Old 10-19-2015, 09:30 AM   #26
Heavymetl
Re: Which oil pan?
I'm running an Fbody pan with a modified truck windage tray. My truck is fairly low, however the shallow fbody piece gives plenty of ground clearance and is well above the crossmember.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 10-19-2015, 08:59 PM   #27
GMJimmy
Re: Which oil pan?
Does anybody have comparison measurements or pictures to compare the F body and CTSV pans? If the CTSV pan is about the same as the Holley pan I may go with it instead.
GMJimmy is offline   Reply With Quote
Old 10-20-2015, 07:38 AM   #28
BigDan3131
BigDan3131's Avatar
Re: Which oil pan?
You guys can keep your factory pans I'm using the Moroso Pan: http://www.summitracing.com/parts/mor-20142 because it offers 7 quarts and the usual standard baffles and trap doors. I'm future proofed to build a big inch engine too.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-20-2015, 08:16 AM   #29
boostedc10
boostedc10's Avatar
Re: Which oil pan?
Here is the v pan
Here is the fbody
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 10-20-2015, 09:42 AM   #30
Hart_Rod
Hart_Rod's Avatar
Re: Which oil pan?
Which motor mounts/engine stands are you using?
Hart_Rod is offline   Reply With Quote
Old 10-20-2015, 10:09 AM   #31
Aruba1
Re: Which oil pan?
Won't the fbody create a possible clearing issue as it will be closer to the crossmember? I am at work right now but IIRC my oil pan is very close to the crossmember and my LS engine sits in the same place as the SBC. You can gain clearance if the engine sits a few inches back though.
Aruba1 is offline   Reply With Quote
Old 10-20-2015, 11:16 AM   #32
Hart_Rod
Hart_Rod's Avatar
Re: Which oil pan?
If you use the ECE LS swap mounts, the Fbody pan won't work because of the crossmember interference. That was the reason I switched to the CTSV oil pan. If you are using some slider mounts such that you can move the engine back, then the Fbody pan will probably work.
Old 10-20-2015, 10:14 PM   #33
GMJimmy
Re: Which oil pan?
Originally Posted by boostedc10 View Post
Here is the v pan
Here is the fbody
Boosted C10 Thanks for the pictures! That really helps! Hart_Rod I'm using transdap 4575 mount adapters and the stock C10 perches and mounts. It fits in there really good. The CTSV pan looks like it may be the one to go with but I need a part number. I don't want to be poking around the wrecking yards looking for this pan and trying to remove a good used one so I'll probably buy a new one at the dealer or from the aftermarket guys.
Old 10-20-2015, 10:24 PM   #34
boostedc10
boostedc10's Avatar
Re: Which oil pan?
CTS-V oil pan: Part#12605814
Oil pan Baffle: Part# 12611129
Oil pump pickup: Part# 12621299
Oil dipstick tube: Part# 12584737
Oil dipstick: Part# 12584738
Brandon
Instagram: DRVFSTR
Old 10-21-2015, 12:03 AM   #35
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Which oil pan?
I would recommend the Holley pan. It may be more money, but I love it. Just be sure of which one you need. I ended up installing the 302-1 at first and then found out I had an interference issue with my cross member and had to go to the 302-2. Fortunately, I was able to return the 302-1 to Summit. You need to understand though that my chassis is a custom chassis with rack and pinion. The 302-1 hit my rack and pinion and there was no way to know that ahead of time.
Don't be scared by the windage tray modifications either. They are no big deal. The 302-2 pan requires more windage tray modification, which I didn't want to do, so I bought the right windage tray (PN 12558253) from Summit for $24. The 302-1 windage tray mod is easy. If you go to Holley's web site they even tell you what windage tray you need and what oil dipstick to use. Lots of info at their web page.
Here is the comparison between the 302-1 & 302-1 pan. Also a picture of my LS3 with the 302-1 installed first.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 10-21-2015, 12:07 AM   #36
derotoreut
derotoreut's Avatar
Re: Which oil pan?
Here are pictures of the Holley pan install with windage trays. The first picture is of the windage tray for the 302-1. Second one is with the 302-2 windage tray.
The windage tray for the 302-2 needs to be cut, while the 302-1 has a minor mod around the pick up tube bolt. That's why I just bought the proper windage tray for the 302-2.
~ Dan
Old 10-21-2015, 12:10 AM   #37
derotoreut
derotoreut's Avatar
Re: Which oil pan?
You can see I had a clearance issue with my rack and pinion with the 302-1 by the first picture. I had to go with the 302-2 (2nd & 3rd pics) in order to get the proper clearance for my rack.
~ Dan
Old 10-21-2015, 12:21 AM   #38
derotoreut
derotoreut's Avatar
Re: Which oil pan?
Here's a couple pictures of my chassis and LS3 with the 302-1 installed. You can see I had a lot of clearance until I installed the rack and pinion. Again, I would buy the Holley pan. You will not be disappointed.
~ Dan
Old 10-21-2015, 07:43 PM   #39
GMJimmy
Re: Which oil pan?
I think I'm going with the Holley 302-1. I was thinking the 301-2 would be better for me because of the very shallow front end but I'm concerned about the 9.84 inch fore and aft length of the sump may hit my cross member. I think the 302-1 front depth of 2.42" and sump measurement of 7.65" should work in my truck.
Thanks everyone for the help! It really makes a difference!
Jim
Old 10-22-2015, 04:55 AM   #40
Cobalt964ruf
Cobalt964ruf's Avatar
Re: Which oil pan?
I use the ls2-ls3 factory road race pan in my lsv8 911. it is the shortest of all ls oem pans and is a gm oem pan with baffles for hard cornering. gmpp 12624617 it is only 4.25" tall.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 10-22-2015, 05:09 AM   #41
Cobalt964ruf
Re: Which oil pan?
pan measurements
Old 03-01-2016, 07:58 PM   #42
88k5jimmy
Re: Which oil pan?
Where did you find the instructions for the 302-1 windage tray mod?
88k5jimmy is offline   Reply With Quote
Old 03-01-2016, 08:10 PM   #43
boostedc10
boostedc10's Avatar
Re: Which oil pan?
https://www.google.com/url?sa=t&sour...UrutTw32wrD9Jw
Brandon
Instagram: DRVFSTR
Old 03-01-2016, 11:13 PM   #44
derotoreut
derotoreut's Avatar
Re: Which oil pan?
Info found on Holley's website or at link in post above.
~ Dan
Old 03-02-2016, 09:51 AM   #45
88k5jimmy
Re: Which oil pan?
Thanks!!
Old 08-24-2019, 01:53 AM   #46
SierraMtns
SierraMtns's Avatar
Re: Which oil pan?
Did the CTS-V oil pan change to #12631828 ?
SierraMtns is offline   Reply With Quote
Old 05-31-2022, 06:00 PM   #47
D-n-Tyke
Re: Which oil pan?
Bring up an old thread trying to find an answer. When running he Holley 302-2 pan can you run the stock dipstick and dipstick tube, or do you have to use a different dipstick set (and if so which one?)?
D-n-Tyke is offline   Reply With Quote
Old 05-31-2022, 09:11 PM   #48
Jason Banks
Jason Banks's Avatar
Re: Which oil pan?
The Holley® LS Swap oil pans are designed to work with an LS3 dipstick and tube (if desired). Below are the part numbers:   LS Dipstick – GM P/N 12634547 LS tube – GM P/N 12625031
I copied the above from the Pan instructions. When I did mine, I cross referenced them to Dorman part numbers and bought those instead of the GM.
Jason Banks is offline   Reply With Quote
