04-10-2024, 11:08 AM | #1 |
Proportioning Valve Wire
Can anymore tell me where I can buy one of these short extension wires from. I'm adding power brakes to my drum brake truck and need this proportioning valve extension.
04-10-2024, 04:12 PM | #2 |
Re: Proportioning Valve Wire
the new combo valve should come with the wire
1970 C10 Custom longbed 350/350 |
04-10-2024, 05:57 PM | #3 |
Its likely a different connector on the new PV for power so just splice that new pigtail into your wiring. Or if you just need same connector, just splice in a longer piece of wire. What I did.
04-10-2024, 06:13 PM | #4 |
All about them K’s
lol the way you are holding the wire made me laugh. We take random pictures like that and send them to each other at work
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
04-10-2024, 08:49 PM | #5 |
It seems some others are thinking you are getting a new proportioning valve. It may be because you called the drum brake distribution valve a proportioning valve. If you are not getting a proportioning valve and are simply moving the existing distribution block out from the firewall, you probably have some options. Re-route the wire if it is taking an inefficient route like through wire channel on the firewall and wire clip, and instead run it from the firewall connector in a more direct way to the distribution block, or splice in a piece of wire to lengthen it and route it any way that looks neat, or become a subscribing member of the forum and post a want-to-buy ad in the parts section and ask for somebody to send you that wire. I didn't know there was such an extension wire like that. There are people here on the forum who have their original wire harnesses stashed and offer parts and pieces to people who need them in response to want-to-buy ads, I have experience with that.
04-10-2024, 09:24 PM | #6 |
Sorry, I misread power brake conversion as disc+power.
I just spliced mine.
04-10-2024, 09:49 PM | #7 |
What does the wire do?
1972 C20 402/TH400/3.54 Highlander 1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold) 1983 GMC Sierra Classic 2500 crew cab (sold) 1972 Chevy C10 Cheyenne Super (sold) 1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it) |
04-10-2024, 09:50 PM | #8 |
Lights the warning on the dash when there's a pressure loss in either front or back
04-11-2024, 12:02 PM | #9 |
04-11-2024, 12:07 PM | #10 | |
