01-15-2015, 08:39 PM | #26 |
Re: "Brass Monkey".....Installing 4/6" ECE Drop Kit
Super nice looking truck! I'll be doing a 2.5/4" ECE drop on mine, with similar size wheels and tires. It'll be interesting to compare their stance when they're done.
01-15-2015, 10:10 PM | #27 |
BEAUTIFUL TRUCK! I plan to do the same drop kit on my truck in the future as well.
Looking forward to seeing the final results on yours, good luck.
Current: 1970 C-10 350 long bed "The Mammoth" 1957 Belair 2dr HT, 283, Muncie M-21 Past:1931 Ford Model A PU, 1928 Ford Model A Business Coupe, 1949 Willys-Overland PU, 1953 Willys PU |
01-15-2015, 10:37 PM | #28 |
I'm not sure about the springs, I didn't think it would matter but I'm an amateur. I have the evil competitor's springs to install, but can't see a difference in direction. Mine are marked CPP on the lower coil tho so I plan to install with the letters right-side-up.
Hopefully someone will chime in to confirm so you can keep moving forward.... |
01-15-2015, 11:08 PM | #29 |
It doesn't matter about the springs. Just put them both the same way.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-16-2015, 08:45 AM | #30 | |
I am painting the retainers today at work and getting new bolts. Hopefully get them in tonight. Now if my back ordered lower spring mounts would show up then I can finish up the rear.
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
01-16-2015, 09:07 AM | #31 | |
EDIT: Found them, http://67-72chevytrucks.com/vboard/s...ring+retainers
02-01-2015, 02:02 PM | #32 |
02-01-2015, 02:23 PM | #33 |
Like the bottom pic is how mine is.
02-01-2015, 03:08 PM | #34 |
I'm just subscribing to this thread so I don't get fined (and it is totally awesome!)
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
02-01-2015, 04:42 PM | #35 |
Great thread and good pics - thanks for sharing your process. Wow - originally an olive interior - can't imagine, but proves the original buyer could get whatever they wanted in those days. Very cool. Truck looks gorgeous! Can't wait to see the final pics and I'm not even a big drop fan(!) Know it's gonna look awesome - this is a beautiful truck.
02-01-2015, 06:25 PM | #36 |
I was surprised to here back from ECE on a sunday. But this is the correct way to install the sway bar.
02-02-2015, 05:49 PM | #37 |
Sooooo cool. The color is a beauty.
02-02-2015, 05:52 PM | #38 |
Should i keep the rally wheels with a smaller tire?
Or go to a 20" TT2 wheel?
02-02-2015, 05:59 PM | #39 |
TT2's get my vote.
02-04-2015, 08:20 AM | #40 |
02-04-2015, 08:22 AM | #41 |
I only have1/4"-1/2" clearance on the front tires. Defiantly have to get a smaller tire, which also should gain anther 1"+ of drop.
02-04-2015, 08:25 AM | #42 |
Your truck looks great!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
02-04-2015, 10:01 AM | #43 |
Well done.
02-05-2015, 08:13 AM | #44 |
Are your rear springs ECE's 6" springs?
02-05-2015, 08:15 AM | #45 |
02-05-2015, 09:07 AM | #46 |
The truck looks very good with the drop! No C notch on the frame was necessary?
02-05-2015, 09:21 AM | #47 | |
The rear end is 2.25" from the frame rail. It is close but i will see how it works out before I do a C-notch.
02-05-2015, 09:52 AM | #48 | |
02-05-2015, 10:09 AM | #49 |
Truck looks awesome.
My leaf spring truck with a flip came down 7". I removed the factory bump stops as well as the steel pad that is on a leaf axle. (Never owned a coil truck other than a c20 Sub so not sure what they look like.) I put the DJM urethane bumps on the frame above the axle. They hit occasionally but not often enough to c-notch it. On your fronts, I'd look at a wheel with a different width/offset in addition to a narrower tire maybe? I have 27" tall tire on the front of mine (235 55 17) and with about 500 miles under my belt I have zero tire rubbing anywhere front or rear. And rears are 29" tall (275 55 17). Taller tires are one of the things IMO that really help the look and stance of these trucks lowered.
02-05-2015, 10:18 AM | #50 |
ECE recommended using a 245/60/15 on the front and a 275/60/15 on the rear. The wheels are 15x8.
Any thoughts on this? It currently has 255/70/15 all around
