Old 04-14-2024, 02:47 PM   #1
Ziegelsteinfaust
Rear gear options
My rcsb 73 C10 has 4.88 gears, and a Detroit locker.
Since I am giving the truck to my dad. I need to swap gear ratios.
Would 3.23's be too low with a C10 backed by a TH700R4 with 30" tall street tires?
Ziegelsteinfaust is offline   Reply With Quote
Old 04-14-2024, 03:44 PM   #2
RustyPile
RustyPile's Avatar
Re: Rear gear options
Naaaa!! Don't change a thing.. Give it to your Dad like it is so he can take it racing sometimes.
RustyPile is offline   Reply With Quote
Old 04-14-2024, 04:29 PM   #3
Dead Parrot
online RPM calculators are your friend.
At 70mph, engine RPMs are:
3.23 = 1772
3.73 = 2047
4.10 = 2250
4.88 = 2678
Unless that motor is some kind of special low end powerhouse, 3.73 or 4.10 is probably a better choice.
Or just leave it as is.
Dead Parrot is offline   Reply With Quote
Old 04-14-2024, 04:48 PM   #4
LS short box
I'd go 3.73's.
Old 04-14-2024, 04:55 PM   #5
truckster
truckster's Avatar
If your dad is a conservative driver 3.23 would be just fine. If he wants a little more pull, I'd agree on the 3.73.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-14-2024, 06:38 PM   #6
kwmech
3.23s may have a tendency to make the trans hunt between 3 and 4 especially with the lock-up convertor. With a 30'' tire I would personally go with the 4.10s. Cruising at 21-2200 rpm is actually ideal. No mention of the engine build
Old 04-14-2024, 09:48 PM   #7
Ziegelsteinfaust
The engine will be a bolt on gen2 LT1 from a B body.
Or about 300hp/375tq crank
Old 04-18-2024, 07:31 AM   #8
dennislbrooks
dennislbrooks's Avatar
I run 3.73s in my BB 402 and 700R4 with 265/70R17 tires - 67 Chevy 4WD - 14 bolt. I would not change it but it does hunt between 3 and 4 at about 37-38 mph with light throttle like in a 35 mph zone- same with my other 2. Even with a small block I like the 3.73s behind a 700R4 - my 59 GMC 4WD (215/85R16)- 12 bolt, and my 42 Chevy 29 inch tires 10 bolt.
For 60 mph cruisin I like the 3.73s. But since you are making a switch 4.10s as kwmech says above may help the hunting problem.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 04-18-2024, 06:06 PM   #9
LS short box
On my LS swaps with 4L60E's I delay the 4th gear and lock up until 45 mph. I know its done thru the ECM.
Can the the 700 be "programmed" mechanically to do the same? Just asking.
Old 04-18-2024, 07:35 PM   #10
dennislbrooks
The tension on the TV cable will adjust shifts. There may be other ways. My 700R4 under moderate throttle shifts into 4th about 47 mph and lockup nearly immediately afterwards.
I am talking when you have slowed down for a 35 mph then just remain with a light pedal to maintain something close to 35. If I creep up to 38-39 mph under the light throttle it shifts up to 4. A little less like 36,7 back to 3. Yes I could move the shifter out of OD to D.
