Old 03-30-2008, 08:20 PM   #226
55dude
55dude's Avatar
Re: My Project 56Chevy1300
best way is from the motor back. make sue everything is level side to side,front to back. should improve the ride with the updates 10 fold. if you match the trans output angle with the pinion angle you should be set.
55dude is offline   Reply With Quote
Old 03-31-2008, 06:00 PM   #227
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
yepers, it sure is looking good
tiggerstoy is offline   Reply With Quote
Old 04-10-2008, 12:23 AM   #228
hammerdog57
hammerdog57's Avatar
I was wondering if you had any pics with front sheet metal back on? Was wanting to see how keeping stock axle centerline looked with the camaro clip and bagged. Did wheels look centered in opening with truck on the ground? I also have the video to do the clip. Others tell me to move axle centerline forward about an inch.
hammerdog57 is offline   Reply With Quote
Old 04-11-2008, 10:58 PM   #229
56chevy1300
56chevy1300's Avatar
No sheetmetal back on yet; I agree that moving the axle centerline 1" forward will center the wheels in the wheel wells, you may want to do this in the rear as well.
56chevy1300 is offline   Reply With Quote
Old 04-12-2008, 02:28 AM   #230
hammerdog57
I was also wondering if i move the axle centerline forward 1 " if this will effect the clearance between the steering box and the radiator support? It looks like it might be a problem based on pics since the clip would be moving forward and support staying in same location.
Old 04-12-2008, 08:56 PM   #231
56chevy1300
I'll check on the clearance when I get home and let you know.
Old 04-13-2008, 05:55 AM   #232
56chevy1300
hope these pics help...looks like with some mods it will work
Old 04-13-2008, 02:00 PM   #233
hammerdog57
Thanks for all the pics. Looking forward to the pics with sheetmetal back on.
Old 04-29-2008, 06:24 AM   #234
Sinisterspeed
Sinisterspeed's Avatar
Looking good. Cant wait to see the finished product.
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 07-04-2008, 01:08 PM   #235
northerngmc
northerngmc's Avatar
UPDATES?
Will we see it this summer?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 08-19-2008, 11:52 AM   #236
56chevy1300
Hey Blaine...no, you won't see my truck this year...haven't had any time work work on her, but after September, I will be back in the garage!
Old 10-01-2008, 11:48 AM   #237
northerngmc
Well it is October!
Blaine
Old 10-01-2008, 01:33 PM   #238
Throwback
Just found this and thought I would say, i would run a Watts Link instead of a panhard bar. keep the axle centered thru complete travel instead of moving it side to side with travel. Only bad part is you couldn't run your bag behind axle setup.
Throwback is offline   Reply With Quote
Old 10-01-2008, 11:08 PM   #239
56chevy1300
I'm back in the shop, started to assembly the engine. I'm probably going to need some help as I've never done this before.
Thanks Throwback, I am a novice at this so I think I'm going to stick with the panhard supplied. This truck is just for cruising anyways.
Old 10-02-2008, 02:46 AM   #240
watahyahknow
watahyahknow's Avatar
give us a step by step as i never put an engine together as whell but would love to try it in the future .
there is a book i have that has a dvd with it , verry handy shows a lot of little things yu wouldn't think about .
make verry sure the machinist done his job correctly and everything spins like it should during assemby
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-02-2008, 07:31 PM   #241
56chevy1300
You guys are going to have to help me! Do I need a gasket between the block and pump? What is the torque spec of the oil pump bolt? What is the torque spec of the oil pump nut?
Old 10-02-2008, 08:03 PM   #242
56chevy1300
Pics
Old 10-02-2008, 08:05 PM   #243
56chevy1300
Question 1 - Do I use this gasket sealer on both sides of the gasket? Do I need to let this stuff set first?
Question 2 - Do I need to use red or blue threadlocker on the oil pump bolt?
Old 10-02-2008, 08:07 PM   #244
56chevy1300
I also just measured the gap between the oil pump pickup and the oil pan...its about an inch. What is the gap supposed to be?
Old 10-24-2008, 08:29 PM   #245
56chevy1300
Engine install...time to level the frame and square the engine.
Old 10-25-2008, 11:25 AM   #246
Daniel U
Daniel U's Avatar
Nice!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 10-25-2008, 04:57 PM   #247
56chevy1300
Mounts are tacked in. Working on tranny crossmember. Needed to cut a notch to clear the brake booster.
Old 10-26-2008, 09:59 PM   #248
CAL 58 GMC
CAL 58 GMC's Avatar
Let me know how well the cross menber fits. I had the same problem with mine not clearing the booster. I use spacers to get it to clear but it makes the crossmember hang down to low. when you get it bolted in could you take some detail photos and post them?
CAL 58 GMC is offline   Reply With Quote
Old 10-27-2008, 02:28 PM   #249
56chevy1300
Hey Dave, hope these help. There's about 3/4 to 1" clearance. I added a 1/8" spacer between the crossmember mounting bracket and the frame. I also welded the driver's side bracket to the crossmember as I cut a little notch out of it. I'm not sure if I can weld the other side...don't know if I could take it off if it was welded since its on the inside of the frame.
Old 10-27-2008, 02:54 PM   #250
watahyahknow
a hydraboost might've been an option here
