Old 05-18-2006, 11:11 PM   #226
TugOwar
Re: Project Penicillin~ 68 crewcab build up!
Dayum son, you do good work!
TugOwar is offline   Reply With Quote
Old 05-18-2006, 11:43 PM   #227
ChevyDude
Your project completely blows me away....WOW you are amazing! Great...or more like.... Incredible work dude!!!
ChevyDude is offline   Reply With Quote
Old 05-21-2006, 01:29 PM   #228
Rokcrln
Rokcrln's Avatar
Now the real fun has begun! Removal and replacement of the pass side A post. I thought it had been fixed or scabed onto before and one I cut it open I was right. In the past some PO had repaired the rust by cutting part of the post off and scabing on a new section over the old one. They left all the inner rust un-treated and now it shows. First ting I did was braced off the opening and added two alignment bars. These are set right to th einside lip of the where the new window chanel must sit. The top one is set right into the upper corner as well for a better alignment. After removing the small section for inspection you can see where the added skin was installed in the past as well as the remainder of the old section rusting away. If you look close you can see the old lips of the chanel and the new old section added and blended at the outer edge. The new post we have will be installed from the floor to the roof and accross most of the passenger upper door opening.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-21-2006, 01:31 PM   #229
Rokcrln
Rokcrln's Avatar
And the last two for Now.
Kevin
LFD Inc.
Old 05-21-2006, 06:01 PM   #230
chevyboy55
chevyboy55's Avatar
Kevin
I have been following the project with utter amazment at your skills. Are you keeping track of how many hours you have in it? just kinda wondering. Mike
chevyboy55 is offline   Reply With Quote
Old 05-21-2006, 06:35 PM   #231
Rokcrln
Rokcrln's Avatar
Originally Posted by chevyboy55
Kevin
Yes and by each task as well!
Kevin
LFD Inc.
Old 05-21-2006, 07:56 PM   #232
cornutz
All Praise RANDY!!
cornutz's Avatar
Awesome Kevin!!! Just Amazing!!! Keep the pics flying...
cornutz is offline   Reply With Quote
Old 05-22-2006, 05:27 AM   #233
local13hutch
MEMBER
local13hutch's Avatar
Rokcrln.. Every time I see your avatar guy I stop and read whatever it is you are talking about. I cant begin to tell you how impressed I am with all of your work I have seen so far. I live in orange county cal. In garbage grove ''Garden-Grove''. I absolutely have got to own a crew cab 4x4 dually fifth wheel set up with a diesel power plant behind it. I work full time as a long-shoremen in L A harbor but I am just moving into a shop I just bought about a mile from my house. I am going to build old trucks,and and some 4x4's pretty much old stuff. I used to rent a shop a couple of years ago but it got to expensive and had to let it go. I have been building at my house but it's getting out of hand. It's taken alot to get this new place and I cant wait ,one more week and escrow will close. GOD-WILLING....Any way I have got a couple of old subs but I dont no exactly where and what to start with and I know you do. I am sure it would be better to start with an actual crew cab but dont know how easy or costly it would be. Because I want to go with a diesel I might be better off using a newer frame and running gear. But I realize that gm has gone to the independent front end and I just prefer the old dana 60 f and 70 r tried and true. In your opinion what should I collect. Maby a fully functional older gm one ton. And possibly cut up a sub like that black one on ebay last month. That did look pretty sweet, ofcourse I didnt see it in person. Then there was that wierd lookin one out of oregon that was blue and white but the bed seemed to short I think that although it was a factory truck it seemed like the length of a sub. factory wack job . I dont know...Please give me a moment of your time I would appreciate it. Maby you can point me in the right direction and possibly find or sell me something......THANK-YOU...
86 sub 4wd, 1 ton, duallie, big block th475
72 c10 short fleet, pro street
72 K/5 blazer,2x4 almost stock
72 3/4 ton sub 4x4
61 morris minor pickup, chevy 4.3 v6
03 escalade, 24" momo's wifes
96 2wd 2door tahoe
67 2wd suburban
72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo.
local13hutch is offline   Reply With Quote
Old 05-22-2006, 07:37 AM   #234
Rokcrln
Rokcrln's Avatar
Good luck with Escro it can be a pain. First off just so we are talking the same thing. 67-72 crew cabs were all custom built never came from the factory that way. People used a Burb or chopped up a few trucks to get what they wanted. As far as frames go this one is sitting on a mid 80's crew cab long bed 3/4 ton frame (you just need to put th ebody mounts were they are neded) and running gear. If you have the $ to find a new Diesel frame and motor I would start with that for the added frame strenght. As far as the front end being IFS just find a dana 60/70 from a Ford that way your driveline is on the drivers side like the chevy IFS is set up for. Then just make some spring hangers and a cross over high steer set up and you are half way their. Then take a burb and cut the back of the cab off and slap on a truck cab rear section while it is still on the stock frame. Once that is done then pull the body and drop it befind the Duromax and start lining things up to fit onto the new frame. Don't be surprised if you end up cutting out the whole fire wall in order to get the fenders to fit over the wheels and the radiator to fit behind the grill. By swaping your own straite axel into the front you can place it where you want it and lessen the fire wall clearance problems some what. I have thought about doing this with a PSD I own for a tow rig but I have one or two things to finish first. Have fun and keep us posted.
Kevin
LFD Inc.
Old 05-22-2006, 05:14 PM   #235
Rokcrln
Rokcrln's Avatar
Here is my before lunch work. I have it ready to do some fine tuning on the new post before test fitting. Once it fits and all bolts go back in then I will remove the post and prep and treat everything before welding it in for good. Then this will leave a little bit of patching at the kick panel location as well as around the headliner location.
Kevin
LFD Inc.
Old 05-22-2006, 11:05 PM   #236
Rokcrln
Rokcrln's Avatar
Things are looking up, parts fit well with a bit of moving and pushing. The jamb is spot welded in and ready for some small filler pieces. I had to cut out more than I wanted to due to previous damage but it still is only a small sliver when you concider what we started with. What really sucks is once this is all welded in and patched up I will need to cut it back apart to replace teh kick panel bottom and bottom of teh A post. I could have done it before installing the post but since it is in fairly good shape and has never been damaged I felt it would fit better this way. Then rocker party time! Here are a few pic's.
Kevin
LFD Inc.
Old 05-22-2006, 11:38 PM   #237
extd56
extd56's Avatar
And I thought we were going to make it a convertible, cut it at the roof and make a new top for it. Not too many 4 door crew cab convertibles around here and it would not be duplicated. Not by any sane person at least. Looks good Kevin, a lot better than when I saw it this afternoon and looked like the rust had gotten the best of the A pillar. You had a big pile of rusty parts this afternoon. A now a moment of silence for the GMC truck that gave up its cab for this crew cab to get a new A pillar.
extd56 is offline   Reply With Quote
Old 05-23-2006, 12:23 AM   #238
BAD4X4
BAD4X4's Avatar
The truck on ebay was a suburban conversion. The guy who owns Host campers and used to own a part of Beaver motor coaches in Bend Oregon built it. The truck is a 3 door with 4th as a fake. My buddy bought the truck a few months ago and learned how expensive these trucks can be. So he sold it. The frame and body all sub just chopped. Look at the back window it's bigger then stock.The roof is still sub too. My dad built a stretch cab years ago. I just wanted to say keep up the good work and you guys are doing a great job. I can't wait to see it when it is done. Thanx Dana
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 05-23-2006, 08:40 PM   #239
Rokcrln
Rokcrln's Avatar
The new post is welded in enough to start cutting everything else out I will have some work to do on the pass side rain gutter to get things right. Before we cut into it the gutter had some real bad waves to it and now that the front 1/3 is good it make the rest look like crap. I think I will end up just fabricating a new outer edge of the gutter so we end up with a nice strait line.
Kevin
LFD Inc.
Old 05-23-2006, 08:45 PM   #240
Rokcrln
Rokcrln's Avatar
I then test fit the new rockers, A pillar bottom and kick panel just to see how bad things would be and I was pleased with how it just fell together. At this point I have not trimmed anything yet, I just put a few clamps on to get a better view of where things are going. Tomarrow I will work on bending up the inner rockers and floor patches (3rd door fool mainly) and get that all tacked in. Then I will trim the rest of the parts and screw everything in place for a door fitment check. If that goes ok then I will melt it all in and move back up to the roof.
Kevin
LFD Inc.
Old 05-26-2006, 04:15 AM   #241
local13hutch
MEMBER
rokcrln...Thanks for the tips this is exactly what im gonna do....I dont no for sure but by what you said the driveline for a IFS comes out on the drivers side so ill need a axle from a ford and then a cross-over steering set-up. This sounds good but is the transfercase/ 4x4 gear box as strong as a 205.. Is it possible to use a 2-wd duramax and go with a divorced 205. Or am I gonna run into to many headaches. And what would be the best year engine to go with if I had access to any of them.I hear that some years are better than others....Guy I know your time is valuable. And I just want you to know that I appreciate your response so far. I'm not just shootin the breeze. Everything you have told me so far is going direclty into my ''baby'' I mean truck... I hope you dont mind but I have catalogged most of what you have done so far strictly for my own build reference........ THANK-YOU-AGAIN AND THANKS FOR TAKING THE TIME TO KEEP US ALL POSTED......
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
Old 05-27-2006, 12:25 AM   #242
Rokcrln
Rokcrln's Avatar
No problem and use the info for what ever you want that is why I post it. As far as engines and T-cases I have no clue as to what is better. But I am sure you can do a 2wd to a divorced case with out much trouble. All my 4x4 info is for rock crawling and we use Atlass II cases that is not needed for street use but would hold up to what you want and can bolt to almost any tranny. Check with advanced adapters for info.
Kevin
LFD Inc.
Old 05-27-2006, 12:41 AM   #243
Chevrolet4x4s
Chevrolet4x4s's Avatar
Its gonna be one of those ultra rare option test vehicles that will even fool GM
Great Work
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 05-27-2006, 02:25 AM   #244
local13hutch
MEMBER
rokcrln... Thank you . And I have used advanced adapters for quite a few projects. My sister lives in the area up there. I have already started my research on wich truck to start with alot of these guys on this website are friggin ''diesel guru's'' so with there help and yours I'll be able to get a handle on this project without spinnin my wheels to much and wasting money I dont have....Thanks again.....
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
Old 05-27-2006, 09:27 AM   #245
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
wow
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 05-28-2006, 12:43 AM   #246
72CREWCAB
Lookin' awsome Kevin! Thanks for keepin us all updated!
After everything you've done on this cab you should be able to pound off a half dozen crew cabs in no time..!! let's see..six cabs X 20k each....
72CREWCAB is offline   Reply With Quote
Old 05-28-2006, 02:36 AM   #247
mbgmike
can i come out and visit you?
mbgmike is offline   Reply With Quote
Old 05-31-2006, 10:42 PM   #248
Rokcrln
Rokcrln's Avatar
Not alot but still progress is progress. I had a little over an hour to kill tonight so I got started by cutting off a perfictly good bottom B pillar I did this so I could cut off the rest of the inner rocker that runs from the front door to the back door. This also allows me to runn the new inner panel thru the B post area and have all fresh metal. Once that was cut off I trimmed the floor back to good metal and then set my new panel in place and scribed a line for a but weld. I welded that seam up and ground down the welds and called it a night. Next I will finish up the vertical returns and bend up a rear door inner rocker with plenty of extra floor metal to patch in all I had to remove back their.
Kevin
LFD Inc.
Old 05-31-2006, 11:00 PM   #249
Frizzle Fry
Frizzle Fry's Avatar
That looks horrible Get some skills man...
Frizzle Fry is offline   Reply With Quote
Old 06-01-2006, 12:21 AM   #250
Rokcrln
Rokcrln's Avatar
Heck I wish they all looked this good to start with. If they did I might have some free time to work on my junk!
Kevin
LFD Inc.
