Old 11-30-2011, 07:49 AM   #26
AUSSIE54
AUSSIE54's Avatar
Re: 1948 Chevy / S10
Very neat Shannon, great stuff man!
Regards,
Trently.
AUSSIE54 is offline   Reply With Quote
Old 11-30-2011, 10:04 PM   #27
xpickup
xpickup's Avatar
AUSSIE54, Thank you.
Well I was on a mission tonight. I blanked out the floor panels tonight along with the fire wall and the rear inner cab corners. What I would do without my trusty plasma cutter and the 4 1/2 grinder with a cut off wheel got everything done in 2 hrs. Should be able to start bead rolling the panels in and have it welded in by the end of the weekend. I will then work on the back tranny tunnel and roll it. I can not do the front removable one until I do the fire wall. I am waiting for the brake booster setup then I will start on the fire wall and toe boards. Here are some pictures.
Shannon
xpickup is offline   Reply With Quote
Old 11-30-2011, 10:14 PM   #28
Atommik
Atommik's Avatar
Shannon, how much clearance do you have between the floor braces and top of the frame? I'm hoping to not need a driveshaft tunnel or a trans tunnel (turbo 350). I'm planning on using the cab mounts from Jeff's 51 ( plans he posted). Also as far as building a bed... did you use 16 ga. for the stake pockets also? Are they plug welded in and then capped off from the out side? I've got a really nice spot welder at work that should work well for that.
Thanks,
Atommik
Atommik is offline   Reply With Quote
Old 12-01-2011, 12:00 AM   #29
oldman3
oldman3's Avatar
Shannon, just caught your new build thread today. Don't know how I missed it earlier. Everything is looking good. I love the body pieces you make for the cab line, super job. Will be watching this one real close. Will also be waiting for the panel thread....Jim
oldman3 is offline   Reply With Quote
Old 12-01-2011, 07:35 AM   #30
xpickup
xpickup's Avatar
Atommik, I think it is like 4". Mine are based off of Jeff's 51 but I used 3" x 3" 3/16 wall tubing. I have used 16 gauge for the stake pockets. I made a template and cut them out with my plasma cutter. I put the bend on the inside to smooth them out. I plug weld them. I have also used 2" x 4" box too. I like the box the best. After they are welded on I cap the outside on. I use 1 1/2 box for the frame work. I then use aluminium angle for the board hold downs. I drill them all and weld a nut on in the inside if the stake pockets , that is way I cap them last.
oldman3, Thank you. The panel thread will be coming soon. It was good seeing your son on here now. I really like his truck too. I will be watching his build. You guys do great work.
Shannon
Old 12-01-2011, 01:40 PM   #31
BBEEP
Junior Member
BBEEP's Avatar
Wait a second, is it the pic, or is the panel grill wider . . .?
BBEEP is offline   Reply With Quote
Old 12-01-2011, 02:39 PM   #32
xpickup
xpickup's Avatar
BBEEP, It has to be the picture. It is a aftermarket replacement. It does look wider though. There you go there is another modification you could do. Haha. Yours is coming along great.
Shannon
Old 12-01-2011, 03:49 PM   #33
BBEEP
Junior Member
BBEEP's Avatar
OH! Its a Chevy, mines a GMC hahaha
Old 12-01-2011, 09:40 PM   #34
xpickup
xpickup's Avatar
Started doing the paneling tonight. I did 3 out of the 4 pieces. I have one more to panel and then I have to do some 1/4" beads and then drill my holes for the plug welds. Weld the floor in and then the rear tranny piece. As you can see I had my little helper with me. He talked all day about helping his dad in the garage. Yep, another car nut!
Shannon
Old 12-01-2011, 10:19 PM   #35
oldman3
oldman3's Avatar
Shannon, panels look real nice. Cute little helper you got there, keep him busy.....Jim
Old 12-02-2011, 06:30 PM   #36
xpickup
xpickup's Avatar
I now have all the paneling done except the 1/4 beads. I also have to roll the tranny tunnel. Next is to drill all the plug weld holes. So I should have them welded in this weekend. Here are the latest pictures.
Shannon
Old 12-02-2011, 09:17 PM   #37
cleanshaven84
cleanshaven84's Avatar
I'm liking to floor pan. I'm going to be building mine as well and if I'm good enough, maybe santa will bring me a bead roller. What thickness did you use for the floor?
1949 GMC Pickup
Project "No Time '49"
Currently working on S-10 chassis swap.
Philippians 4:13 - "I can do all things through him who strengthens me."
cleanshaven84 is offline   Reply With Quote
Old 12-02-2011, 09:35 PM   #38
Kabwe
Certified Car Nut
Kabwe's Avatar
Shannon,
As always everything is looking top notch. Keep up the good work.
Kabwe is offline   Reply With Quote
Old 12-03-2011, 08:39 PM   #39
xpickup
xpickup's Avatar
cleanshaven84, You better be good because santa is watching. I used 18 gauge for the floors.
Kabwe, Thank you.
I got the tranny tunnel rolled this morning down at my buddies house. He has a 4' slip roll. I am working on a 29 Ford sedan down there right now . I put a Heidt's IFS in it which lead to a whole bunch of other changes! Fix one thing that creates 5 other problems. So I came home to see how it looked. It needs a little trimming but looks great.
Shannon
Old 12-03-2011, 10:34 PM   #40
cleanshaven84
Looks awesome. Can wait to see it all buttoned up.
1949 GMC Pickup
Old 12-03-2011, 11:34 PM   #41
oldman3
oldman3's Avatar
Shannon, like the way this floor is coming together.....Jim
Old 12-04-2011, 06:13 PM   #42
xpickup
xpickup's Avatar
oldman3, cleanshaven84, Thank you.
Had a good day. Worked early this morning and then had family pictures taken and the went back out and I got a lot done. I now have the floor pans welded in except the rear tranny tunnel. That will be this week. And then the fire wall. I got the brake booster assembly this weekend.So I can start on doing that. Here are some pictures.
Shannon
Old 12-04-2011, 08:04 PM   #43
oldman3
oldman3's Avatar
Sweeeeet....Jim
Old 12-06-2011, 12:22 AM   #44
bustac
bustac's Avatar
Nice looking floor!
1947 5 Window bagged S-15 frame
5.3 w/4L80E
1960 Apache LS Swap
5.3 w/4L80E
bustac is offline   Reply With Quote
Old 12-06-2011, 07:34 AM   #45
xpickup
xpickup's Avatar
oldman3, bustac, Thank you.
I should be able to start on the fire wall next week. It is going to get paneled too. I also am going to recess the brake booster a little. Other than that it will be smooth.
Shannon
Old 12-06-2011, 09:09 PM   #46
BlueJeep
BlueJeep's Avatar
So the rolling the driveshaft tunnel didn't screw up the beading? Can you explain how that works for those of us who haven't done that? Looks great!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-07-2011, 12:01 AM   #47
blitz'd
vintage car junkie
blitz'd's Avatar
That floor is way too nice looking to cover up!
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 12-07-2011, 07:11 AM   #48
AUSSIE54
AUSSIE54's Avatar
Blitz'd is right Shannon.
Old 12-10-2011, 07:45 PM   #49
xpickup
xpickup's Avatar
BlueJeep, blitz'd, AUSSIE54, Thank you, I paneled it the way that I did all the others. I then put it in the slip rolls and rolled it. Believe it or not it did not smash the paneling. I seen it done before and thought I would try it. I know what you mean it is to nice to cover but it adds a lot of strength to the floor.
Shannon
Old 12-18-2011, 08:09 PM   #50
xpickup
xpickup's Avatar
Boy it seems like a while since I last posted. I have been super busy at work and with the holidays coming up. But today I got a lot done. I cut out the rest of the firewall, built the recessed booster panel, made the firewall and the foot boards and then fit everything and tacked in place. Fire wall turned out great, Next is to make the inner cowl panels and the removable tranny cover. The booster bracket needs some more supports too. Then the steering column. Here are some pictures.
Shannon
