Old 01-18-2008, 01:05 AM   #26
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: ojoe's crewcab shortbed build
Originally Posted by ponjohn View Post
What was the final length difference?
John
Going from LWB to SWB is a 14" reduction in wheelbase and you would have to lop off about 6" off the back, so technically it should be 150.5" wheelbase now. and should be about 2 feet shorter.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-18-2008, 09:16 AM   #27
OJOE
Crew Cut
OJOE's Avatar
Originally Posted by cartman View Post
Did you notch the frame due to the fact that you are going lower, or is it nessary because of the axel flip? When I build my truck I want it at about the height that yours is now. I am figuring on just the axel flip and wondering if I'll have to notch the frame or not. It's not practical in the northeast where I live to go any lower with a truck that is a daily driver. The roads here SUCK!
i would advise anyone doing a flip kit to do a c notch. i know about the roads in Mass i did a 3 mo shut down at PNPS in plymouth mass a few yrs ago. good luck on your build
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-20-2008, 08:45 AM   #28
lolife99
67-72 parts collector,…
lolife99's Avatar
Here's another one on Craigslist in Columbia, MO for you would be builders. It has the "gas miser" 350,... instead of the standard 454. http://columbiamo.craigslist.org/car/542898257.html
Keith
Convert to disc brakes.
Old 01-20-2008, 08:47 AM   #29
lolife99
lolife99's Avatar
Here's a pic,...
Keith
Old 01-26-2008, 11:19 AM   #30
nwmod39
nwmod39's Avatar
top
1980 c-10: under destruction
http://photobucket.com/albums/c372/nwmod39/
nwmod39 is offline   Reply With Quote
Old 01-26-2008, 11:37 AM   #31
pcmcobra
pcmcobra's Avatar
ojoe, looking good!
wheels look sweet
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 01-27-2008, 10:54 PM   #32
This will be yet another very intersting build to watch!
Old 01-31-2008, 12:11 PM   #33
djracer
djracer's Avatar
Joe will have a sweet ride as usual!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-04-2008, 11:05 AM   #34
mike nutt
69fatmotor
mike nutt's Avatar
joe got the brakes and rear axle finished off also lowered the rear another 2". this weekend we got the bed changed . here's a few pics.
mike nutt is offline   Reply With Quote
Old 02-04-2008, 11:23 AM   #35
LEEVON
LEEVON's Avatar
What was wrong with the old bed? It looks pretty straight...?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-04-2008, 10:23 PM   #36
OJOE
Crew Cut
OJOE's Avatar
the old bed was rust free but did have small damage on the right side. also has 2 5th wheel rails mounted in the bed (extra holes). this is a real nice bed and already had it.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 02-06-2008, 01:05 AM   #37
WELD4DAYS
NIce job.Your truck looks awesome. Can't wait to see it finished!
WELD4DAYS is offline   Reply With Quote
Old 02-06-2008, 09:02 AM   #38
OJOE
Crew Cut
OJOE's Avatar
we got the brakes blead and the cab lights off this weekend. just had to get rid of the cab lights could not look at them any longer. we tried a burb gas tank but just to big. going to go w/ a small full size 87 blazer tank.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 03-17-2008, 07:22 AM   #39
mike nutt
69fatmotor
mike nutt's Avatar
new school meets old school. got the 5.3 bolted in the truck today. fit like it was made for it .still waiting on the blazer fuel tank and trying to decided on who to use to modifiy wiring harness and reprogram the computer. any suggestions ? not much else to update right now.
Old 03-17-2008, 07:28 AM   #40
Hart_Rod
Hart_Rod's Avatar
Sweet! When did you pick that up? I'm going with Speartech for my harness. I've looked around a lot and they seem to have the best combination of price and customer service. I'm having them do some special mods for the Suburban and they seem eager to do what you want.
Question, why no AC? Are you going with the throttle by wire or are you going to switch to a cable. Speartech can do it either way.
Hart_Rod is offline   Reply With Quote
Old 03-17-2008, 07:34 AM   #41
mike nutt
69fatmotor
mike nutt's Avatar
rob , he'll be using s&p's compresser and bracket kit. the lt1 will be going in his son's '86 shortbed, the one in ojoe's avatar, but that will be another biuld.
Old 03-17-2008, 07:36 AM   #42
LMDGUY
LMDGUY's Avatar
sweet.Hey Mike How much work was it to get the 5.3 in?
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 03-17-2008, 07:48 AM   #43
mike nutt
69fatmotor
mike nutt's Avatar
we used motormount plates from edelbroc , then bolted factory stuff from the truck to the 5.3 and it bolted right in like it was made for it , and the trans crossmember will need to be moved back depending on which transmission you using.
Old 03-18-2008, 04:15 AM   #44
OJOE
Crew Cut
OJOE's Avatar
hey rod, i think i am going with the throttle by wire. what are you going to use for cruise control.
this is a long story about the engine. long story short, the man i got the engine from died in the middle of our trade and i still have not got all of the things we traded on but i have been able to contact his son and i may be able to get the rest. i still have the engine and trans that i owe him.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 03-18-2008, 04:16 AM   #45
OJOE
Crew Cut
OJOE's Avatar
hey rod, i think i am going with the throttle by wire. what are you going to use for cruise control?
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 03-18-2008, 07:31 AM   #46
Hart_Rod
Hart_Rod's Avatar
If you use the throttle by wire, Speartech can pull the wire for the cruise control, you just have to let them know when you order the harness.
R/
Old 03-19-2008, 08:12 AM   #47
Captkaos
Captkaos's Avatar
I just wanted to drop in and say I keep annoying them every other day until I hear something. Sorry sorry it is taking so long.
What do you need done to the ECM. My brother can possibly program it for you. He does this for the STS setups we sell..
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 03-20-2008, 04:11 AM   #48
OJOE
Crew Cut
OJOE's Avatar
thanks chris, when goodmark called last week they said it would be 3 weeks to get the tank to me.
i made a deal with wait4me wiring today to do my ecm and harness. still waiting on my other parts for engine.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 03-28-2008, 09:07 PM   #49
BrooKLyn
BrooKLyn's Avatar
how come u didnt use the front bed mounts and hack the rest of the frame off?
BrooKLyn is offline   Reply With Quote
Old 03-29-2008, 02:25 AM   #50
djracer
djracer's Avatar
The way he did it was the bomb. It made it impossible to line up wrong!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
