of those questions that gets us all fighting.
![]() If it where my engine I would run Royal Purple 10-30 in the winter and 10-40 in the summer. If you are adverse to synthetics then I would use Valvoline all-climate in the same weights. But that is just me, I'm sure you will get 400 differing suggestions and some serious stone throwing. I have had exceptionally good results with both brands and some very bad experience from other brands.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#10 | |
![]() Join Date: Mar 2012
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Mar 2006
Valvoline VR1
#12 | ||
"I ain't nobody, dork."
The diesel oil is no longer the savior of flat tappet cams... It doesn't have high enough ZDDP in it as well. Been that way for almost 10 years. So you need to run an oil made for older rigs with flat tappet cams.
Look into Joe Gibbs Racing oil... Or run off the shelf 10w30 with a ZDDP additive. Gary
#13 | |
#14 | |
#15 |
Rotella and the others have high zddp 1,200 parts per million and recommended level for hot rods with flat tappet cams is 1,100 parts per million. The Valvoline VR1 is 1,400 parts per million and can be used in non cat cars and trucks.
#16 |
I have used the vr1 oil and I do like it but expensive I only use when I need the heavy weight as they make in 50wt and 60 wt
#17 |
I have an opinion about motor oil, changing it frequently is more important than brand or viscosity. A few years back my employer gave me a 96 jeep with 100,000 miles. I went to my friends place for an oil change. He put in a Napa filter and 10w30 Napa oil. I didn't much like that. At 200,000 miles he was still putting in a Napa filter and Napa oil. When I turned it in, it had 250,000 mile with, you guessed it. I changed oil every 3,000 miles and the valve cover was never off of that engine. The last time I ask one of the company mechanics he said the Jeep now had 350,000. I am not promoting Napa oil or filter, but the concept of regular changes.
#18 |
![]() Join Date: Feb 2002
I would go with Valvoline Racing, since it has the ZDDP. Or use STP 4 Cylinder Oil Booster [w/ high ZDDP] with other oils. I like 20W-50 weight for a hotter climate -- I live in Tucson. Or straight SAE 30. [My 292 L6 likes that stuff.]
There are also some other ZDDP additives on the market that I haven't used myself. If you can find new-in-the-box old oil marked series 'SL' or earlier, that's OK. Series 'SM' or later needs more ZDDP for our vintage engines. Frequent oil changes are also a lot less expensive in overhaul costs, over all. I got 250,000 miles out of a 292 by changing oil every 2000 miles.
#19 |
BigPaul:
Napa oil is private label Valvoline All-Climate (Ashland Oil Co.) and the Napa filters are private label WIX. The same goes for CARQUEST. Both are top shelf stuff.
#20 |
#21 |
#22 |
I use Castrol GTX Classic 20w-50, it’s got the proper zinc additive. My second choice would be Joe Gibbs DRIVEN Hot Rod Oil, it too has the zinc. Both oils have high reviews
#23 |
I just switched the oil in the 350 in my '71 GMC Jimmy from 20W-50 to SAE 30 Valvoline VR1. Same oil I use in my '68 C/10 Stepside's 292. Logistics, mainly. One oil to rule them all. But also an old school engine works best with old school oil.
Hey, my last comment in this thread was 11 years ago.
#24 |
![]() ![]() Join Date: Jul 2002
I typicallly use the vavoline vr1. Rotella is good. But still needs zddp additives to give it sufficent amounts for the traditional non roller cam lobes
#25 |
![]() Join Date: Feb 2001
lubriplate super gpo 15w-40
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
