06-13-2018, 10:51 AM | #1 |
70 c10 project
This is a 58k pickup with some serious rocker rust. it does have a 4 bolt main high compression 70 small journal 350 though. so I had the motor pulled and a high performance rebuild done on it. it currently has the biggest cam avalible that is still semi-streetable and a noisy gear drive. I had the rockers/floor braces/partial floors/cab corners repaired. I have a 650 road demon, 700-R4, and blacked out grill surround/grill/headlights, front disk conversion, brake booster, lowering springs, and cool billet aluminum dash and glove box on it. it's been striped by Ripley's Old Skool of Olatha, KS. I have an under bed gas tank and a behind the tail light fill just waiting to go on.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by skymangs; 04-04-2020 at 12:52 PM. |
06-13-2018, 10:56 AM | #2 |
Re: 70 c10 project
some of the rust repair.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
06-13-2018, 11:05 AM | #3 |
Re: 70 c10 project
06-13-2018, 11:16 AM | #4 |
Re: 70 c10 project
more rust repair.
06-13-2018, 11:22 AM | #5 |
Re: 70 c10 project
and more...
06-13-2018, 11:26 AM | #6 |
Re: 70 c10 project
last one I promise.
06-13-2018, 12:41 PM | #7 |
Proprietor of Dale's Corner
Re: 70 c10 project
Looks great
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-13-2018, 03:56 PM | #8 |
Re: 70 c10 project
thanks, it's been a hellova ride! since I can't work on em' any more, Mike my customizer/mechanic does all the wrenching.
06-13-2018, 05:34 PM | #9 |
Re: 70 c10 project
Loooove that color, and excellent metal work.
1970 C-10 "Old Yeller" |
06-22-2018, 12:31 PM | #10 |
Re: 70 c10 project
Nice work. It's amazing how all of these trucks rust in exactly the same areas!
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
06-22-2018, 05:59 PM | #11 |
Re: 70 c10 project
yup, now I'm eyeballing a set of Riddler 18's.
01-26-2020, 08:02 AM | #12 |
Re: 70 c10 project
So I had some things done to the old girl: I had a billet aluminum dash and giove box door done. I had a beefed up 700R4 in with a deep pan, 4.5/5” drop, 5 lug conversion, disk brakes in the front, converted to power brakes, and the 18” Riddlers.
01-26-2020, 03:20 PM | #13 |
Re: 70 c10 project
Here’s what it looked like lowered
01-26-2020, 03:34 PM | #14 |
Re: 70 c10 project
Then I had a 71-72 grill shell powder coated. Bought a black billet 72 grill, and moved this turn signals behind the grill. Put LED turn signals on the core support.
01-26-2020, 03:37 PM | #15 |
Re: 70 c10 project
moe
01-26-2020, 03:47 PM | #16 |
Re: 70 c10 project
then I put in black halo LED headlights
01-26-2020, 03:56 PM | #17 |
Re: 70 c10 project
Yesterday we replaced the stock fuel pump with an Edelbrock HP, we put a Holley regulator on it, and a see through fuel filter.
01-26-2020, 04:14 PM | #18 |
Re: 70 c10 project
So about 2 months ago we replaced the Edeljunk with a Speed Demon 650 (huge difference) we also replaced the OEM alternator with an internally regulated 105 amp Chrome one. The last few are cleaned up and show ready. We have a cruise this weekend. Sometime this summer plans include serpentine drive, aluminum heads, and Tuned Port Injection!
03-31-2020, 10:36 PM | #19 |
Re: 70 c10 project
First things first we put an 01 Silverado seat in it.
03-31-2020, 10:53 PM | #20 |
Re: 70 c10 project
Then we pulled the heads and intake to replace them.
03-31-2020, 11:04 PM | #21 |
Re: 70 c10 project
The plan is 200cc aluminum heads, 68cc combustion chambers, 2.02 valves. A modified TPI manifold. Polished aluminum exhaust manifolds. Should be pretty spiffy when we’re done!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by skymangs; 04-01-2020 at 02:27 PM. |
04-04-2020, 10:47 AM | #22 |
Re: 70 c10 project
it had 333882 heads. that’s a 1.94 intake, and a 76cc combustion chamber. The heads I’m putting on it have a 2.02 intake, 200cc intake runner, and a 68cc combustion chamber. Quite the upgrade!
04-04-2020, 10:57 AM | #23 |
Re: 70 c10 project
it has a 1226870 ECM, which is from an 85 Camaro
04-04-2020, 11:06 AM | #24 |
Re: 70 c10 project
Modifications will include a 58mm BBK throttle body, airfoil, Bosche 24lb/hr injectors. The upper plenum, lower intake and runners are getting gasket matched and pocket ported. Then the runners are being resized to stage III. Then to finish it off a BBK adjustable fuel pressure regulator to up it to 50psi
07-25-2020, 03:31 PM | #25 |
Re: 70 c10 project
So I started off with the bare heads, then put chromo pushrods in it, and topped it off with aluminum roller rockers.
