04-06-2024, 09:35 PM | #4726 |
Who Changed This?
Re: What did you do to your truck today.The 3rd chapter
'72 Fremont truck, early in the production year. That's looking really nice!
Oh yeah, I went to a local car show. Lots of vehicles, from over 90 years to the present. I remember when a Model T ford was only a few decades old.
04-07-2024, 11:45 PM | #4727 |
Got my AM tuner unfrozen, got my BT unit and speaker switch mounted.
Next we find out if the AM unit works with the speakers....if it still works at all ;-)
1970 C10 Custom longbed 350/350 |
04-08-2024, 02:28 PM | #4728 |
At the body shop.
Polished the Mickeys ordered lugs and caps
" That didnt make it any newer " " Dont antique the equipment " |
04-09-2024, 12:14 PM | #4729 |
04-09-2024, 02:15 PM | #4730 |
Thank you, it came out all right for a fully homebuilt truck.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
04-11-2024, 08:37 PM | #4731 |
Did a lot of running around but managed to get the front sway bar painted and the new bushings installed
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
04-12-2024, 08:40 AM | #4732 |
Finished up the power steering install by securing the lines and re-installing the inner fender. Wife and I took it on about an hour drive. Now on to finishing up the rear bumper.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
04-13-2024, 02:31 PM | #4733 |
At the body shop.
Duplicate
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 04-13-2024 at 02:36 PM. |
04-13-2024, 02:34 PM | #4734 |
At the body shop.
Speedo diagnosis.
Yep that's the problem area.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 04-13-2024 at 03:31 PM. Reason: Pic |
04-14-2024, 01:53 PM | #4735 |
Electrolysis rust removal on the manifolds . Found a crack in one so I’ll be doing some welding next week .
04-14-2024, 03:12 PM | #4736 | |
I had a crack in the drivers side manifold of the 454 BBC in my '67 K/10 Sub. I tried JB Weld. Unlike the claims on the package side, it burned off after a while. There were Ram Horn exhausts on the small block in my '71 GMC Jimmy when I bought it. After It sucked a couple of valves [#6 + #7], I bought a Mr Goodwrench crate motor 350. I noticed the exhausts were different. The RH one had tapped bores for A.I.R. but the LH was pre-Emissions. I didn't like the possibility of different backpressures, so I got Headman headers.
04-15-2024, 11:44 AM | #4737 |
04-15-2024, 12:22 PM | #4738 |
Junior Member
Pulled the TKX 5 spd, clutch and bellhousing off my engine to prep for the 6 speed I am adding . . .
Doug P Yorktown, Virginia 1962 C10 LBFS - in pieces currently 1967 C10 SBFS and a couple non-trucks |
04-15-2024, 02:27 PM | #4739 |
Finished up the fabrication part of my rear bumper build and got it in primer. A light sanding and paint is on the agenda next with plans for an install this weekend.
04-15-2024, 06:03 PM | #4740 |
I tried and my welding guy tried to weld up the crack . No go the cast is so porous it just opens up . So it looks like a new set is in order . I even painted the passenger side .
04-15-2024, 06:04 PM | #4741 |
Yes it does it was only in the bath for about two hours
04-17-2024, 07:47 AM | #4742 |
i pulled my truck and trailer out from winter hibernation,unloaded the truck and started getting the old girl cleaned up for this weekend and the 50th Annual Radical Speed Sport Show in Moncton,New Brunswick,about an hour from here.Chip Foose is coming and lots of very nice machinery.my truck did well at this show last year,maybe we can do it again?
04-17-2024, 08:42 AM | #4743 |
Very nice truck ^^^ hope you get nice weather, it's been nasty here in North Bay Ont
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
04-17-2024, 09:28 AM | #4744 |
You got my vote!! Love your truck!
04-17-2024, 05:32 PM | #4745 |
i hear ya.we've had some nice weather but calling for a 30% chance of showers in the morning,hopefully if it rains,it's early and i'll make tracks for Moncton.it'll all work out.thanks.
04-19-2024, 01:02 AM | #4746 |
I was checking fuses on my new-to-me 2003 Tahoe. [Weird electric window issues.] When I dropped something, so I crawled under the motor.
I didn't find the tiny piece I had lost but I did find a 1'' piece of blue sparkplug wire. I had moved the '71 Jimmy out rom under the carport so I could check on the Tahoe in the shade. The Jimmy had run rough, but I thought it was just a cold engine. I looked under the hood and found a packrat had chewed thru the #5 cylinder plug wire. No. 5 is hard to get to on a 4-Speed truck with Power Steering. I found a used plug wire I can try, but I'm not sure I got the terminal to click on the sparkplug tip. I'll get back after it tomorrow. The sun went down on me today.
04-19-2024, 07:35 AM | #4747 |
I took out a mortgage and ordered a set of tires.
04-19-2024, 08:50 AM | #4748 |
Well the whole not doing the “While it’s apart deal “ went out the window .
04-19-2024, 09:25 AM | #4749 |
Scope creep! It gets us all at some point.
04-19-2024, 09:43 AM | #4750 |
No I’m eying the Lugnut rear disc conversion .
