04-24-2019, 05:29 PM | #26 |
Re: Stuck on oil filter, seriously tried everything!
try this 12 Inch Oil Filter Pliers Slip Joint Design Up to 4-1/2" Diameter Tekton 5866 works ever time
04-25-2019, 11:09 AM | #27 |
If you could get a small chain wrench in there around the rim it would probably work
04-26-2019, 08:09 PM | #28 |
Yes, getting the wrench high up is the key. I don't have a lot of room to spare with my BB, but the handle does pivot so that does help get it in position.
Having said that, it the filter has been crunched too much already, it might just crunch further and not budge. Still worth a try though. |
04-26-2019, 09:43 PM | #29 |
I have one of these strap wrenches, it's never failed me yet on stubborn oil filter. get it up near the base, and crank it down. it will crush the side of the filter but it comes off!
https://www.grainger.com/product/2ZP...!g!82496526117!
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-18-2019, 05:17 PM | #30 |
Had to use the recip saw and none of my vise grips will stay on to turn...at this point I've even prayed about it a few times. What if any options do I have now, I am trying to avoid damaging the surface.
Any and all advice is really greatly appreciated!
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
05-18-2019, 05:24 PM | #31 |
A socket with some teeth on the side going into the holes? Just need a welder and some rod
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
05-18-2019, 05:31 PM | #32 |
I had one like that.
Got to the same place as you. Ground down the noses on a pair of channel locks to fit in the holes. Twisted right out. Mine was on a brand new 80 T/A. First filter change. Channel locks like this. https://www.homedepot.com/p/Channell...-440/100002119 Last edited by geezer#99; 05-18-2019 at 05:53 PM. |
05-18-2019, 08:23 PM | #33 |
Maybe an adjustable spanner/pin wrench? The nubs are small, but if you could get it to catch it would probably work
1978 Scottsdale - celebrating 10 years of teaching me profanity 1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold 1987 k5 blazer - sold... :\ seed money for the 81 1981 k20 4x4 - 5.3 swap in progress Events attended: Spring GOG 2011 Dale JR car show Summer 2012 Gathering at Tommys pickup parts |
05-18-2019, 08:33 PM | #34 |
Post Whore
WOW!!!.you did a number on that...maybe if you made a tool like this that would fit into the outer holes of the filter base...with a long enough pipe to get on it with channellocks or pipe wrench might work
05-18-2019, 08:59 PM | #35 | |
Nice graphics there Greg! I envisioned the same tool but don't have the computer skills to whip up something like that on my $40 phone. I'd like to add a modification to your idea by making the main shaft out of hex stock (like a big Allen wrench). Could stick a socket on the end & hit it w/ an impact. Should come right off. It's AMAZING what an oil change can turn into!!
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's Last edited by Feel the 'Pane; 05-18-2019 at 09:05 PM. Reason: Spell check |
05-18-2019, 11:36 PM | #36 |
Looks like it's going come out, amazed of how stuck that is. My I suggest is that you add a few more pins to Mongocanfly's tool - round plate instead of bar, use another oil filter for a template for the pins. My concern is that if only 2 pins are used they may just tear up more of the filter base and leave you very little work with. 🤔
05-19-2019, 01:15 AM | #37 |
ok, here's the plan.. next full moon, we all close our eyes and focus on your filter loosening while you turn....
anyways, yah I'm with the last couple of suggestions, devise an apparatus to get some traction on the filter base.. that crimped on sheet metal looks to be about a lost cause at this point.. and not to be a capt. hindsight, but when they feel like that's about to happen, get yourself a real band clamp and choke up on it near the filter base so it doesn't deflect and bites so it can be spun out.. if you can fold the sheep metal inward out of the way, may still be able to get one up there directly around the base.. good luck! fyi, I have these all the way up over 6" and only busted one on a big cat filter in 20 years..
I started out with nothing - and I still have most of it |
05-20-2019, 01:23 PM | #38 |
I don't know about the skills you have or tools you have access to, but expanding on what mongocanfly pictured, you can buy one of those angle grinder nut tools and bend it to work instead of building something.
Don't know how well it'd work but it's an option |
05-21-2019, 07:37 AM | #39 |
C10 , I dont know if you have it off yet , but if it were me I would get a hole saw just large enough to fit over the threaded area and cut the outer off . At this point you can reach the 2 bolts holding the filter adapter on and remove it all together . This will keep you clear of the sealing area . I would not worry about damaging the adapter . I would want to replace it anyway . I think there is something going on with the threads between the two anyway .
05-21-2019, 07:42 AM | #40 |
At this point I would be using a long cold chisel and hammer it counter clockwise. That was always the last resort on the farm.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-21-2019, 04:52 PM | #41 |
do you have any large needle nose pliers or angled needled nose? Just stick them in the holes and twist, should come off. You could also use a small punch and tap it gently with a hammer. Good luck
79 Chevy 2wd BIG10 350 TH400 |
05-21-2019, 07:50 PM | #42 |
would a 4x4 spindle-nut socket come close to fitting in the holes? One of those and an impact might give it an attitude adjustment. Just a thought....
05-21-2019, 08:09 PM | #43 |
Post Whore
DANG!!...we ain't got this thing off yet?
05-21-2019, 08:51 PM | #44 |
if this job's flat rate, we've lost our butts
