Old 02-11-2007, 10:50 AM   #1
craftsworker
sb drivers side alt bracket upper
does anyone know where i can get one of these brackets from ...i have the lower bracket which i repainted already but i need the upper bracket.When i ask around for and upper alt bracket (drivers side) on a sb chevy short waterpump i get the deer in the headlights look.or they point me at something that cost 400 bucks lol
i am getting ready to do the cs-130 alt conversion and i wanted to clean up this area to while i am at it.
thanks
'69cst/10
craftsworker is offline   Reply With Quote
Old 02-11-2007, 10:56 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: sb drivers side alt bracket upper
Your best bet will be to subscribe and post a WTB on the parts board.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-11-2007, 11:02 AM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I have one you can have for free.
Dean
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-11-2007, 11:43 AM   #4
Southedisto
River life......
Southedisto's Avatar
Check your local parts store, autozone/advance, both of them have them usually. They are in there "chrome" parts section.
Southedisto is offline   Reply With Quote
Old 02-11-2007, 12:29 PM   #5
Aarons72s
There are 3 types of upper brackets for short water pump small blocks. The 67-68 type, the 69-71 type and the 72 type. I think the chrome one at the parts store is 67-68 type and the 69-71 is avaliable by some vendors. The 72 style was avaliable new awhile back but havent seen them avaliable lately. Hope this helps.
Aarons72s is offline   Reply With Quote
Old 02-11-2007, 12:32 PM   #6
Sport/Truck
Sierra Grande Club
I’m not sure what I have then. What’s the difference? Length?
s/t
Old 02-11-2007, 12:37 PM   #7
Aarons72s
The 67-68 is real long as it mounts to the water pump. The 69-72 mount to the alternator bracket on the head. The 69-71 is shorter than the 72 bracket. If the bracket came off your truck it was probably the 69-71 short bracket since yours is a 71. If I remeber right the brackets were lengthened in 72 for the larger diamater redesigned alternator housing that looks like the 73 up alternators but is still external regulated. Hope this helps.
Old 02-11-2007, 12:55 PM   #8
Sport/Truck
Sierra Grande Club
My brackets were all hosed up (see picture). I got a set from a guy in Texas and haven’t installed then yet, so I really don’t know if they are going to work. Here’s a picture of the old alt set up.
s/t
Old 02-11-2007, 01:18 PM   #9
Aarons72s
That looks like a 69-71 upper bracket and modified for passenger side use instead of on the correct driver side. Not sure. Never seen one modified like that. Sorry not much help on this one.
Old 02-11-2007, 01:25 PM   #10
Sport/Truck
Sierra Grande Club
Ok, that’s good. They really didn’t modify much, just jerry rig every thing up.
Old 02-11-2007, 01:34 PM   #11
WorkinLonghorn
WorkinLonghorn's Avatar
I'm looking at the catalogue for www.truckandcarshop.com otherwise known as "Truck Shop" and they show the upper straight arm piece for $8.00. "O.E." type is $14.(?)
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 02-11-2007, 02:18 PM   #12
70GMCer
70GMCer's Avatar
Still available as of last summer at any GM dealer. Part #3951338
That number says upper alt bracket for 67/72
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 02-11-2007, 02:57 PM   #13
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Here's my 70 with the driver's side bracket. You can see the top in the pic. They do sell chrome ones at most parts stores that mimic ours.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-11-2007, 02:57 PM   #14
rage'nrat638
rage'nrat638's Avatar
heres a couple different alt brackets
rage'nrat638 is offline   Reply With Quote
Old 02-11-2007, 03:16 PM   #15
rage'nrat638
s/t
looks like yours are installed upside down on the incorrect side
Old 02-11-2007, 03:31 PM   #16
craftsworker
note the angle of the curve on rage'rat638's top 2 pics....that is the correct part,the aftermarket chrome ones i bought and tried had a milder curve and would bottom out on the cooling fan of the alt,so then i thought maybe i will run the tension bolt thru the backside of the alt mount but the bracket bottoms out on the body of the alt before the bolt will go in,yes i could change the belt to a shorter belt but would then be very close to covering the power steering pump.i gonna try to upload a couple of pics.
'69cst/10
Old 02-11-2007, 03:33 PM   #17
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
This post is great. There needs to be a FAQ thread showing what accessory brackets are correct for the different years.
Note that the 67-68 alternator setup uses a boss on the front end of the left exhaust manifold, 69 and later doesn't.
What year did they switch to the pass. side alternator mount on the small blocks?
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-11-2007, 03:41 PM   #18
krue
Designated A-hole!
krue's Avatar
Start a thread and when we get all the info I'll be glad to move it to FAQ.
www.daveramsey.com
Old 02-11-2007, 04:06 PM   #19
rage'nrat638
heres one set for sale on the board
http://67-72chevytrucks.com/vboard/s...d.php?t=226313
lets see 2/11/07 2:21 pm how long will it last
Old 02-11-2007, 06:27 PM   #20
Sport/Truck
Sierra Grande Club
Yes that's what was done. I got them all ready to go one now. The brackets look like the one your in your last picture.
Old 02-11-2007, 08:50 PM   #21
Bob D
Rolled on Paint Club
Bob D's Avatar
That is what came on my engine,and I always had trouble getting the belt tight enough to stop it from slipping. Now I have taller valve covers and the bracket was useless: alternator would hit the cover before i could get it loose enough to change the belt. Tried the chrome bracket and it would hit the fan on the alternator. I ended up cutting the stock bracket and welding in a piece of flat stock to make it longer. The belt still slips but that is probably due to the drag of the large blade flex fan that will be history soon.
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 02-11-2007, 09:39 PM   #22
craftsworker
well... when i purchased the aftermarket chrome piece i noted it had 2 bolt holes for mounting it so i figured that one went on the lower bracket and the other went to the empty bolt hole located on the head...just made more sense to me for it to have 2 bolt holes.i took a few measure ments and made up some chrome spacers for the bolts and then i went to put it on and the angle was way to far up ward,i really wanted the 2 bolt holes so i wouldn't have to worry about the pivot point moving and....i wondered about the big wahooo bend on the peice i had,see i wanted the bracket to be straight because in my little mind i was thinking ok belt applies pressure to pulley ( if its tight) so i want to make the mount straight and durable,alt might be more stable with better support,because to me the stock bracket on a pivot point doesn't make alot of sense. anyway so the bolt holes didn't line up to well so i drilled them and i still didn't like the angle so i hacked the bracket shorter and removed one of the bolt holes ...then it bottomed out on the alt.
thing i s i can't beleive only certain models of trucks were afflicted with this bracket...has to be a fair amount of other gm products still on the road....someone has to have thought at some point maybe we can improve this,make it fuction better and make it look better .......with out costing 400 bucks
doesn't have to be laser cut polished aluminum
'69cst/10
Old 02-12-2007, 07:25 PM   #23
oldgold70c10
Who's got steelies?
OK, here are some pictures I took of some brackets I am cleaning up to repaint.
The first pic shows a 67-68 bracket on the left and I believe a 69-71 on the right. The second pic is just the sickle-shaped part to compare the shape.
My Truck Page
My Youtube Channel
Old 02-12-2007, 07:33 PM   #24
jimmydean
jimmydean's Avatar
I didn't like my alternator hanging that far out, so I used a Camaro mount for the passenger side. It's a lot closer to the engine and doesn't look as bad IMO.
My truck is far from "correct" though.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-12-2007, 07:36 PM   #25
Sport/Truck
Sierra Grande Club
Can you post a picture please?
s/t
