Old 09-19-2004, 06:44 PM   #1
Madbomber88
Active Member
Madbomber88's Avatar
My blazer drives smooth in front wheel drive
Well it finally happened. Drive up a gradual incline on a highway, and my rear end blew out. Driveshaft spins freely with only a nice clanking noisein the rear.
I put it in 4X4 and got home fine in front wheel drive. Pulled the cover and it's a mess of broken metal. If I'm going to pay a mechanic a few hundred to fix it, I'm thinking of getting a new axle.
It's a 71 CST with a 12 bolt rear and posi from the factory. What are my options for axles? All I know of the top of my head is Boyce equipment, but I can't find a 12 bolt on their website.
Any ideas are much appreciated.
Thanks,
-Tim
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 09-20-2004, 11:02 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
12 bolts are a dime a dozen.Just go to a junk yard and look around.
Do you know your gear ratio?
I'll bet you could pick up a 12 bolt at a pick-a-part for less than $100.00.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-20-2004, 11:58 PM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Correct me if I'm wrong, but the spring pads are narrower on our first gens 4x4s than '67-'72 leaf spring 4x2s and '73-up 4x4s/4x2s. If you use a '73-up 12-bolt (these are a dime a dozen) you will need to move the spring pads outward, relocate the shock mounts (different location and we need non-staggered), and work out the brake lines (just use the '73-up?). I think there is also a difference in spring pad width (plus the u-bolt direction difference).
If anyone has any more information on this swap I'm also interested.
badpeanut is offline   Reply With Quote
Old 09-21-2004, 01:58 PM   #4
3wbdriver
3wbdriver's Avatar
Posi
Hey madbomber. If that's an Eaton Posi unit, and you decide to replace it, let me know please. I'm looking for one. I've got a bad housing with good guts looking for a home. Thanks.
'72 Blazer, 4WD, 350/4 spd. Affectionately known as "Da Beast"
'04 Silverado (new daily driver)
'00 Intrepid (wife's ride)
It's a BLAZER dude! No options, no emblems, no a/c, no fancy shmancy. It's a BLAZER....
3wbdriver is offline   Reply With Quote
