12-01-2009, 01:58 PM | #26 | |
Re: Installing a T-56
12-01-2009, 03:10 PM | #27 |
On the path to financial ruin!
I agree with you totally...some blocks can, some can't. An owner also has to know what shape their block is in to know if it can handle it. And unless you know your machine shop guy pretty good, most will just do the bore just as you asked and send the block right on out the door. Now todays aftermarket blocks can handle a .60 bore with no problem because they are built with thicker cylinder walls.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 Last edited by 68jewel; 12-01-2009 at 03:11 PM. |
12-01-2009, 03:59 PM | #28 |
Location: Sunny, Florida, some might call it South Alabama
Thank you guys for your advice. My block is a newer one piece rear main seal block. My machinist assures me that it will be no problem and I will address that again when i drop the block off at the machine shop. So no one has anymore experience or information about installing a T-56 into a C-10?
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
12-01-2009, 04:48 PM | #29 | |
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 Last edited by 68jewel; 12-01-2009 at 04:59 PM. |
12-01-2009, 05:24 PM | #30 |
Called them and they are supposed to call me back.
12-01-2009, 06:31 PM | #31 |
They are very knowledgeable and have a great tech support team. They can help you from beginning to end on your install.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 Last edited by 68jewel; 12-01-2009 at 06:31 PM. |
12-01-2009, 06:50 PM | #32 |
Definitly subscribing to this. I plan on doing this in the future.
12-01-2009, 08:31 PM | #33 |
x2 I'm on the subscribing list
12-02-2009, 01:35 AM | #34 |
motor exploder
i don't have a T56, but I do have a TKO 500, and had to fab up a hydraulic clutch and the shifter is pretty far back on the TKO, but not as far back as the T56. Here's a link to a thread with some pics in it.
http://67-72chevytrucks.com/vboard/s...d.php?t=364326
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
12-02-2009, 10:04 AM | #35 |
Isn't there a place that you can move the shifter to on the t-56? I think I read something about it before but now I can't seem to find anything. But on the transmission there is a plate about a foot up from the stock location of the shifter plate, I was wondering if that was an optional shifter location.
12-02-2009, 10:43 AM | #36 | |
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
12-02-2009, 12:20 PM | #37 |
Deleted
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. Last edited by smoky02; 12-02-2009 at 12:21 PM. |
12-02-2009, 12:21 PM | #38 | |
12-02-2009, 05:41 PM | #39 |
Would I have to remove my bench seat? Or is there a shifter that would fit around it? Or is there another style seat I can use that is still considered a bench with a little more clearence?
12-02-2009, 06:24 PM | #40 |
motor exploder
i flipped my shifter around on the Tremec and ordered a Hurst stick for a bench seat car. I'm pretty sure that the shifter is even farther back on a T56, but don't quote me on that. Even with mine the way it is, it's pretty close to the seat in 2, 4, and R. I'm sure any vendor that sells T56's or TKO's will be able to tell you how far back or what the difference is.
not sure about another bench style seat that would clear a T56. Jeg's sells a bunch of different Hurst sticks, that's where I got mine. I looked up the dimensions on Hurst's website and did some measuring from my floorpan to the seat and just found something that was close enough.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 12-02-2009 at 06:26 PM. |
12-02-2009, 06:36 PM | #41 |
That makes good sense...thanks...
12-02-2009, 06:39 PM | #42 |
Finally found this. There is a way to move it forward. I am not sure how tough it is...
http://67-72chevytrucks.com/vboard/s...d.php?t=300892
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
12-02-2009, 07:02 PM | #43 | |
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 Last edited by 68jewel; 12-02-2009 at 07:02 PM. |
12-02-2009, 07:08 PM | #44 | |
12-03-2009, 11:21 AM | #45 | |
12-03-2009, 01:26 PM | #46 |
I looked at mine again last night and I think for it to work right I will need to move this forward but I am not sure it is something I want to tackle and chance messing up my 1000 dollar transmission. Good luck with yours.
Dave
12-03-2009, 03:57 PM | #47 |
I'm calling a few of the tranny shops around here and see if they can do it.
12-20-2009, 07:51 PM | #48 |
did anybody get a quote on the t56 magnum yet? It's sunday and long ways down the road for this install but just curious.
12-21-2009, 02:19 PM | #49 |
I got mine from Jegs for $2795. Forgot how much freight was, but I think it was around $120 shipping. No tax because of out of state.
01-27-2010, 11:02 PM | #50 |
What questions did you ask them? Did they get back with you? I'm hoping to be able to just buy the parts I need from them.
Thanks for any updates on your trans project... Dan |
