Old 03-05-2013, 07:30 AM   #1
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Need 1/8" Pipe thread temp sender compatible with stock gauge
2003 5.3
1971 Blazer
Autometer 2277 adapter-goes into head on pass side and has 1/8" thread port for sender----1/8" NPT Female to M12x1.5 Male
http://www.autometer.com/cat_accesso...il.aspx?vid=61
What I am looking for is a 1/8" sender that will screw into the adapter and be accurate for the stock Blazer gauge. The Autometer site sez
"If using with a Short Sweep Electric Temperature gauge, sender #2259 is also required."
http://www.autometer.com/cat_accesso...il.aspx?vid=33
Will this sender correctly operate the factory gauge? If not, Autometer sells others or another 1/8" sender might work. Anyone know?
I am not looking for other alternatives such as drilling and tapping the head- I only want to now about a sender--Thanks!
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-05-2013, 10:15 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Need 1/8" Pipe thread temp sender compatible with stock gauge
I just tapped the passenger sides head to fit my autometers slightly larger sender size. Magnet, some grease, and a lot of care to pull the metal out of the hole while drilling. Factory sender is in the drivers side head for the efi...so yes I have 2 senders!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-06-2013, 10:43 PM   #3
69CST6.0
What was the magnet for? Did it do a good job. Jk That is a really good tip and I probably will use it.
69CST6.0 is offline   Reply With Quote
Old 03-07-2013, 07:01 AM   #4
68fixeruper
68fixeruper's Avatar
Here is what i did.
68fixeruper is offline   Reply With Quote
Old 03-07-2013, 07:19 AM   #5
chuckmc8
chuckmc8's Avatar
[QUOTE=69CST6.0;5931962]What was the magnet for?
The real question is, what does a magnet do to aluminum shavings?
Anyone know where I can find out about compatible 1/8" senders to the 1971 gauge?
Old 03-07-2013, 09:10 PM   #6
71chevystep4x4
71chevystep4x4's Avatar
I'm using #2259 on my 71, and everything seems to be working fine. I got the Idea from others using it as well, and never noticed that it said only works on 95 and newer guages until I read the link you posted.
71chevystep4x4 is offline   Reply With Quote
Old 03-07-2013, 11:25 PM   #7
solidaxel
solidaxel's Avatar
What does Street and Performance have to offer?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-08-2013, 09:44 AM   #8
Robznob11
Robznob11's Avatar
I bought a aluminum pipe off ebay that was tapped for a stock sender. Cut the upper radiator hose and installed it ofchorse i dont see temp till the thermostat opens. But its the cheapest way. And you can always find a sender or gauge to work even cheap auto store gauges. I know that if i dont see temp with in a few min of driving i would have to have a stuck thermostat. Lol the puter monoters temp to and if the engine gets to hot it will attempt to cool it with extra fuel makeing the thing run real funny!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-08-2013, 03:04 PM   #9
68GMCCustom
[quote=chuckmc8;5932413]
I guess I was thinking of tapping something else....a different metal obviously.
Kurt -
Old 04-08-2013, 05:47 PM   #10
chuckmc8
chuckmc8's Avatar
Just to update this thread with a conclusion- The autometer 2259 and the autometer adapter was the ticket- no drilling and threading and the factory gauge works like new. Thanks for the help.
Old 04-09-2013, 11:15 AM   #11
G8DAN
G8DAN's Avatar
So with those 2 autometer products you were able to use the factory gauges and not have to do any extra drill and tapping?
G8DAN is offline   Reply With Quote
Old 04-09-2013, 12:20 PM   #12
chuckmc8
chuckmc8's Avatar
Yup, that's the deal. Here is installed pics. Just hook up the green wire that went to the factory sender.
sorry for the tilted pics-it's just beyond me
Old 04-09-2013, 02:57 PM   #13
G8DAN
G8DAN's Avatar
Thanks man! This helped striaghten out some questions I had about the temp gauge.
Old 04-10-2013, 10:26 PM   #14
cjohnson6772
cjohnson6772's Avatar
Thank you for the follow up. Any idea why the link says 1995 and newer? I'm not doubting you. Just curious what the significance might be.
cjohnson6772 is offline   Reply With Quote
Old 04-11-2013, 12:03 AM   #15
solidaxel
solidaxel's Avatar
Have you checked the engine and radiator with a I/R gun to see if they ate reading the same?
LS 3 4L70E
Old 04-11-2013, 05:39 AM   #16
chuckmc8
chuckmc8's Avatar
Beats me
Old 04-11-2013, 05:50 AM   #17
chuckmc8
chuckmc8's Avatar
Smile Re: Need 1/8" Pipe thread temp sender compatible with stock gauge
I don't have an I/R gun, but that would certainly be worthwhile. Since the gauge doesn't have numbers, you are just in a 'range' anyway. In my 50 years of roddin', after I drive and open the hood, I can lay my hand on the radiator (if just for a second) and pretty much tell if its too hot or not. My 5.3 runs in the lower portion of the 71 temp gauge scale, and it is close in my personal experience method. Still, not something to guess with, but I am through with it and moved on to something else ;-)
What the gauge gives you is a 'normal' baseline anyway. Once that is established, the gauge just lets you know that something is amiss.
if anyone installs this sender and adapter and has access to an I/R gun, please post the results to seep this thread updated, since this is valuable info for swappers.
If anyone would like to send me an I/R gun or a gift certificate, please PM me for addy
Old 04-11-2013, 01:00 PM   #18
bohmankid
bohmankid's Avatar
Thanks chuck. This will help multiple people, including me.
bohmankid is offline   Reply With Quote
Old 04-17-2013, 10:39 PM   #19
cjohnson6772
In case anyone is interested...... here is the resistance vs temp chart for both the 2258 and 2259 sender
Old 04-17-2013, 11:50 PM   #20
Daaaanz67
This is great info thinking of converting to this setup. I'm currently using one of street and performance adaptors and the original sending unit my tuner says its not reading correctly because the adaptor is so long and the water is not constantly moving cross the sender.
Daaaanz67 is offline   Reply With Quote
Old 04-18-2013, 09:48 AM   #21
solidaxel
solidaxel's Avatar
Just thinking, if the brass sits long enough in the aluminum head with the water passing next to it "should" come up VERY close to the same temp, even if it is not in direct contact with the water.
LS 3 4L70E
Old 04-18-2013, 09:55 AM   #22
solidaxel
solidaxel's Avatar
Thanks I need that for another mis reading temp gauge I am working on.
Now how do I get it to read from 230* down to 180*
LS 3 4L70E
Old 04-18-2013, 09:24 PM   #23
TR65
TR65's Avatar
I put cjohnson6772 data on my temperature sender data. Doesn't exactly match either the 60-66 GM sender or the late model GM sender but it is closer to the late model one.
I have yet to find a sender in small size that works for the 60-66 stock gage. (The late model sender overheats from high current and pegs the stock gage at any water temperature.)
The attached file gives a bigger picture.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 04-18-2013, 09:41 PM   #24
cjohnson6772
TR
Thanks for putting that on the chart! Gives a good graphical way of seeing the relationship. I believe you could use the autometer sender and a 75 ohm resistor in parallel to the gauge to get it "pretty close".
Also: if I=V/R wouldn't the late model gauge have less current? (Constant voltage and greater resistance?)
Old 04-19-2013, 09:25 PM   #25
TR65
TR65's Avatar
I think the 60-66 sender sees a higher voltage from the gage thus increaseing the current. As the sender puck self heats from the current the resistance drops and the current increases leading to a runaway and the gage pegs in a minute or two.
TR
1965 C10 SWB Fleet
Two owner
