04-19-2019, 10:01 AM | #1 |
Stuck on oil filter, seriously tried everything!
The thing feels like someone used a torque and an impact! I bought the lisle 60200 strap did nothing but crumble it, so I drilled a hole and tried to turn with a long flathead through it tore it to pieces. I don't know what to do now.
Info: '84 c10 350 cid/th350 Any advice is greatly appreciated, thanks in advance!
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
04-19-2019, 01:32 PM | #2 |
Re: Stuck on oil filter, seriously tried everything!
This type did the trick for me to get overtightened filters off. Has a 3/8" hole for socket extension/wrench;
https://www.princessauto.com/en/deta...n-/A-p8031426e |
04-19-2019, 01:57 PM | #3 |
Post Whore
I've had to use big screwdrivers or small pry bars to getem loose before....prying against the block and on the rolled ring of the filter
I've also tore em all to pieces trying to get me loose...always be sure to oil the filter seal before installing...
04-19-2019, 01:59 PM | #4 |
rip it off down to the o-ring top section and use a hammer and round punch in the oil flow holes .
sounds like someone did NOT lube the o-ring and its about glued to the block .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-19-2019, 02:00 PM | #5 | |
i have the small and big versions and used them for years now in the shop .
04-19-2019, 02:59 PM | #6 |
Post Whore
I've not seen one like axle posted...may have to get me one...
04-19-2019, 10:38 PM | #7 |
weld a nut on it works or like said cut it off and knock the rest off with a chisel
04-20-2019, 03:49 PM | #8 |
I ran into this problem once before. The fix was to do as indicated above - get off as much of the can as you can, then use vice grips locked in one of the drain holes, then tap, tap, tap the end of the vice grips with a hammer until the filter breaks loose. This method is not without risk, because the tools can slip and you could end up gouging the filter mount surface, causing a permanent future oil leak.
My guess is that you may find more than one rubber ring left on the filter mount surface which caused the sticking issue. I have been told that an overheated engine can cause the rubber ring to fuse to the filter and the filter mount housing. |
04-20-2019, 04:45 PM | #9 |
I had the same experience and bought this. It's pricey but, it works!
https://www.amazon.com/OTC-4440-Filt...38559830&psc=1 |
04-20-2019, 05:07 PM | #10 | |
I had a stuck filter years ago and bought this sane style tool from Snap-On. Pricey yes, but haven't had a problem removing a filter since. Time is money so it's a 'no brainer'.
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's |
04-21-2019, 01:56 PM | #11 | |
Alex. |
04-21-2019, 08:31 PM | #13 |
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
04-21-2019, 09:38 PM | #14 |
This, my beater drive to work nissan has this occasional problem
04-22-2019, 06:54 PM | #15 |
Really starting to irritate me now!
04-22-2019, 07:04 PM | #16 |
Post Whore
Dang...what a mess...I've also got a set of 480 channellocks that sometimes work...
04-23-2019, 07:59 AM | #17 |
You either need to drive that screwdriver higher up in the filter or...... you still have enough filter left to use one of these.
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
04-23-2019, 08:13 AM | #18 |
I drive a big flathead with the head ground down to look like a punch about 30% through the filter (meaning not directly through the middle left to right but off to the side as to not hit the threads the filter spins on to) but very high up on the filter. Then use both sides of the screwdriver to twist it out. Driving a screwdriver through at the bottom is all thin metal so you can't really get torque on it down there without it ripping through. May hose down the top with PB blaster as well. I have the pliers, wrench, and strap dealio (the worst) and none of them worked for the filter I had issues with.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
04-23-2019, 08:19 AM | #19 |
Related to my post, I would try the pliers first as you can kind of crush the filter and get some decent torque on it (I think it is the 2nd best method after the screwdriver thing) as if you drive a screwdriver up high and rip that out...it is going to make it that much more difficult to have anything to get ahold of. You do get 2 tries at it though with the screwdriver as you can drive it through on each side (left of middle and right of middle).
04-23-2019, 09:04 AM | #20 |
I have used oil filter strap wrench with some heavy grit sandpaper on one side to give you more grip. You are lucky there is plenty of filter left. If you do resort to screwdriver, I like to use a longer screwdriver so I can grab on both sides and use equal force. Now a days I only use fram filters or the K&N filter on my newer vehicle. Good luck
79 Chevy 2wd BIG10 350 TH400 |
04-23-2019, 04:39 PM | #21 |
Since you still have a lot of the filter left in place, I would second that idea of coarse sandpaper on an adjustable spring steel type filter wrench. This is the kind I usually use:
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds |
04-23-2019, 10:25 PM | #22 |
04-24-2019, 11:18 AM | #23 | |
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
04-24-2019, 11:53 AM | #24 |
I welded a chain to a socket that grabs the filter. Silar to this: https://upload.wikimedia.org/wikiped...ter-wrench.jpg
Grab it down as low as you can
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
04-24-2019, 04:42 PM | #25 |
What I have done was to take a small cold chisel and carefully bend up the rim where Mongocanfly illustrated in his post. In my experienced once the seal was broken more traditional methods would work.
