Old 04-22-2013, 03:24 PM   #26
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: Need 1/8" Pipe thread temp sender compatible with stock gauge
Here is a pic of my gauge after driving 30 mins with occasional tire and passenger squealing
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 04-22-2013, 03:26 PM   #27
cjohnson6772
cjohnson6772's Avatar
Any idea what the ecm temp is?
cjohnson6772 is offline   Reply With Quote
Old 04-22-2013, 03:28 PM   #28
chuckmc8
chuckmc8's Avatar
I don't even know what the ecm is
Old 04-22-2013, 03:29 PM   #29
cjohnson6772
Sorry pcm: powertrain control module. Computer.
Old 04-22-2013, 03:32 PM   #30
chuckmc8
chuckmc8's Avatar
Is there a way to tell? I don't have any type diagnostic equipment.
Old 04-22-2013, 03:35 PM   #31
cjohnson6772
You would need some form of obd2 connection. Scanner. Or cheap Bluetooth dongle.
Old 04-22-2013, 03:37 PM   #32
chuckmc8
chuckmc8's Avatar
Hmmm...I have a scanner. Do these normally read engine temp?
Old 04-22-2013, 04:13 PM   #33
cjohnson6772
I believe it should. Something like ECT. Engine coolant temp
Old 04-22-2013, 05:09 PM   #34
Daaaanz67
Hey guys that's where my gage reads also. On my scanner the ect reads 197/198. Thats the original sender on the end.This is my funky setup from street and performance. Never liked it from day one, the threaded piece that screws into the head is real thin and when I was screwing it in thought I was going to snap it. If this thing gets hit accidently on the head i could see it breaking off. Think ill change it out to the one on this thread
Daaaanz67 is offline   Reply With Quote
Old 04-22-2013, 09:45 PM   #35
coyotes33
coyotes33's Avatar
I accidentally broke mine when it was installed. Good thing I was able to remove the piece with the threads.
coyotes33 is offline   Reply With Quote
Old 04-22-2013, 10:17 PM   #36
Daaaanz67
Your lucky that piece is a real piece! That's why I'm going to change it out. Almost afraid to change it out though afraid it might break.
Old 04-23-2013, 06:11 AM   #37
chuckmc8
chuckmc8's Avatar
Dan, Are you using stock truck exhaust manifolds?
Old 04-23-2013, 09:20 AM   #38
coyotes33
coyotes33's Avatar
Looks like he might be using the TBSS manifolds, same ones i'm using.
Old 04-23-2013, 10:00 AM   #39
chuckmc8
chuckmc8's Avatar
Is that Trail Blazer SS? Can you post a pic of the manifolds? I am gathering pics to make a engine swap thread. I am using truck manifolds, but they have a few issues, so I am looking for inexpensive alternatives
Old 04-23-2013, 10:11 AM   #40
Daaaanz67
This is what I'm using fit tight against block and don't make any crazy bends when they dump out the bottom. Also ceramic coated inside out.
Old 04-23-2013, 10:12 AM   #41
coyotes33
coyotes33's Avatar
Yes, this is the only pic i currently have. Ill take some once i get home, i ordered them from GM Parts Direct, part #12600526, $50.94 and 12600527, $48.27
Old 04-23-2013, 03:09 PM   #42
chuckmc8
chuckmc8's Avatar
"I just tapped the passenger sides head to fit my autometers slightly larger sender size."
Kurt -
Kurt, Can you post a pic of your temp gauge at normal operating temp with the factory 67-72 sender in the 5.3? If so, we can compare it to the normal temp needle position on mine with the autometer sender.
I am running a 4 core 1972 GM radiator with the factory shroud and the mechanical fan that came on the 2003 5.3
Old 04-23-2013, 03:56 PM   #43
Daaaanz67
Chuck I thought you were using the auto meter 2277 and 2259 why the change if you don't mind me asking.
Old 04-23-2013, 04:56 PM   #44
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Kurt -
I have a genIV 6.0L and AutoMeter gauges. I'm not using much that "was" factory. Here's the only pic I have of my "auto meter sender" and location.
Between water heater hoses, just above header pipe. Notice "blue" connector.
my temp gauge stays at 180 or just left of...which is almost straight up.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-23-2013, 05:35 PM   #45
Daaaanz67
Oops read that wrong sorry chuck
Old 05-01-2013, 03:00 PM   #46
AMERICAN PICK-UP
GOOD info.
AMERICAN PICK-UP is offline   Reply With Quote
Old 05-03-2013, 09:03 AM   #47
5150
C10 Club Tennessee
5150's Avatar
Good info, Chuck. I just bought both adapters off of ebay for $27 shipped to the house. Much more easier then having to drill.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 05-03-2013, 01:48 PM   #48
bohmankid
bohmankid's Avatar
I can vouch that these adapters work for a 1979 silverado water temp gage.
bohmankid is offline   Reply With Quote
Old 07-26-2013, 06:22 AM   #49
chuckmc8
chuckmc8's Avatar
Looking to update this thread with new info- Anyone using the autometer sender and factory gauge that has access to diagnostic equipment to post the actual temp (degree #) that corresponds with the gauge? (see where mine runs normally in post #42) It would be nice to have a number that corresponds with this sender and factory gauge.
Old 07-26-2013, 08:59 AM   #50
solidaxel
solidaxel's Avatar
I am still a few months from testing with my Inferred, but I think this is the combo that I am going to use on my 78.
One more item to check off the to do list!
Did I miss the ebay site for those parts to use the stock sender from my 350?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
