Old 04-13-2024, 04:48 PM   #1
michael bustamante
michael bustamante's Avatar
Sway bar mounting brackets
Great shape. Bolt on, not riveted
25.00 plus ship
1967custom
michael bustamante is offline   Reply With Quote
Old 04-15-2024, 06:58 PM   #2
kev2809
low n' slo
kev2809's Avatar
Re: Sway bar mounting brackets
hey michael, do you know what size bar this bracket uses?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-28-2024, 11:43 PM   #3
michael bustamante
They were mounted to the 1.25" bar
1967custom
Old 05-29-2024, 11:05 AM   #4
kev2809
low n' slo
kev2809's Avatar
thats the thicker bar right? trying to see if i can find a way to mount them to my LCA's, have drop cups welded in and they plated the underside!
-_--_--_ _________
Old 05-29-2024, 03:50 PM   #5
michael bustamante
What I did was run the sway bar inside the frame bracket instead of hanging underneath the frame bracket. Works great amd tucked the bar in closer to the chassis. If your frame is boxed in where this mounts, ypu might have to weld them on
1967custom
Old 05-29-2024, 06:41 PM   #6
kev2809
low n' slo
kev2809's Avatar
well these mounts are no problem, its where the sway bar mounts to the LCAs. they bolt through the top of the LCA...hmmm
ill take them and figure out the rest later, im sure someone has ran a swaybar with plated bottoms. whats the shipping to 77471?
-_--_--_ _________
Old 05-29-2024, 06:42 PM   #7
kev2809
low n' slo
kev2809's Avatar
also, do you have any pictures of the setup you mentioned?
-_--_--_ _________
Old 05-29-2024, 10:12 PM   #8
michael bustamante
Shipping would be 13.25. Fed ex. Pics are with an oem sway bar you are probably thinking of an aftermarket bar from helwig. I have a set of front and rears for sale too
1967custom
Old 05-29-2024, 10:15 PM   #9
michael bustamante
Helwig front and rear sway bar for coil spring rear. These have flattened ends to take sway bar links. 1.5 in the front and 3" in the rears I'm pretty sure. I dont have links but they're available in most lengths at Napa I'm sure
200 for the pair plus ship
1967custom
Old 05-30-2024, 07:42 PM   #10
70STOVEBOLT
70STOVEBOLT's Avatar
Would you sell the rear bar separately? If so how much shipped to 46590?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-31-2024, 12:15 PM   #11
kev2809
low n' slo
kev2809's Avatar
i may be interested in that front bar as well if i can figure out how to mount these to my plated control arms!
-_--_--_ _________
