11-11-2014, 11:43 AM | #1 |
Improved Door Seals
I forget , there are Dodge (Dakota maybe?) door seals that are better than the OEM '67 ~ '72 crappo seals .
Please re post what model and year they are to be found on . TIA ,
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
11-11-2014, 12:34 PM | #2 |
Re: Improved Door Seals
86-96 Dodge Dakota.
11-11-2014, 12:38 PM | #3 |
THANK YOU ! .
Off to Steele Rubber Co. I go........
11-11-2014, 10:30 PM | #4 |
I never heard about the Dakota door seals, Do they fit really well on a C10?
11-12-2014, 01:13 AM | #5 |
11-12-2014, 09:13 AM | #6 |
They have a metal lining so they hold better to the pinchweld .
I have ordered up a pair and will report back when I get them installed .
11-12-2014, 10:15 AM | #7 |
After three years of SLAMMING the doors, maybe I should try those !!! |
11-12-2014, 10:19 AM | #8 |
Interesting. Subscribed to hear the results.
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
11-12-2014, 10:48 AM | #9 |
I thought it was the Durango door seals. Probably could use either one.
11-12-2014, 10:54 AM | #10 |
I am a Referee of life.
I have a drivers side Dakota seal on mine. Very tight. I wanted something cheap and easy until I could do rockers. I also wanted the ability to remove/replace until everything was done and working the way I wanted. I'm living with it but it is quite a bit thicker than the original.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-12-2014, 11:53 AM | #11 |
Durango door seals won't work. They are a completely different animal. I actually looked at them when I was looking for door seals on my truck. Ended up using 88-98 chevy truck seals which work halfway decent but they are too wide and I have to slam my doors more than I would like. Will probably try some dakota ones later.
11-12-2014, 12:28 PM | #12 |
Our doors were engineered to be SLAMMED! It's a TRUCK
project: "my happy mess" |
11-12-2014, 12:47 PM | #13 |
Just to clear up any confusion about these seals AND the originals.
In the 45 years I've had my truck, the doors have always required a fair amount of effort/slamming to close. This was true to a somewhat lesser extent even after the original seals were mashed to almost nothing. To some degree litew8 is correct. The doors never did close with minimal effort and a nice solid satisfying thunk. My Dakota seals are from the junkyard. So, they are fairly well broken in. They fit great, but it does require a fair amount of effort to close the doors... almost like the originals. Maybe my truck was an outlier and others always closed beautifully. Maybe... |
11-12-2014, 01:00 PM | #14 |
So what is the actual advantage of changing the seals to there, other than not needing adhesive?
______________________ www.northeastrodrun.com |
11-12-2014, 01:11 PM | #15 |
I did it because they were dirt cheap from the junkyard, everyone was complaining about all the new repro seals out there, they don't require adhesive and they've received fairly positive reviews in other threads. Was worth a try. To me, the clip on feature is a big positive, and, as I said, the originals weren't great either. If I ever hear great reviews of some reproductions, I may try them.
11-12-2014, 01:21 PM | #16 |
Ease of installation, about 5 minutes per side, and no glue. I tried the no glue clip-ons, both the dodge and the repop that some vendors sell. They are thicker than the glue-ons and often require the door to be adjusted. On my truck, to get the door to close easily, even after many months, a lot of adjustment was needed. I went back to the glue-ons, boy what a mess, but they fit great, seal well, and the door gaps are correct. I know some folks that have the clip-ons and they fit well.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-12-2014, 01:24 PM | #17 |
I tried the Dakota seals (new) and could never get my door to shut. I gave up on them.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-12-2014, 01:37 PM | #18 |
Florida Edition
I have posted this before but it apparently didn't take.
The problem isn't the seals its the pinch weld they sit on. Before you put new seals on bend the pinch weld in just a tad with a paddle-nose set of vicegrips or a 2x and hammer. A very small adjustment is all it takes. With the push on type seal (Dodge) you can even fine tune the adjustment to your liking.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-12-2014, 02:28 PM | #19 | |
when I get tot his point (after the new year), I have no problem messing with adhesive, if that's the better fitting seal. I don't take the easy way out, just to save a bit of work, if that's not the best way. Thank you everyone, for the good advice...... or is it the more confusion? I'm not sure
11-12-2014, 02:59 PM | #20 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-12-2014, 07:54 PM | #21 |
Back in the late seventies, my friend who had a 68 50th anniversary, INSISTED that we close the door with a " gentle, finger, PUSH " until it went - click !!! ( of course, it was less then ten years old then and had the original door seals !!! )
11-12-2014, 09:04 PM | #22 | |
11-12-2014, 09:18 PM | #23 |
I have the push on seals from Paul's and my doors on the 68 shut very well, wish I had used them on the other trucks and will use again in future.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-12-2014, 10:26 PM | #24 |
I'd like to see that! When old (before restoring), mine never closed without effort, and I prefer it that way I think some of the reason for a solid shut - cabin pressure. As for the mess of glue on type, I don't get it. Sure, it isn't the nicest stuff to work with, but with 2 people it isn't bad at all if you take your time.
project: "my happy mess" Last edited by litew8; 11-12-2014 at 10:35 PM. |
11-13-2014, 02:38 AM | #25 |
Wanted to subscribe to this thread.
