Old 05-25-2016, 01:57 AM   #301
swamp rat
swamp rat's Avatar
Re: Blood Sweat and Tears.. 67 Build Thread
I would concider it too but I need to get my house payed off first. Hang in there!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-01-2016, 04:18 PM   #302
Possmguts
Possmguts's Avatar
Well.. there goes any truck parts for a while... busted the crank in the old one and it was worn out anyway... so... I guess the truck gets put on the back shelf for a while... again... (sigh)...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 06-01-2016, 08:03 PM   #303
jlsanborn
jlsanborn's Avatar
I feel for you. Story of my life.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 06-02-2016, 10:30 AM   #304
RRR18
RRR18's Avatar
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 06-02-2016, 04:36 PM   #305
roushinator
roushinator's Avatar
Originally Posted by Possmguts View Post
Houston.. we have a problem...
Apparently I WAS supposed to notch the bed bracket on the frame to get that sway bar mounted a little more forward after all....
What swaybar is that?
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 06-04-2016, 01:15 AM   #306
swamp rat
swamp rat's Avatar
That ain't nuttin, wait till you get old and bust your crank! LOL!!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-05-2016, 12:28 AM   #307
Possmguts
Possmguts's Avatar
tOO Late.. Ive already busted a few cranks lol
Thats a "No Limit Engineering" Above frame sway bar...
Old 06-05-2016, 08:05 PM   #308
Possmguts
Possmguts's Avatar
Managed to get all the holes that have been drilled in the bed side to pull dents and hold tons of bondo in welded up and ground down... BUT I stressed the metal in the biggest flat spot just behind the cab and its tin canning now... I guess I have to study up how to fix that before moving on. Has any of you guys used the cold compressed air and heat gun method to de-stress metal before?
Started "Trying" to disassemble the bed as well and found I need a second person to push down on the castle bolts to keep them from spinning...
I'm going to HAVE to find some good tail sections with the tail light sections for these bed sides if I'm going to save them... Any ideas where to find those?
I swear I'm at a point where I just want to hand it over to someone to finish up on the body...
Old 06-05-2016, 08:41 PM   #309
GR8-68
GR8-68's Avatar
I love your project build !! Nothing like a truck that is built on blood sweat and tears
GR8-68 is offline   Reply With Quote
Old 06-05-2016, 10:22 PM   #310
Metaldoc
Metaldoc's Avatar
Oil canning sheet metal can be a pain, hammer and dolly to stretch it to keep it out and torch to red to shrink to hold it in. Do some research on heat shrinking with a torch before you try on the body. Heat gun is not hot enough to shrink. That process works on hail dents. The bungee hooked on the bars held the carriage bolts then cut them off with cut off wheel.
Metaldoc is offline   Reply With Quote
Old 06-05-2016, 11:02 PM   #311
Possmguts
Possmguts's Avatar
I suppose I wont be re-using any of the bolts so.. cutting them it will be... I have a steel floor and will be doing a wood one with a new bed front. The heat shrinking sound a bit scary but Ill look up some vids and give it a shot...
Thanks Metaldoc, I appreciate that. Any advice on those rear corners?
Old 06-06-2016, 06:36 AM   #312
Metaldoc
Metaldoc's Avatar
If the metal around the lights is solid, a 180 deg. hook on a slide hammer. remove the taillight housing and you should get in with that. Replacing both bed sides would fix the all the problems. It might be cheaper to replace than to repair with all the body work involved on the box sides.
Old 06-06-2016, 08:53 AM   #313
Possmguts
Possmguts's Avatar
I know it would be easier to just replace them, But I would rather put the money elsewhere. Its only costing me time and a few bucks to fix them... Thats 1400 bucks that would buy some nice stuff under the hood or in the cab. Sucks being on a budget...
Old 06-06-2016, 09:22 AM   #314
roushinator
Thanks. Do you have a picture of how it connects to the trailing arms? Thanks.
Ryan...
Old 06-06-2016, 09:30 AM   #315
Possmguts
Possmguts's Avatar
There are plates under the axle it and the shocks attach to... I dont have a pic of that area. Ill try to remember to get one for you. Here is a link to the panhard bar kit that includes the plates... http://nolimitengineering.com/produc...32&id=26244500
Old 06-08-2016, 11:31 PM   #316
Bubba4spd
Bubba4spd's Avatar
I just started catching up on your restore post here. Auburn is where I went to college so I'm a little attached to your truck already. You really have invested a lot of hard work, you sure haven't taken the easy route, every step has been hand to hand combat...very proud of you for hanging in there. I purchased my truck in a small town just north of Auburn but yours was in much better condition! I'd be happy just to get mine back to the shape yours was in before you started!
Bubba4spd is offline   Reply With Quote
Old 06-08-2016, 11:59 PM   #317
Possmguts
Possmguts's Avatar
Thank you very much. Its comments and support like that that keep me going. There really was a lot hidden under that paint when I got it. I hope to have some sort of progress pics for ya'll this weekend when I get back home.
Do you have a build thread going on yours?
Old 06-09-2016, 05:41 AM   #318
flashed
I love your new avatar pic ,just noticed it this morning ,look forward to more update pics ,I wish I had your skills .
flashed is offline   Reply With Quote
Old 06-09-2016, 09:36 AM   #319
Bubba4spd
Bubba4spd's Avatar
Not yet but I guess I could get one going...just decided this past weekend to finally after all these years to get her started. Many things I am unsure of such as engine and trans selection even though I know it will be a manual. Color and interior I have no idea either, nothing over the top. But I am 100% decided on plenty enough to get started such as just a basic solid frame, suspension, and presentable bodywork.
Maybe by starting a thread, it will help keep me motivated, have you found this to be the case at any point along your build?
Old 06-09-2016, 08:54 PM   #320
Possmguts
Possmguts's Avatar
Absolutely... I only have maybe 2 friends at home that are interested in it. Its been a solo build from the start other than getting someone to help with the lifting of heavy stuff. If it wasnt for this forum I would have thrown in the towel a while back. Guys on here have been great and I feel obligated to see this through for bragging rights on here lol.
As far as yours goes... If I had a nickle for every time I have changed my mind on colors and interior design during this build I would have been able to afford to just pay someone else to do the work... I still aint 100% sure on the orange yet. Ill know what color its going to be when I leave the paint store with the box full of paint lol The wheels will be determined once its painted. Only way to do it is to just grab a wrench and start pulling it apart.
Old 06-10-2016, 08:22 PM   #321
Bubba4spd
Bubba4spd's Avatar
Bragging rights......lol. I like that. Well we all need something from behind to push us. Well I'm excited for you to finish her on up so you can have your garage back and enjoy the fruit of your labor.
Old 06-17-2016, 04:57 PM   #322
Possmguts
Possmguts's Avatar
So I made it home again and I might be able to get something done this weekend... I got a new transmission cross member I hope works and found this on Craigslist... never used and was sent to me in the envelope it was mailed out in in 1967 to boot.
Old 06-17-2016, 06:31 PM   #323
flashed
Now that is a nice plate .
Old 06-18-2016, 04:51 PM   #324
Possmguts
Possmguts's Avatar
No body work today. Cleaned the garage up a bit and did manage to get this cleaned up and painted. It will do the job for a while while I save for the 5 or 6 speed. I wasn't going to spend the time sanding the rough case since its not going to be under there for very long.
Old 06-19-2016, 04:16 PM   #325
Possmguts
Possmguts's Avatar
And before I knew it... I hit the Buy it button...
