Old 04-18-2024, 11:18 AM   #1
57Suburb
57Suburb's Avatar
oddball waterpump outlet location
I installed an LSSimple accessory drive on my 6.0 swap, and in order to run their AC mount, it was suggested to install a 2012ish Camaro water pump which positions the outlet as shown in the photo. Anyone on here have this setup with a radiator inlet in the stock location (drivers side) and what hose set up did you go with. Thanks,
1972 C30 Grain Hauler, 350/400
1967 1500 GMC Stepside SWB, In Transformation Process
1967 RS/SS Camaro 350/TKO600
57Suburb is offline   Reply With Quote
Old 04-19-2024, 04:37 PM   #2
LS short box
Re: oddball waterpump outlet location
Not a truck swap but on my 73 LS3 swap I used "stock" style aluminum radiator. I struggled to find upper hose that fit. I ended up using two hoses and a splice. The splice also had a NPT opening for the head vent line.
I got splice from "Jaguars that run".
Lower hose I got from Oreillys by looking thru the selection in the back room.
Pic of the 73 upper hose.
Old 04-19-2024, 05:00 PM   #3
mongocanfly
mongocanfly's Avatar
Same here..I've had to do the hose splice on mine..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-20-2024, 09:24 AM   #4
57Suburb
57Suburb's Avatar
Yeah, I'm thinking I will need to do a split anyway because of the size difference between the inlet and outlet. Just wondered if there was an off the shelf hose the worked for a more "factory" look.
thanks for the reply
Old 04-22-2024, 01:16 PM   #5
mongocanfly
You can use the gates powergrip clamps (like heatshrink) instead of hose clamps to give it a cleaner look... ive got mine mocked up with hose clamps..but am using these once I get it all squared away..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-22-2024, 01:29 PM   #6
57Suburb
57Suburb's Avatar
I came across this image, which shows what looks to be exactly what I'm wanting to do. Just got to find that hose.
Old 04-22-2024, 04:19 PM   #7
LS short box
Looking at the ECM maybe a Gen1 LS? Maybe a 6.0 in a 3/4 ton pick up. Or maybe a Denali? Or 6.0 in Escalade?
Old 04-24-2024, 09:04 PM   #8
jessemthompson
I believe that’s a Gates 24342 Premium Molded Coolant Hose. That’s what the square body guys use with the ls3 water pump. Idk if that’ll be a direct bolt on with th 67-72 though
jessemthompson is offline   Reply With Quote
Old 04-24-2024, 10:05 PM   #9
57Suburb
57Suburb's Avatar
This is one I’ve come across. Won’t know if it will work until chassis is back together.
Old 05-04-2024, 07:32 PM   #10
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
gates has a hose catalog, pretty awesome. It has it organized by size, and then length.... photos of the hose will get you in ball park and then google the part number.
Almost looks like a hose that was almost perfect if not perfect, but maybe slightly to long, and they just clocked the hose to make an arc to avoid a splice.. pretty slick!
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
