07-05-2017, 11:20 PM | #26 |
Re: 72 GMC Grande part out
gas pedal with cable to 34208?
07-05-2017, 11:43 PM | #27 |
Bullseye reverse lenses shipped to 93013?
Thank you
72 Cheyenne super swb 4x4 68 CST swb anniversary gold 67 custom swb 4x4 |
07-06-2017, 01:03 AM | #28 |
Would like a price on the AC Vacuum ball shipped to 75035
Thanks!
Dale - ApacheIvan 1972 Chevy Custom/20 Custom Camper Highlander http://67-72chevytrucks.com/vboard/s...d.php?t=740479 Original Owner ** Do you have a 1972 Plaid Pickup?** |
07-06-2017, 05:35 AM | #29 |
Its Topless Season!!!!
Interested in the tailgate band, tailgate edge protector and the cargo light housing and the dash bezel if ATOG passes , thanks
07-06-2017, 07:15 AM | #30 |
is the antenna g.m. the heavy straight mast , any good , and also , how much for the cowel if patania paint is fairly good , I just acquired a super in same color that has had camper struts on it , shipped to ut 84648
I aint nobody DORK 1972 Cheyenne super k10 swb 350 4speed posi hooks 1934 ford 3 window blown 355 1969 Camaro hugger orange hounds tooth |
07-06-2017, 07:20 AM | #31 |
interested in steering wheel , if you can get pics at your conv. of the cracks , just a overall pic thanks
07-06-2017, 07:43 AM | #32 |
Interested in all A/C parts minus engine brackets and compressor pending condition once removed. Thanks
07-06-2017, 07:49 AM | #33 |
Are there seatbelts..if so what color and how much?
07-06-2017, 08:18 AM | #34 |
Condition of the door panels and price shipped to 98409, with or without the woodgrain since it appears someone inquired about those pieces. Price on headliner?
07-06-2017, 08:46 AM | #35 |
Interested in price and condition on headliner and stainless trim, rear step bumper, gas cap, and shipping on tilt column shipped to 44805.
07-06-2017, 11:50 AM | #36 |
cigarette lighter and wiring harness shipped to 77830, thanks
07-06-2017, 02:02 PM | #37 |
One of the First
ill take the top radiator brackets with associated bolts, screws and clips and botom clips (with screws) for fan shroud
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
07-06-2017, 02:30 PM | #38 |
Any chance the passenger side fender is clean? And if so any chance ship to 97206? Desperately need one for my 72 Cheyenne same color. Thanks
07-06-2017, 04:50 PM | #39 |
Ok, Did my homework as follows;
Oarnge71, waiting on response to clarify your request 1Rippen6, the woodgrain is weak, see pics below Hotfun, I cant get at the carpet behind the seat to check your stuff yet, will pull the seats this weekend and get back to ya Pickmup, It looks to be the original clutch, but I don't know how to tell. I can send pics when I get it pulled Towbar, I'm using the pulley, heatshield is bad DeadheadNM side markers are decent, bullseye lenses ane nice. 50.00 shipped Gawdly The headliner and trim look good, pending removal without issue. 55.00 plus shipping, guessing in the 20.00 range MO, you are 2nd up on the lenses Shiny side up, cable and pedal assy. 50.00 shipped A1, tail light lenses look nice, no chips noticed, but will inspect closer when I pull them. Apache Ivan, I have a pending on the entire A/C, but I believe I have another vac ball on another cab, 29.00 shipped pending conformation that I have it Clos69, GMC tailgate applique looks good, wood grain tape will need to be either removed and painted or tape replaced. 35.00, top protector 25.00 , cargo light 15.00 Plus the ride. ATOG snatched up the bezel Undertaker, the cowl looks good, antenna is telescopic, but I have a solid mast with good cable on another truck. see pics below. 95.00 for both plus the ride Eagle500, you are first on the a/c, pending condition on removal Briank, the seatbelts are from a different vehicle, see pics below. I do have other belts, what color do you need Randy500, the door panels look surprisingly nice, with the exception of a chip missing in one corner, see pics below. also, you are 2nd in line on the headliner Chevyfan forever, you are 3rd on the headliner, rear bumper 50.00 plus shipping, gas cap 10.00 steering column will ship for 26.00. I can put the gas cap in there as well Tbohne, cigar lighter and harness29.00 shipped Dpassmore upper rad brackets 20.00 shipped, you are second on shroud clips and screws I am going to put the truck on the stripper pole and make it dance this weekend. I should have everything pulled that has been requested and will have more info then. thanks everyone for your interest, Please don't send any payments until I confirm that your requested part is removed and satisfactory. |
07-06-2017, 04:55 PM | #40 |
Antenna, cowl and steering wheel
07-06-2017, 05:05 PM | #41 |
I would be interested in the trim around the front windshield too if it is in good order. Sent you a PM
07-06-2017, 05:59 PM | #42 |
Second in line for antenna. Just headliner trim ring. Tailgate band. If any of it gets to me. Thanks. Let me know.
07-06-2017, 06:00 PM | #43 |
One of the First
On the upper rad supports, that includes the bolts, shroud clips and screws? Ill pass on the bottom shroud clips and screws then.
07-06-2017, 06:05 PM | #44 |
My interior is gold but looks like dirty parchment...so parchment would work.
07-06-2017, 08:37 PM | #45 |
"Gawdly The headliner and trim look good, pending removal without issue. 55.00 plus shipping, guessing in the 20.00 range"
I'll take them pending removal without issue. |
07-06-2017, 08:50 PM | #46 |
Carpe manana
Thanks. I'm interested in pics of the the side marker lamps when poss and the screws I mentioned. I'll pass on the bulls eyes to the next in line - after the 71-$2 style. Thanks! Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
07-06-2017, 09:24 PM | #47 |
Pics and price on door panels, chalky or deep scratches?
07-06-2017, 09:29 PM | #48 |
I didn't see the pictures but will pass if they are weak. Thanks
07-06-2017, 10:29 PM | #49 |
It looks like the Cowel has been repainted is that correct and also it looks like it has an extra hole that's been drilled that's what I'm trying to get away from is that on both sides you know what they drilled it for how much for just the antenna the good one you say you have
07-07-2017, 05:23 AM | #50 |
Thanks for the reply.... I would like to get better pics of the tailgate band, protector and cargo light housing... if everything looks good Ill take them shipping to TX 76180 , thanks
