#26 |
Re: Improved Door Seals
About 2 years ago if you would have to me that having all the windows up and the cab as sealed as it was from the factory that if you shut the doors they would compress the air in the cab enough to fight the doors from closing I probably would have answered "yeah.. Sure" but I've noticed on my 67 if roll down the windows I can "gentle one finger close" the doors no problem. But if I roll the windows up it is not possible. Unless your finger is green, really large and you where purple shorts. Now I know that the latch and door adjustment in accordance to the latch makes a big difference in the way the door shuts, but I noticed in 67, there was no ventalation of any sort besides the kick panels. There wasn't any hard lines running in or out of the cab to the charcoal canister, or a door jamb vent like they had in the 72's. But I have installed a door jamb vent in my 67 and it has made the doors much easier to shut. Long story short have any if you guys come to realize this and found ways to make the doors shut real nice?
#27 | |
#28 | |
Still Learning
#29 |
![]() Join Date: May 2010
#30 |
My doors shut with half the effort of a new car, but i havent replaced the seals yet.
#31 |
For some odd reason , my doors shut quite easily......
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#32 |
I know I'm the one that mentioned cabin pressure as an explanation. Is it just mine, or do all of our trucks have an opening on the bottom rear of the cab (by cab corners). Are those areas supposed to be open like that or should there be something covering the openings? If they were sealed, I'd think shutting the doors would be near impossible to close.
project: "my happy mess" |
#33 |
![]() Join Date: Mar 2011
jus subscribin
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
#34 |
My dad did as well. His '71 shut with no effort at all and this was in the mid '80's. He would get after anyone that slammed them. I do the same with Stella and my son, now........the circle of life I suppose.
#35 |
2nd follow up question: Why do some dislike having to SLAM the doors shut? Do you think it hurts the doors or something other?
#36 |
#37 |
Please, feel free to elaborate your concerns. Why? My parts are 40+ years old and have no issues.
#38 |
Its tough on the mirrors, 1000 slams cant be good for the point where they mount. Eventually they will fail.. plus, I always have to readjust the side mirror after slamming the door. Why would anyone want to have to slam there door anyway, they didn't come from the factory that way...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#39 |
![]() Join Date: Apr 2010
I used Precision brand door seals after getting my truck done and had to slam the doors! I completely removed those and got Metro brand and now the doors shut great. I think if you spend the extra money, it will be worth it. I have also heard good things about Softseal too, just don't use the Precision brand for door to cab seal.
#40 | |
![]() I'm not sure what type of mirrors you have, but believe me - these mirrors were engineered to stay put, AND withstand being SLAMMED.
project: "my happy mess" Last edited by litew8; 11-16-2014 at 11:51 AM. |
#41 |
Not to mention that the interior door parts are all metal and quite delicate. Window regulators as well. The harder you slam the doors the more likely you are to loosen one of those parts up. I prefer an effortless 1 finger close.......I inherited that from my dad.
#42 | |
#43 |
My 68 would close the doors by itself just click. That was with old nasty seals. They do close now but you have to push them closed. I used new glue in seals from Tuckers (Precision). They are nice gluing isn't bad just remember you don't need that much. I used spring clamps to hold the seals tell the glue dried and never had a mess or problem. My drivers door closes better then then the pass door I still need to do some adjustment. I did notice when the door handles were off when I closed the doors that there was a lot of air coming out of the holes. This may be why they don't close well. I wonder if leaving the cowl vents open if this would help the air to escape?
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 Last edited by marvgarr68; 11-16-2014 at 02:44 PM. |
#44 | |
Still Learning
#45 |
Check out this this thread on door seal problems. http://67-72chevytrucks.com/vboard/s...=636778&page=2 I was having the same exact problem that Robert Bergstrom was having so I thought I would try the Metro brand out and they worked out great! The doors shut 100 times better. All trucks are not created equal and the Precision brand might work on some trucks but they didn't work on mine and the Metro brand did. I think the Precision seals are a little too beefy which is making it harder to close the doors. Air pressure in the cab is always going to be a problem or GM would not have put the door jam vents on 72 models, I think that was the 1st year for them? All I know is the Metro brand worked for me, hope this helps
#46 |
Awesome... Wish I had known there was better options before I put my all rubber OEM seals on.... They are total crap
#47 |
![]() --------------- Probably. As mentioned above, it's why GM put the doorjamb air vent on 72's. What does that tell everyone? Shutting the doors was always tight due to cabin pressure and your doors are supposed to be slammed shut. Like I mentioned above, if (non 72's) your doors close easily - the door is not sealing properly. Not rocket science. If your doors do not close at all - you have other issues.
project: "my happy mess" Last edited by litew8; 11-17-2014 at 02:53 PM. |
#48 | |
#49 | |
#50 |
Wow ;
Thanx for all the great replies ! ![]() Last night my Dodge Dakota seals from Steele Rubber Co. arrived , I'll drop them of to - night after work , along with another box full of window channels etc.
