Old 04-02-2013, 05:28 PM   #26
BurnoutNova
BurnoutNova's Avatar
Re: New master and now no power brakes
A 1 1/8" bore is not typically used for disc brakes. I don't think that was the problem. Maybe they gave you a drum/drum prop valve. I would start by checking the fluid pressure at the calipers. Should be between 800-1200 psi.
BurnoutNova is offline   Reply With Quote
Old 04-02-2013, 05:41 PM   #27
lolife99
67-72 parts collector,…
lolife99's Avatar
Drum/drum set ups have a distribution block, not a proportioning valve.
The 71-72 M/C with a booster had a 1-1/8" bore.
Keith
Convert to disc brakes.
Old 04-02-2013, 06:56 PM   #28
nds1968
nds1968's Avatar
That's why I will only use aluminum M/C's from now on.
No painting that will eventually rust anyway.
I painted my '69 M/C with cast look caliper paint,... but now it's starting to look like crap.
(with almost no miles on the truck)
Do you know where to buy a stock looking aluminum M/C other than from PICKMUP? Thanks, Nate
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 04-02-2013, 07:17 PM   #29
lolife99
lolife99's Avatar
http://www.speedwaymotors.com/Alumin...nder,8905.html
http://www.performanceonline.com/Dis...h-Performance/
http://ssbrakes.com/i-10092246-maste...-aluminum.html
Keith
Old 04-03-2013, 06:34 PM   #30
shawno72
C/10 junkie
shawno72's Avatar
Well I replaced the master with the 1 1/8 bore master and the brake pedal is worse. The pedal stroke is better but overall it is a tad bit worse. I'm thinking that maybe the brake pads just need to seat in.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-03-2013, 07:16 PM   #31
shawno72
C/10 junkie
shawno72's Avatar
What would the symptoms be if I had a disc/disc prop valve?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-03-2013, 07:45 PM   #32
lolife99
lolife99's Avatar
Are you sure you have all the air out?
How much "free play" in the pedal?
(should be 1/8"-1/4")
Keith
Old 04-03-2013, 08:26 PM   #33
shawno72
C/10 junkie
shawno72's Avatar
Free play is about 1/4 or less. Nothing but clear fluid being bleed out. Really feels like maybe it needs a stronger booster? I don't know what to do.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-03-2013, 08:30 PM   #34
shawno72
C/10 junkie
shawno72's Avatar
Even though I bought my prop valve from CPP the only markings on it are "PM" One I had before had the correct part number PV2.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-05-2013, 11:57 AM   #35
BurnoutNova
The rear drums would want to lock up, as the self energizing drums require much less pressure.
A 71/72 prop valve should deliver more pressure to the front calipers than to the rear line. A drum/drum "metering block" is just going to deliver straight line pressure to all 4 wheels.
Old 04-05-2013, 11:59 AM   #36
BurnoutNova
I would put that 1" bore master back on, and then check your actual pressure at the caliper. If it is 800-1200 psi you can assume the pads need to seat in, or maybe the rotor finish is really bad and the pads are glazed over.
Old 04-05-2013, 12:18 PM   #37
shawno72
C/10 junkie
shawno72's Avatar
I have a brand new aluminum 1" bore MC and brand new aluminum disc/drum prop valve ordered. I'll post updates once installed. Thanks for all the help. It's funny cause the brakes are feeling a tiny bit better each day......or I'm just getting used to them
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-11-2013, 11:10 AM   #38
cericd
cericd's Avatar
Hey Shawn, any updates on the brake issue?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 04-11-2013, 11:12 AM   #39
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
x2
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 04-11-2013, 11:13 AM   #40
Longhorn 70
Longhorn 70's Avatar
Yeah Shawno.... What's the news. I ask because mine feel like they are getting worse each day! It now feels like my pedal is bottoming out the M/C in the bore.
Maybe I got a bad M/C
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 04-11-2013, 11:47 AM   #41
shawno72
C/10 junkie
shawno72's Avatar
Well guys I got an aluminum master that will go on Saturday, I re adjusted the rear brakes nice and tight and the pedal has been fine. I still think the new master with the 1" bore will be the cats meow. I'll update you guys on Saturday.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-17-2013, 12:50 PM   #42
nds1968
nds1968's Avatar
hey shawn, any updates on the brake issue?
x2
Nate
Old 04-17-2013, 03:48 PM   #43
shawno72
C/10 junkie
shawno72's Avatar
Sorry guys been super busy at work so no new master installed yet. Ever since I re adjusted the rear brakes they hav been fine so I am a little hesitant to swap on the aluminum master for fear they may be worse
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-17-2013, 06:12 PM   #44
Longhorn 70
He who dares wins!
Old 04-17-2013, 06:34 PM   #45
knomadd
knomadd's Avatar
Hey Shawn, have you ever checked how much vacuum your truck is producing? Do a simple vacuum test and see if your in the 18"-22" range. If you're below 18" of vacuum, you won't have enough to operate them on a vacuum booster as well as you would expect. They will still work, but just like you're explaining.
When I had this problem with my GTO, I thought I had bled the system pretty well, but wound up paying a shop to pressure bleed my brakes and they were able to get more air out, which helped but still didn't get it to where my drums were. I found out that I didn't have enough vacuum to operate the typical vacuum booster so I switched to hydraulic.
Do a vacuum test so you can at least rule that out. I'm curious if your next swap will fix your problem. Good luck!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
