03-26-2024, 12:30 PM | #1 |
1972 Blazer AZ rolling chassis and rear seat
I have a 1972 CST Blazer rolling frame/ chassis from AZ. Surface rust present, no major pitting or rot. Comes with a NP205 auto TC core SANS shifter, TH350 with cracked case, both driveshafts, all 4 springs, rear open 12 bolt 3.07 ratio, front Dana 44 diff, but damaged from front RH corner collision, disc brakes gone, has power steering box core with pump, front engine crossmember and engine mounts for small block. Homemade hitch shoddily welded to rear frame. Should come off easily. This will need to be put on a frame machine and checked especially on RH front corner. Frame VIN stampings crisp. Also includes glovebox door with intact SPID, LH B pillar with unaltered VIN, and a open AZ title. I have owned this since 2004.
$2000 Real Blazer rear seat from a 1972 base Blazer. Black base upholstery in VG condition. Both armrests and brackets present. 2 Rear mounting brackets there, been in dark dry storage since I parted that Blazer out in 1994. $1500 Absolutely NO shipping on either. Must pick up at my residence in ZIP 16920.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-28-2024, 12:34 AM | #2 |
Re: 1972 Blazer AZ rolling chassis and rear seat
If you end up parting that chassis out I'd buy the rear frame horns.
72 Cheyenne C20 BB, air 70 Suburban 20 BB, air, buckets 68 CST C20 air, buddy buckets |
03-28-2024, 08:37 AM | #3 |
Thank you for your inquiry. I will be keeping this chassis whole. If there is no interest, it will be put into storage.
03-28-2024, 02:16 PM | #4 |
03-31-2024, 07:16 AM | #5 |
Price reduction:
$1600 for rolling chassis $1250 for the rear seat
04-02-2024, 11:34 AM | #6 |
If you check Dallas Facebook there is a blazer with a decent body for six thousand but has no vin this is a match
04-07-2024, 07:42 AM | #7 |
bump
04-11-2024, 12:14 PM | #8 |
Ttt
04-17-2024, 07:35 AM | #9 |
bump
04-21-2024, 01:51 PM | #10 |
can you send me pictures of the of the blazer frame? thanks in advance?
04-22-2024, 06:21 PM | #11 |
Pics
05-02-2024, 11:28 AM | #12 |
T t t
05-12-2024, 07:17 AM | #13 |
Ttt
05-21-2024, 11:43 AM | #14 |
Still available. Not going lower on either price.
