12-02-2015, 10:19 AM | #301 |
Re: Blake's 67 GMC stepside build
Thank's Kees, I think it's a mixture between really Brave or really Stupid!
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-02-2015, 10:28 AM | #302 |
Pic #1. The new piece after making the needed bends.
Pic #2. Mocking up the fit. Pic #3. Another view. Pic #4. This was after the welding,metal finish and some weld through primer were done and the O.E. mount welded back in. Onto the passenger side. Mark...
12-02-2015, 01:54 PM | #303 |
Nice work Mark. I am thinking I would have thrown in the towel on that one.
12-03-2015, 10:55 AM | #304 |
Thank's Doug!
It was kinda like the seen from "Fastimes at Ridgemont High" when spicoli says "I've got an awesome set of tools I can fix it!" So I took a leap into the deep end! Mark...
12-03-2015, 11:06 AM | #305 |
Pic #1. This was the mock up of the large section for the passenger side.
Pic #2. After it was tacked in place. Pic #3. 2nd view of it tacked in place. If you notice it has holes in it for flange nuts to be welded in for mounting the inner fender. Pic #4. In this shot it shows the upright all repaired just like the Drivers side. Moving on...next up flange nuts and flange. Mark...
12-03-2015, 04:27 PM | #306 | |
You are Supernatural Really nice work, Doug is right I think, most of us wouldn't start on this one!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
12-04-2015, 10:29 AM | #307 |
Well I don't know about the Supernatural thing but thank's for the compliment my friend (your skills are right with me)
12-04-2015, 10:45 AM | #308 |
Pic #1. Flange nuts welded in place, ready to start on the flange.
Pic #2. The flange was super easy, I just cut a long strip and started tacking along the length and bent to shape. Weld,grind etc. Pic #3. 2nd view Pic #4. 3rd view for good measure. Mark...
12-04-2015, 11:29 AM | #309 |
Btw I am starting a new build thread for another customer (off topic in alternate tinkering ) on a 1978 Toyota FJ40
link down below. http://67-72chevytrucks.com/vboard/showthread.php?t=690527 Reed 78 FJ40 Rebuild
12-04-2015, 02:42 PM | #310 |
I think it is way more than an awesome set of tools....
12-07-2015, 10:40 AM | #311 |
HaHa Thank's Doug!!
12-07-2015, 11:07 AM | #312 |
Pic #1. The upper portion of the stock core support is very Ugly with these relief cuts, SO away they will go...
Pic #2. another view (do not have a after shot) But they were welded,ground and metal finished smooth! Pic #3. This was after some light bodywork,Epoxy primer and High Build primer. Pic #4. 2nd coat of H.B. Primer
12-08-2015, 10:43 AM | #313 |
Pic #1. The core support is all done and in it's final paint, again going with the Satin black.
Pic #2. another view. Pic #3. Set in place with the inner fenders. Just to recap on the Engine bay: Firewall,under hood, inner fenders and core support will All be Satin Black. Trying to give it a little contrast when you open the Hood. Have not nailed down what all will be done with the Engine yet will figure it out as it progresses. Mark...
12-08-2015, 05:42 PM | #314 |
Came out great!!
Really a nice job you did there!!
12-08-2015, 09:23 PM | #315 |
Yea!! Nice job. I like the idea of satin.
Ryan. |
12-09-2015, 10:22 AM | #316 |
You've done a lot of nice metal work on this. I'll be following along. Keep it up!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
12-09-2015, 10:54 AM | #317 |
Kees,yj4000,and knomadd thank you guy's!
This thing has been a TON of work,more than I had ever expected it to be but I guess that's all part of it! (it was an old Farm truck and it shows!!) Mark...
12-09-2015, 11:05 AM | #318 |
So now that the core is finished I will turn my attention to the inside of the cab again. This time the inner roof. The customer is a Big guy and can't use the sun visors so the stock holes will be filled per his request.
Pic #1. Here I'm getting ready to weld up several holes that someone screwed fabric to the back panel years ago. Pic #2. Visor holes welded up. Pic #3. 2nd view. Pic #4. (jumping ahead after bodywork) Sprayed in Epoxy Primer. Pic #5. And finally in H.B. Primer and ready for blocking. Mark...
12-10-2015, 11:02 AM | #319 |
Pic #1. The cab all masked and ready for interior color.
Pic #2. 2nd view. Pic #3. After the color was shot. (it is a G.M. color called light shale) Pic #4. 2nd view. up next is the roll pan it will need a bit of fine tuning. Mark...
12-11-2015, 12:46 AM | #320 |
Doing some nice work!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-11-2015, 06:30 AM | #321 |
Yep, nice work Mark. The light shale...was that an original color? It kinda looks like primer and I don't remember seeing it before.
12-11-2015, 10:53 AM | #322 |
Thank's Swamp rat
12-11-2015, 10:58 AM | #323 |
Thank's Doug!
Yes it is a stock GM color and they have a medium and Dark as well. On his interior there will be some dark accent pieces to mix it up a bit. It was an early 2000 model I believe.
12-15-2015, 11:05 AM | #324 |
I'm going to switch gears a bit here and show the roll pan.
Pic #1. When the pan showed up it wasn't the best looking piece..meaning seams not welded ugly corners etc. So in this shot I welded the seams around the plate box and the ends. Pic #2. I then rounded the corners and will cap them off. (bolt on pan) Pic #3. The mockup piece for the cap. These will add a more finished look to the ends of the pan when mounted. Pic #4. After welding. Pic #5. In Epoxy primer. Mark...
12-16-2015, 11:35 AM | #325 |
Pic #1. The Drivers door being prepped for interior color. The top section of the door will be the same as main color of the truck.
Pic #2. After laying down the blue Fine Line tape. Pic #3. Another view of how the separation of the colors will be. Pic #4. After Light shale was shot. Mark...
