Old 04-08-2024, 10:22 AM   #26
jweb
jweb's Avatar
Re: The Old Bench Seat
Brian (MARTINSR), if your seat ends up really thin, the springs may be a good idea. The stock seats are too thick for an unchopped truck, at 5'10" I'm looking out the top of the windshield in mine.
Unfortunately you will have multiple issues when dealing with a chopped truck.
A really low seat puts your knees up in the air and possibly your steering wheel in an awkward location.
On a truck like yours I would wait until it's drivable to do some testing of the seat on actual drives before upholstering it.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 04-08-2024, 10:59 AM   #27
MARTINSR
MARTINSR's Avatar
Yeah, that's what I was thinking, the seat and the steering column mounting need to come later when I am closer to driving it.
I have decided I will be splitting the column and changing the angle at the dash dropping it down some. The seat has my had spinning every time I think about it. I need to put it aside and get other things done. I may be removing the stock mounting from the floor. Right now, sitting in there with just a very thin foam on a piece of plywood I am looking at the top of the windshield and I'm only 5'8''.
We will see.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 04-08-2024, 12:16 PM   #28
Chopped53
Yes, fitting a seat into a chopped truck is tough. I removed the original mounting frame and also removed the gas tank. Then mounted a seat with a very thin back right on the floor (no sliding mechanism). Had to mount the steering column lower than normal too (it's a tilt/telo from a 68 Olds). Finally, I tilted the seat bottom up at the front, similar to the way they do it in the old 30's hot rods, to get some leg support. It might look a little funny, but it's super comfortable even on long road trips. Headroom and visibility is great and I'm 6'1".
Chopped53 is offline   Reply With Quote
Old 04-08-2024, 12:53 PM   #29
MARTINSR
MARTINSR's Avatar
Right on, thanks for the info. Your chop is way more than mine, but with my section, we are probably pretty close.
Brian
1948 Chevy pickup
Old 04-08-2024, 01:04 PM   #30
MARTINSR
MARTINSR's Avatar
I just measured mine, 38 inches from the floor to the bottom of the roof rail over the door.
Just for fun, measure yours, I wonder how close we are.
My poor photos makes it look like I am at an angle. It was straight up to the middle of the roof that is even front and rear, not raked down at the front like this photo looks like.
Brian
1948 Chevy pickup
Old 04-08-2024, 05:12 PM   #31
Chopped53
Wow! That is a ton of work. Looks very well done. I will measure tonight when I get home. I bet it's close to the same.
Old 04-09-2024, 11:09 AM   #32
JDarby
Junior Member
These chopped AD truck look so cool,
I take my hat off to you guys!
I would think with the gas tank removed that it
would give you a little more room to work
into a comfortable seat configuration.
Hell if a airplane pilot just uses velcro and foam
for a seat I would think you have better odds
of making it comfortable than them.
JDarby is offline   Reply With Quote
Old 04-10-2024, 08:49 AM   #33
MARTINSR
MARTINSR's Avatar
Yeah, the gas tank was removed, using a stock 48 under the bed.
Brian
1948 Chevy pickup
Old 04-10-2024, 10:55 AM   #34
Chopped53
@martinSr - Went out to shop today to visit my hibernating truck. I measured the door opening and it came in at 38.75 inches. So, very close to yours although you achieved it through a combination of chop and section.
I'm curious what that door opening measurement is on a stock truck. Can anybody share that? See MartinSr's earlier post for picture reference.
Old 04-14-2024, 05:11 PM   #35
MARTINSR
MARTINSR's Avatar
Pretty cool, yep you have an awesome chop.
Brian
1948 Chevy pickup
Old 04-15-2024, 12:18 AM   #36
jweb
jweb's Avatar
Just measured and stock door opening is 44”.
Old 04-15-2024, 03:37 PM   #37
Chopped53
Thanks jweb and Brian. Apologies to the OP and moderator for taking the thread slightly off topic. I'll be good now....
Old 04-16-2024, 09:18 AM   #38
Rickysnickers
No worries...
Old 04-26-2024, 07:49 PM   #39
vintovka
vintovka's Avatar
Went the cheap way on mine and its great. I took the springs/parts from 2 original seats made a good one as best i could. Laid commercial carpet over the springs and added 3" foam over the seat and 2" over the back. . With many cuss words and zipties got a cheapy premade seat cover on it. It came out nice and comfy. I even caught the shop guys sleeping on it during lunchbreaks.
vintovka is offline   Reply With Quote
Old 04-27-2024, 02:10 PM   #40
_Ogre
_Ogre's Avatar
removing the gas tank in cab doesn't give any extra room for the seat or legroom. the stock seats go back to the window either way. my sub enclosure is bigger than the gas tank and my seat goes back to the window frame.
being 6'4" legroom was a concern, i actually raised the drivers seat a couple inches above stock height. electric controls allow me to tilt the bottom to support my thighs.
shop air compressor timer
Old 04-27-2024, 02:32 PM   #41
dsraven
I always try to remove the fuel and venting from the cab. Less off gassing next to you of known carcinogens. To each their own.
Old 04-30-2024, 10:17 PM   #42
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by JDarby View Post
Dan, that seat looks great!!!
That is a very doable option!
Did you do your own upholstery?
I think between you and dsraven I can pull this off!
Thanks guys!!
Sorry for the very late reply but no. I do not do upholstery. A local shop that does SEMA quality stuff did it. High priced but not terrible. $600 in 2015 I think it was.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 04-30-2024, 10:53 PM   #43
Dan in Pasadena
Originally Posted by 72Mountaineer View Post
Hey Dan got a pic of the back/under?
Hmmm, sorry but I don't. All that work was done at the upholsterer and that was when I was still a working person so I only saw it once it was done.
Old 05-02-2024, 12:30 PM   #44
JDarby
Junior Member
What I meant Dan was if I can get a comfortable seat be it foam, spring what have you.
I will cover it in Indian blanket if it means cutting cost down without
sacrificing comfort!
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
