Old 07-25-2020, 03:35 PM   #26
skymangs
skymangs's Avatar
Re: 70 c10 project
Now we start working on the TPI (It’s nasty)
skymangs is offline   Reply With Quote
Old 07-25-2020, 03:49 PM   #27
skymangs
skymangs's Avatar
Re: 70 c10 project
The runners will have a set of straightening and enlarging balls run through them enlarging them to stage 3, or about 1/4”. I have a 90-92 speed density ECM, and I bought a custom speed density Harness from Larrys Electric. I also have a weld in O2 bung and a knock sensor.
Old 07-25-2020, 04:01 PM   #28
skymangs
skymangs's Avatar
Re: 70 c10 project
Attached are some pictures of when I did it on Cecil.
Old 07-30-2020, 07:33 PM   #29
skymangs
skymangs's Avatar
Re: 70 c10 project
Here’s my new polished aluminum exhaust manifolds and stud kit being installed!
Old 07-30-2020, 08:42 PM   #30
siggyfreud
siggyfreud's Avatar
Re: 70 c10 project
Looking good! Are you switching over to an electric fuel pump as well for the TPI setup?
siggyfreud is offline   Reply With Quote
Old 07-31-2020, 10:26 AM   #31
skymangs
skymangs's Avatar
Re: 70 c10 project
Have to, TPI requires 45~50 PSI
Old 07-31-2020, 10:36 AM   #32
siggyfreud
siggyfreud's Avatar
Re: 70 c10 project
Yep, just didn't see you mention it and saw that it was just a few months ago that you all put the Edelbrock pump in, so was curious .
Old 07-31-2020, 10:36 AM   #33
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: 70 c10 project
Interesting. I've never seen one of these taken apart. Thanks for sharing.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 07-31-2020, 02:22 PM   #34
skymangs
skymangs's Avatar
Re: 70 c10 project
Sure any specific pictures you want just let me know
Old 08-05-2020, 06:28 PM   #35
skymangs
skymangs's Avatar
Re: 70 c10 project
Lower intake cleared up, painted, and installed
Old 08-05-2020, 06:36 PM   #36
siggyfreud
siggyfreud's Avatar
Re: 70 c10 project
Do you have a plate for the EGR blockoff, or going to block it another way?
Old 08-05-2020, 06:42 PM   #37
skymangs
skymangs's Avatar
Re: 70 c10 project
Are you referring to the port in the middle of the manifold? I was gonna have Michael make a block off plate.
Old 08-05-2020, 06:46 PM   #38
siggyfreud
siggyfreud's Avatar
Re: 70 c10 project
Yup. I bought a manifold once where the previous owner just caked it with silicone, so was going to recommend a plate of some kind instead .
Old 08-05-2020, 07:23 PM   #39
skymangs
skymangs's Avatar
Re: 70 c10 project
He’ll make a plate of 1/8” steel
Old 07-10-2021, 07:31 PM   #40
skymangs
skymangs's Avatar
Re: 70 c10 project
We’re finally working on Tweety again, covering it to Tuned Port. This is the lower intake all torqued down.
Old 07-12-2021, 09:01 PM   #41
skymangs
skymangs's Avatar
Re: 70 c10 project
Wyatt cleaning up the fuel rail
replacing injectors with 26 lb/hr Bosche and regulator with an adjustable one.
Old 07-13-2021, 08:30 PM   #42
skymangs
skymangs's Avatar
Re: 70 c10 project
The timing tab mounted
The fuel rail all cleaned and painted
Old 07-14-2021, 08:09 PM   #43
skymangs
skymangs's Avatar
Re: 70 c10 project
Today we took the bed off
And started looking at what it would take to mount the under bed fuel tank
Old 07-15-2021, 08:47 PM   #44
skymangs
skymangs's Avatar
Re: 70 c10 project
The new gas tank where it’s supposed to sit. We have a few rivet to remove before we’re ready to bolt it in
Old 07-16-2021, 09:31 PM   #45
skymangs
skymangs's Avatar
Re: 70 c10 project
so today we put together the fuel rail. That’s an adjustable fuel pressure regulator, AN adapters on the fuel lines, and 26 lb/hr Bosch injectors!
We also got the under bed tank bolted in.
Old 07-17-2021, 06:06 PM   #46
skymangs
skymangs's Avatar
Re: 70 c10 project
we began cleaning up the frame today in preparation for paint.
Old 07-19-2021, 07:58 PM   #47
skymangs
skymangs's Avatar
Re: 70 c10 project
Got the frame all cleaned and ready for paint!
Got all the old exhaust out too!
Old 07-20-2021, 10:51 PM   #48
skymangs
skymangs's Avatar
Re: 70 c10 project
Got the frame all cleaned and painted, tomorrow the rear end and trailing arms!
Old 07-21-2021, 09:02 PM   #49
skymangs
skymangs's Avatar
Re: 70 c10 project
The entire back half is in paint! Now for the gas tank.
Old 07-22-2021, 08:39 PM   #50
skymangs
skymangs's Avatar
Re: 70 c10 project
Got the gas tank in
fuel rail bolted down/balancer on.
