#26 | |
![]() Join Date: Feb 2016
Re: Collapsible intermediate shaft?
I upgraded to a new steering box and installed with a new rag joint. I have to recheck but i think i cut and attached the new shaft. What makes this collapsible? Is it the u joint? I didnt do that |
#27 |
Moderator
![]() ![]() Join Date: Aug 2011
The shaft is the part that is collapsible on our truck IF you have a collapsible shaft.
#28 | |
So i guess i should swap the whole thing |
#29 |
I'm not sure when these were required as safety equipment but my steering shaft is from the mid-1970's. In the picture, I have put a white dot on the two shearable plastic pins that go through the two parts of the lower steering shaft. On impact, the plastic pins shear off and the outer shaft (which is a hollow tube) slides over the inner solid shaft.
If your shaft is welded or has the plastic pins replaced with metal bolts, it's no longer collapsable. |
#30 |
![]() Join Date: Jan 2011
Afirehawk yours is the stock shaft with the adapter on the end that comes with the power steering kits. This is a weld on process due to it not having a double D setup.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#31 |
#32 |
Since I upgraded with A newer power steering unit, which collapsible shaft does everyone use? I think i used a 72 or 78 unit; so i need to remove the rag joint and count the splines?
#33 |
Well, here's my plan ... which I hope to get going on right away, as soon as my truck gets back home from storage.
1966 GMC 910 pickup (Canadian 1/2 ton) Early 70's G-van tilt column (3/4"-36 spline) Jegs #607002 U-joint coupler (3/4"-36 spline to 3/4" DD) 1979 C20 collapsible intermediate shaft 1979 C20 power steering gear The goal is to cut that goofy OEM "bell" coupler off of the intermediate shaft, then insert the 3/4" DD directly into the Jegs coupler. I think it's going to be long enough to do that, but I did buy a length of 3/4" DD just in case. |
#34 |
That may work. On any adapter I use if it is not splined it gets welded or pinned. I do not trust the set screws.
Jimmy
#35 | |
Also be sure to re install the ground connector from the lower shaft to the steering box across the rag joint or your horn won't work. |
#36 |
I read on CPP website their collapsible shaft/ u joint is not recommended for stock columns.
So do we do? Im confused I have the 3/4, 36 spline gear box |
#37 |
Moderator
That's because you have to modify the shaft on the column.
#38 |
#39 |
Moderator
Pretty much what post 12 did on this thread. But by the way, if your not sure and wanting to do this yourself - Maybe you should get professional help on a something like steering and brakes. Your life depends on it.
#40 | |
Thanks |
#41 | |
The 72 C10 used a collapsible steering shaft. This swap has been done many times, and there are many ways to join the steering shaft to the power steering box. I’m hoping to complete my install within the next couple of weeks, so I’ll try to let you know if it goes according to plan. Posted via Mobile Device |
#42 |
I used the 1977 Chevrolet c10 power steering box
The input spline count says its 26 from Masterpro Suggestions then what intermediate shaft to use I dont think the CPP-1DD730 will work Thats a 3/4x30 spline unless im misunderstanding something Need some advise on this one, Thanks Last edited by Afirehawk1; 01-26-2021 at 09:09 AM. Reason: typo |
#43 | |
Van column (it actually has a 30 -spline output end) Jegs U-joint (30 spline on one end, 3/4”DD on the other end) Squarebody intermediate shaft with the top OEM coupler cut off Rag joint Steering box. Posted via Mobile Device Last edited by DonLeverton; 01-26-2021 at 10:38 AM. |
#44 |
so has anyone used a power steering gear box from late 70's (1977) C10?
the way i read the specs o the input shaft from MasterPro, there are 25 or 26 spline per their website. assuming that is not counting the flat spot on the shaft. Wanting to order the CSS-1DD730 by CPP which is the 3/4-30 spline. just want to verify this. |
#45 | |
![]() ![]() ![]() Join Date: Jan 2018
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#46 | |
![]() Join Date: Sep 2020
![]() Quote:
You will need a bearing or bushing in the end of the column tube as well..... Last edited by MT65; 01-26-2021 at 09:01 PM. Reason: More info |
#47 | |
The steering gear box has 25 splines showing. the flat spot on the shaft accounts for about 5. thus a 30 spline rag joint will work. i had to process this for a moment. |
