#26026 |
![]() Join Date: Aug 2013
Re: Facebook Marketplace finds
1971 Chevrolet 1500 regular cab Long Bed
$5,200 Listed 6 weeks ago in Alpine, AL About this vehicle Driven 1,000,000 miles Automatic transmission Exterior color: Blue · Interior color: Fuel type: Gasoline Seller's description 1971 Chevy Cheyenne, new exhaust, gas tank, locks and ignition are keyed the same. New door parts not installed. Has exterior rust, floor are fine. Motor runs great Alpine, AL Location is approximate Seller information Mike George https://www.facebook.com/marketplace...type=top_picks |
#26027 |
https://www.facebook.com/marketplace...type=top_picks 72 Lwb c10
$6,000 Listed 5 days ago in Arlington, TX |
#26028 |
71-72 C10 Grille Shell
$225 Listed 3 days ago in Concord, NC Details Condition Used - like new 1971-72 C10 Brand new was used for mock up it does have some dents. I did my best to show them in the pictures. https://www.facebook.com/marketplace...30525996%22%7D |
#26029 |
https://www.facebook.com/marketplace...30525996%22%7D 1970 Chevrolet C-10
$10,000 Listed 3 days ago in Guilford, CT Details Condition Used - Good 1970 C-10 350 4-speed new process A-833 Brand new posi 3.73 Cpp Tubular motor mounts Cpp 2 drop spindles Cpp 4 lowering springs Cpp Brake booster New brakes New radiator New clutch New drive shaft I have new fenders, wheel wells, radiator support Truck runs drives stops 10k great project just needs to be finished I have ton of other parts as well Original title Currently registeredd |
#26030 |
https://www.facebook.com/marketplace...0-2771213bfb57 1970 c10
$3,000$3,200 Listed a day ago in Oneida, TN Details Condition Used - Good 350 3 speed truck was running And driving when parked 3 years ago pretty solid truck not rusted out I have the title and keys 3,000 obo may trade for a Harley |
#26031 |
https://www.facebook.com/marketplace...7-0ed722ed52a3 1968 Chevrolet c-10
$6,000 Listed a day ago in Greencastle, IN About this vehicle Driven 22,000 miles Manual transmission Exterior color: Blue · Interior color: Clean title This vehicle has no significant damage or problems. Seller's description 1968 C-10. Starts, drives, and stops. 250 inline 6 motor. Starts right up and idles great. The good: Whole new brake system consisting of all 4 wheels having new drums and springs kits, all new brake lines and new master cylinder. New radiator. New water pump and thermostat. New valve cover gasket, oil pan gasket, and rear main seal. The bad: Does leak oil. Do not know where its coming from especially after replacing all those gaskets and main seal. Can explain more if interested. Trailing arms have holes rusted in them. Passenger side floorboard has rusted hole as well. Turn signal lever is broken somewhere in the column but still works sometimes. The truck is still solid for 56 years old. $6000 obo. Thanks! |
#26032 |
1970 Chevrolet c10
$9,000 Listed 12 hours ago in Front Royal, VA About this vehicle Driven 86,000 miles Automatic transmission Exterior color: Blue · Interior color: Blue Seller's description 1970 C10 383 stroker tricked trans nice Lil hot rod could use some tires runs and drives come check it out Front Royal, VA https://www.facebook.com/marketplace...0-2771213bfb57 |
#26033 |
https://www.facebook.com/marketplace...2-7806b91c0b1f 1969 Chevrolet 1500 regular cab Custom
$7,950 Listed 9 hours ago in Collinsville, TX |
#26034 |
1970 Chevrolet chevy van g10
$2,500 Listed 15 hours ago in Burnsville, NC About this vehicle Driven 100,000 miles Automatic transmission Exterior color: Brown · Interior color: Brown Fuel type: Gasoline This vehicle is paid off Seller's description C10 v8 automatic. No title Burnsville, NC Location is approximate https://www.facebook.com/marketplace...d-b660be171525 |
#26035 |
1969 Chevrolet c/20
$3,000 Listed 4 days ago in San Angelo, TX About this vehicle Driven 1,000 miles Automatic transmission Exterior color: White · Interior color: Blue Fuel type: Gasoline Clean title This vehicle has no significant damage or problems. Seller's description 1969 3/4 ton long bed fresh barn find,runs and drives needs a battery,350 motor,400 transmission come's with wood bed as show in picture's plus the original bed. $3,000.00 https://www.facebook.com/marketplace...2-7806b91c0b1f |
#26036 |
1968 Chevrolet 1500 regular cab Long Bed
$6,000 Listed 21 hours ago in Jacksonville, NC About this vehicle Driven 123,456 miles Automatic transmission Exterior color: Blue · Interior color: Black Fuel type: Gasoline 2 owners This vehicle is paid off Clean title This vehicle has no significant damage or problems. Seller's description This 1968 Chevy C10 Long Bed is an Antique. It has the original engine 250 straight 6. 3 speeds in the tree. Has New Gas Tank, Radiator, New Tires with rims power steering and a title. In the back of the truck has 350 small block engine included with the truck. Truck has only surface rust body is solid, add will we taken down when sold no need to ask. https://www.facebook.com/marketplace...d-b660be171525 |
#26037 |
https://www.facebook.com/marketplace...2-7806b91c0b1f 1969 Chevrolet 2500 regular cab
$14,000 Listed 23 hours ago in Glasgow, MO |
#26038 |
1969 Chevrolet c10
$44,000 Listed a day ago in Beaumont, TX Seller's description 1969 Chevy C10 69 c10 original short bed not cut down. Clean Texas title in my name,Truck came from Kentucky. New 71-72 bumper and grille shell with billet insert. Rebuilt 6.0 with rattler cam, rebuild 4l80 with shift kit and new fti 3600 lock up converter. New steering column, new gear box and all tie rods replaced along with control arm bushings and ball joints. New old air products ac/heat with new vents installed, low mount compressor. New seat foam and cover. New bed wood and strips, wood stained and marine spar finish on them. Intellitronix dash installed. Stainless exhaust with v band clamps, through crossmember and over axle with spin tech mufflers. Ptfe fuel lines and walbro pump. https://www.facebook.com/marketplace...2-7806b91c0b1f |
#26039 |
https://www.facebook.com/marketplace...d-b660be171525 1972 Chevrolet 1500 regular cab Long Bed
$3,400 Listed 2 hours ago in Easley, SC About this vehicle Driven 12,346 miles Automatic transmission Exterior color: Orange · Interior color: Tan Fuel type: Gasoline Seller's description 1972 Chevrolet C10 350 automatic longbed. It has some rust in the rockers but the bed is solid. The frame is really good. It has power steering but no power brakes. The hood latch is missing. The glass is good. The truck cranks and is yard drivable. It does not have any rust on the bottom of the doors. The rust is in the rocker panels and cab corners. It is titled as a1972 but I believe the frame is a 69 and the cab is a 72. $3400 in Easley SC. I will not take any less so please no offers. I will delete them. |
#26040 |
https://www.facebook.com/marketplace...d-b660be171525 1968 CHEVY C10 - 50TH ANNIVERSARY GOLD
$5,500$6,000 Listed 20 hours ago in Rising Sun, MD Details Condition Used - Good No trades. I will not answer offers sent over messenger. Please only contact if you are genuinely serious with cash and a time in mind. Price is only negotiable in person, Im located in Rising Sun MD. Im listing this 50th Anniversary 1968 Chevrolet C10 for sale. Its a single cab, long bed, 2WD truck powered by a recently rebuilt 355 and 3-speed automatic. Clean title in hand. The truck starts, runs, drives, shifts, and stops fine as it sits. The engine was built under 1000 miles ago (by previous owner-no paperwork) and has been bored .030 over with a mild camshaft. It has a new battery, new tool box, and Rally wheels. Everything else is stock. This is a factory 50th Anniversary Gold special edition trim, and it seems to be wearing all of the factory paint. The body is surprisingly straight with some cool patina. The frame has plenty of surface rust but is overall solid. The cab supports, cab floor, doors, and bed floor are rough as far as rust goes, but the truck looks decent nevertheless. The interior is all original and in decent shape. The white upholstery has held up surprisingly well and the lights/radio/horn work. You can drive this home as-is, but it definitely needs some love. The factory manual drum brakes are sketchy and the Quadrajet carburetor isnt the best. I have cruised it around town a few times but its still a project. Message me and come today. Thanks! Rising Sun, MD https://www.facebook.com/marketplace...d-b660be171525 |
#26041 |
https://www.facebook.com/marketplace...2-7806b91c0b1f 1969 GMC sierra (classic) 1500 regular cab SL Pickup 2D 6 1/2 ft
$26,500 Listed a day ago in Rodessa, LA |
#26042 |
https://www.facebook.com/marketplace...type=top_picks 1971 Chevrolet other
$18,999 Listed 2 days ago in London, OH About this vehicle Driven 125,000 miles Automatic transmission Exterior color: Red · Interior color: Seller's description 4 wheel disc breaks New ball joints New tyrods New idle arm New shocks New coil springs New master cylinder New break lines 4 row radiator Vintage air system New TH400 New elder block carburetor New tires New power steering pump New fuel pump Electric windows London, OH Location is approximate Seller information |
#26043 |
https://www.facebook.com/marketplace...type=top_picks 1971 Chevrolet k20
$5,250 Listed 17 hours ago in Tignall, GA |
#26044 |
https://www.facebook.com/marketplace...type=top_picks 1972 Chevrolet 1 ton truck
$4,500 Listed a day ago in Clinton, NC |
#26045 |
1968 Chevrolet classic
$15,000 Listed 4 weeks ago in Ridgeway, VA About this vehicle Driven 333 miles Automatic transmission Exterior color: Orange · Interior color: Seller's description 1968 Chevrolet Classic · Truck · Driven 333 miles 68 C-10 Truck 4- wheel disc brakes, new seat- still in plastic, 327 motor w/ 350 transmission, 20 staggered wheels, Good cruiser. Ridgeway, VA Location is approximate https://www.facebook.com/marketplace...type=top_picks |
#26046 |
https://www.facebook.com/marketplace...type=top_picks 1968 Chevrolet 1500 regular cab
$28,000 Listed 21 hours ago in Fairfield, CT About this vehicle Driven 12,345 miles Manual transmission Exterior color: Blue · Interior color: Black 2 owners This vehicle is paid off Seller's description Good running truck Fairfield, CT Location is approximate Seller information Ed Firgeleski Jr Joined Facebook in 2009 Sponsored |
#26047 |
1967 Chevrolet c10
$5,000 Listed 4 hours ago in Alliance, OH About this vehicle Driven 85,765 miles Automatic transmission Exterior color: Orange · Interior color: This vehicle is paid off Seller's description I have two trucks for sale. One is a 1969 GMC. C 10 2 Wheeldrive for sale for 2500 or best offer comes with two cabs then I have the jacked up 4 x 4 orange ones in 1967 BAD TRANNY 5000 or trade has bad gas in it but still runs Alliance, OH Location is approximate Seller information https://www.facebook.com/marketplace...1-a93fb56e92dc |
#26048 |
https://www.facebook.com/marketplace...1-a93fb56e92dc 1967 Chevrolet 1500 regular cab Long Bed
$4,000 Listed 6 days ago in Midlothian, VA About this vehicle Driven 100,000 miles Automatic transmission Exterior color: Gold · Interior color: Fuel type: Gasoline Seller's description 1967 Chevy K10. Does not run. Good project or parts truck. Cab in bed not included. Midlothian, VA Location is approximate Seller information Nathan Hughes Joined Facebook in 2024 Sponsored Send seller a message |
#26049 |
https://www.facebook.com/marketplace...1-a93fb56e92dc 1967-1972 Chevy truck parts
$1,111 · In stock Listed in Mocksville, NC Details Condition Used - Fair Parting out a couple 1967-1972 Chevy trucks Message for prices and info Mocksville, NC Location is approximate Seller information Jeremy Allen (27) Joined Facebook in 2009 Sponsored |
#26050 |
https://www.facebook.com/marketplace...type=top_picks 1968 GMC 1500 regular cab
$1,800 Listed 15 hours ago in Essex, MD About this vehicle Driven 80,000 miles Automatic transmission Exterior color: Grey · Interior color: Seller's description The truck drives well. 350 with a rochester quadra jet carb. -Automatic -Gauges do not work -The cab and bed is in rough shape -Comes with both rocker rocker panels, cab corners, dash pad, new diff cover, and an extra passenger door. |
