11-19-2009, 10:01 PM | #26 |
Member of the longbed union.
Re: air bag kit!
if you dont wanna spend a bunch of money stay away from Nathans kit. Both front and rear you would be looking close to 3-4 grand to have it all finished
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
11-19-2009, 10:04 PM | #27 |
Re: air bag kit!
Then you need skills & tools (or be gooooood friends w/people that have them) or the right mind-set to learn as you go & do it yourself (definitely not a 'bolt-in' for a rookie).
A bolt-in kit that lays the rails is pricey; but all the engineering is thought through & it's a matter of following assembly directions (great for the novice builder) while still doing the brunt of work on your own. In the end, it's comparable or cheaper vs. paying a shop for the same mod's. A 'bolt-on' 6/8 drop is do-able on a 'budget' w/the parts listed earlier in the thread.
11-19-2009, 10:08 PM | #28 |
Re: air bag kit!
ill do the layframe later in the future when i get out of school but for now i would like to to do the re7 bag setup!
does anyone have pics of a truck with the same setup im trying to get at? |
11-19-2009, 10:19 PM | #29 |
Re: air bag kit!
This is about the same drop. Bags bolted in place of coils, lowering blocks out back, shock relocators, bolt-in c-notch, & adjustable Panhard bar. The rear housing hits the bed floor @ that height when you encounter big bumps in the road.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-19-2009 at 10:19 PM. |
11-19-2009, 10:19 PM | #30 |
Re: air bag kit!
If you dont want to pay so much for the re7's go with no less then the 2600 dominator. You can find good deals on stuff on ebay, but I wouldn't buy any bags on there really, lot of companys say they are re7's or dominators, but they aren't. thats why they are cheap
11-19-2009, 10:25 PM | #31 |
Re: air bag kit!
the re7's are not expensive at all!
i cant go lower than that truck in the pic? |
11-19-2009, 10:28 PM | #32 |
67-72 parts collector,…
Re: air bag kit!
How much?
The lower you go,... the more it costs.
11-19-2009, 10:30 PM | #33 |
Re: air bag kit!
Isn't that the truth.
11-19-2009, 10:32 PM | #34 |
Re: air bag kit!
i understand what you guys are saying but im not talking about price right now!
i want to know what else i would need to drop it maybe 2inch more? |
11-19-2009, 10:39 PM | #35 |
Re: air bag kit!
You'd need more than a bolt in notch. That's as far as you'll get w/o cutting the frame & welding in a step-notch.
11-19-2009, 10:49 PM | #36 |
Re: air bag kit!
That's what you have to do for the rear.
The front either your going to have to Z the frame, Section your crossmember, or buy a SD or PB crossmember. The most you will be able to lay is the bottom of the crossmember and the control arms.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 Last edited by ruffrida2005; 11-19-2009 at 10:57 PM. |
11-19-2009, 11:13 PM | #37 |
Re: air bag kit!
dang and i just dont have a welder
11-19-2009, 11:43 PM | #38 |
Re: air bag kit!
It's a lot of work to get them to lay out, but it's well worth it.
11-20-2009, 03:38 AM | #39 |
HaV0KSR559<~~~
Re: air bag kit!
Yuppp im still in the process of learning to do it myself the only thing keepin me back is i have no welding skills what so ever but getting these beautys to lay frame is just simply sick
...1969_CUSTOM_1O
FLEETSIDE_LONGBED V8_THREE-FIFTY [COMPLETE-EDELBROCK] [PERFORMANCE-SERIES] [CAM_CARB_MANIFOLD] ...TURBO-400_TRANNY... |
11-20-2009, 09:38 AM | #40 |
Re: air bag kit!
is the brother c-notch good to go with?
or what would u recomend? |
11-20-2009, 09:47 AM | #41 |
On the path to financial ruin!
Re: air bag kit!
Here are some pics of Nathan's newest kit I just bought. It's an awesome setup. I can't wait to get it installed. But, like you said, you don't want to spend too much money and it ain't cheap. Nevertheless, it is well worth the money though. See the link below of my post with dropmember pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=371821
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 Last edited by 68jewel; 11-20-2009 at 09:49 AM. |
11-20-2009, 10:42 AM | #42 |
Happy to be here
Re: air bag kit!
Check these sites-
Early Classic Enterprises Porterbuilt Summit Racing Forum Suspension Forum Forum Review Board
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-20-2009 at 10:42 AM. |
11-20-2009, 11:23 AM | #43 |
Re: air bag kit!
Yeah boyeeee!!!!! Got my dropmember. here it is!!!
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
11-20-2009, 02:00 PM | #44 | |
Re: air bag kit!
This is with 225-60-15s, c-notch, 1.5" blocks and 1.5" drop spindles: |
11-20-2009, 06:52 PM | #45 |
Re: air bag kit!
thats a good setup i like!
whats the setup on the second pic? |
11-20-2009, 07:16 PM | #46 |
Re: air bag kit!
I think it's the same setup with the exception of the rear track bar. The CPP bar allowed a little more rear drop on the pass side than the ECE with a notch.
11-20-2009, 07:58 PM | #47 |
Re: air bag kit!
so whats the best way to cut the frame when doing the bolt in notch?
and im noticing everyone saying take off the rubber bumps on the notchs? but wont that mean notch to frame or axle or what ever its called? |
11-20-2009, 08:32 PM | #48 | |
Re: air bag kit!
Here's a good c-notch tech article. http://www.classicperform.com/tech_a...ch/c-notch.htm You can use a sawzall, plasma cutter or die grinder, (with a cut-off wheel), to cut out your notch.
11-20-2009, 08:35 PM | #49 |
Re: air bag kit!
ok i have that stuff but what im saying is i one guy told me to take off the bump stop, is that better?
11-20-2009, 08:48 PM | #50 |
Re: air bag kit!
The factory rear bump stops are long gone when you want to get that low.
