Old 05-19-2024, 11:26 PM   #4826
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by Jiggers72-GMC View Post
Nice score, I hope the boy is ok
Yes he was, thank you.
And was a fine Sunday together got a little pickin in too.
Old 05-20-2024, 06:56 PM   #4827
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Last year made a faux pas backing out of my yard and bent the upper side molding. Found a guy that straightened it back to almost normal. Broke one clip and had a hell of time sourcing the right one but found it at Mar K, black clip in molding. The " What did I do to my Truck Today " part is I finally got the molding back on the truck today.. .
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-20-2024, 11:43 PM   #4828
KQQL IT
At the body shop.
KQQL IT's Avatar
Looks good. Green trucks have really been growing on me lately
Old 05-21-2024, 08:14 PM   #4829
72c20customcamper
72c20customcamper's Avatar
Buttoned up the exhaust today . These butt clamps work real well really didn’t want to weld the pipes
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-21-2024, 09:52 PM   #4830
'68OrangeSunshine
'68OrangeSunshine's Avatar
Wished I'd had those on my headers when they burned/rusted thru and I had to R+R Headers. While I was careful to order the exact same p/n to get the same configuration, Headman had gotten smarter than me and had a whole new attachment scheme. They said it was better and improved, but I'm the guy who had to blast seven miles down a main drag to Midas to get the new ones welded on. A cop got on my tail the last couple blocks, but when I pulled a left into the muffler shop, he lost interest.
Especially annoying were the many cuts and scrapes on my wrists from having to pull them apart with a sawzall.
Yours look good.
Old 05-23-2024, 04:30 PM   #4831
Extended Power
Extended Power's Avatar
I really like these LED headlights.
Hooked the middle bar to be DRL.
Pictures don't show up correctly.
Top section looks like black chrome, then the white bar, then the bottom section.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 05-23-2024, 07:39 PM   #4832
Steeveedee
Who Changed This?
Steeveedee's Avatar
Nice and white! Is that without a relay kit?
~Steven
Simi Valley, CA
Old 05-23-2024, 10:28 PM   #4833
67ChevyPickupMan
67ChevyPickupMan's Avatar
Checked to make sure the top radiator hose I ordered was correct(it was), so with that being good I cleaned up and repainted the thermostat housing and cleaned the surface on the intake manifold. Hope/Plan to have that altogether tomorrow.
67ChevyPickupMan is offline   Reply With Quote
Old 05-23-2024, 11:05 PM   #4834
69Penka
Getting my truck painted. The bed was painted last week and the cowl and God this week. The bed got lined this week as well. I also got the seat reupholstered. She's almost done.
69Penka is offline   Reply With Quote
Old 05-23-2024, 11:08 PM   #4835
69Penka
More pics
Old 05-23-2024, 11:10 PM   #4836
69Penka
A few more.
Old 05-23-2024, 11:18 PM   #4837
'68OrangeSunshine
I like the seat. Nice job.
Will you paint the Cab top White?
Old 05-23-2024, 11:40 PM   #4838
Extended Power
Yes sir, no relay required...plug and play for the most part.
I just ran an accessory switched wire to all four for the DRL’s. (Key on, DRL’s on.)
Old 05-24-2024, 12:17 AM   #4839
68bowtie
68bowtie's Avatar
Looks great
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
68bowtie is online now   Reply With Quote
Old 05-24-2024, 02:31 AM   #4840
'68OrangeSunshine
I guess LEDs require a lot less amperage than filament-based lamps.
Old 05-24-2024, 10:15 AM   #4841
Steeveedee
Who Changed This?
Steeveedee's Avatar
Thanks! I'm using a relay and waiting for a bulb to go bad before making any changes.
~Steven
Simi Valley, CA
Old 05-24-2024, 10:18 AM   #4842
Steeveedee
Who Changed This?
Steeveedee's Avatar
More pics
Sure is purty! I like that color.
~Steven
Simi Valley, CA
Old 05-24-2024, 11:48 AM   #4843
Chevys4life
A few more.
That's a nice color combination. It is going to look really good!!!
Chevys4life is offline   Reply With Quote
Old 05-24-2024, 02:32 PM   #4844
72c20customcamper
Got the new engine started . Ran real nice now I can put the nose back on . Have a video but for some reason I can’t upload it from my phone to YouTube
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-24-2024, 03:14 PM   #4845
Steeveedee
Who Changed This?
Steeveedee's Avatar
Does BPE break the cams in on their engines? If it's a roller, that might be a moot point? I've read the break-in procedure and it seems to be full power runs. Seeing all the horror stories about cams going flat, I hesitate to rebuild the old 402.
~Steven
Simi Valley, CA
Old 05-24-2024, 05:29 PM   #4846
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
A few more.
Nice, looks good
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-24-2024, 07:12 PM   #4847
72c20customcamper
Ran on a dyno but it’s a roller cam engine so there is no initial 2000 rpm for 20 minutes break in ,as per their instructions I did turn the engine over on the starter with the plugs removed till it had oil pressure start at high idle check for leaks and noise ,drive at moderate speeds and not at one speed to long for 500 miles . I did use their break in oil never put bright blue oil in an engine
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-24-2024, 07:21 PM   #4848
72c20customcamper
Another thing I don’t remember ever taking a brand new car and revving the piss out of it in park or neutral. I remember getting new AMC cars and jeeps right off the truck prepping them and then putting them on the lot . Nobody ever did the 2000 rpm for 20 minutes . Well I can remember my cousin taking AMXs and Machines out and beating the piss out of them .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-24-2024, 07:52 PM   #4849
'68OrangeSunshine
That brings up a good point... Does the Factory break-in the engines before installing them on the line? Or are they run on a manufacturer's track to break in?
I know home builders always go thru the ritual of breaking in a newly-assembled engine:
With a distributor shaft mounted in a variable speed drill motor's chuck, spin up the Oil Pump until circulation is noted.
Reinstall Distributor.
With a crankcase full of Non Detergent SAE 30 oil,
Pre Run at a specified RPM for about 20 or 30 minutes in place, observing functions.
Some will flush this oil and filter, and add more ND SAE 30 and run for 500 miles at variable speeds but no freeway action.
After 500 miles, flush oil again with type you will run for its life, and the break-in is complete.
So do the manufacturers just pump out green engines, and let the consumers break them in?
Old 05-24-2024, 08:27 PM   #4850
72c20customcamper
The car manufactures do not break in engines . Used to be cars would have less than 10 miles on them mostly from the dealer moving it and going to fill it up but I doubt they fill them up anymore . The last new vehicle I bought was my Dodge 3500 CTD it had 100 miles on it as they had to bring it up from another dealer . But with overhead cams roller cams the need to break in is moot. Studebakers have solid lifters never had one wipe a cam out .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
