#26 | |
Who's got steelies?
![]() Join Date: Feb 2006
Re: sb drivers side alt bracket upper
![]() But recently, I've had this itch to get the engine bay looking more "stock". Something about the primitive look of the older brackets looks cool.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#27 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#28 |
Sierra Grande Club
is that on a short WP?
#29 |
Who's got steelies?
From what I've read on this thread, the 72 bracket (just the sickle part) is a little different because the 72 alternator case was slightly larger. However, I haven't seen a 69-71 and 72 bracket side by side to tell you for sure
Yes, it is a short water pump. Passenger side bracket looks like it came off of a mid 70's Chevelle or Monte. Alternator is very close to fan shroud with this set up, but it uses a shorter belt.
#30 |
In Memoriam...
I love posting pics. Here's mine on a '68 307.
Notice how close the Upper Radiator hose is to the alternator's cooling blades. It has actually "clearanced" the hose a bit, taking a small chunck out of the hose. Guess someone didn't have the right lenght belt last time it was replaced ![]() I definately need to replace that hose and belt... ![]() ![]()
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
#31 | |
'69cst/10 |
