Old 05-23-2024, 11:11 AM   #1
profe56
Bed question
GOOD MORNING FOLKS
Has anyone used plywood and, or different metal strips to renew the bed of the truck(69) stepside longbed
I found 10 foot heavy duty plywood that I think might work unless I'm told otherwise.
Thank you for your answers.
profe56 is offline   Reply With Quote
Old 05-23-2024, 12:20 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Bed question
Does it have an 'x' in the identification, like 'ACX' plywood? If not, I wouldn't use it, as the glue would not be water resistant.
~Steven
Simi Valley, CA
Old 05-23-2024, 10:46 PM   #3
dmjlambert
dmjlambert's Avatar
Re: Bed question
I'm thinking of this as well. Is there any reason not to consider cutting the planks to twice as wide and just reducing the number of metal strips? Would it look too strange?
Old 05-24-2024, 01:16 AM   #4
profe56
Re: Bed question
I'm also thinking about,use flat metal strips
Old 05-24-2024, 01:18 AM   #5
profe56
Re: Bed question
I was told is water resistant
Old 05-24-2024, 01:25 AM   #6
58 Special
Re: Bed question
Water resistant is not waterproof.
58 Special is offline   Reply With Quote
Old 05-24-2024, 07:27 AM   #7
Re: Bed question
My 64 used marine grade plywood. no strips,as just needed a floor so things would stay in there. 10 years later it still fine according to the current owner.
Old 05-24-2024, 08:51 AM   #8
profe56
Re: Bed question
It’s waterproof.
Old 05-24-2024, 10:24 AM   #9
profe56
Re: Bed question
Thank you Setevedee.
Yes it has an X.
But, I also found "MANGLARIS WOOD" the only problem is 96 in long and must be 97. and the diference $$$$ its minimum.
I don't know if can can I ad a half an inch at bott extremes will work.
