04-16-2009, 12:23 AM | #51 |
Its a Truck Thing......
Re: I bombed emissions
No tests in sierra vista.....yet
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
04-17-2009, 12:27 AM | #52 |
A lesson on emissions:
As some of you probably know, HC and CO are both emissions that are tested for. But what are they, and how are they created? First of all, HC is simply unburned fuel. Misfiring can cause this. Low compression? Ignition problems? Lean mixture? CO is partially burned fuel. See the distinction? Ignition problems won't increase CO, since a misfire doesn't create combustion, thus no "partially" burned fuel. If you richen the mixture, both CO and HC will go up. If you lean the mixture, both will go down, until the engine starts to misfire, then HC will jump up. I actually like emissions testing, to an extent. I like knowing my engine is in tune, and running its best. |
04-17-2009, 07:01 AM | #53 |
Summer of '06, my '71 Jimmy w/ 350 flunked the smog test 6 or 7 times at the Prince Road location. It turned out to be a vacuum leak related to the A/C controls. I tried it all -- adding a pint of 91 proof rubbing alcohol, new PCV valve etc. Even tried to have them test it in Maricopa. They wouldn't let me test there. They are way more invasive in PHX.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-17-2009 at 07:01 AM. |
04-17-2009, 10:24 AM | #54 |
Engine n00b
Smog on a classic? nuh UH!
04-17-2009, 01:29 PM | #55 |
Yeah metro tucson and PHX only though. A 67 through the late 70's is only an idle test, if you fail that, as he said the rollers are a second chance deal, then the retest. If you fail the return trip is free, so no biggy there. A tune on your carb was all you needed, as said above lean it out, but if you lean it too much the the HC go up. I paid to have it done one time, dude with a sniffer set timing and carb to pass I marked the spot for the timing and remembered the settings on the carb every year I just set it up like it was and passed. Believe it or not running clean by the sniffer isn't the best for performance!
04-17-2009, 06:58 PM | #56 |
In WA state unless i miss understood there were talks about smog testing small engine equipment. I know in cali they banned the older flat head engines.
Give a man a fish and he will eat for a day, teach a man to fish and he will spend all day in his boat fishing and drinking beer. |
04-17-2009, 07:10 PM | #57 |
Moderator
04-17-2009, 09:58 PM | #58 |
Flat head small engines. They've been fazed out for some time now.
04-17-2009, 10:08 PM | #59 |
You must be referring to lawn mowers and such? A friend of mine owns a lawnmower shop. As he told me, studies show that running a lawnmower for 20 minutes, is equal to running a well tuned car for 2 hours. That is why in So Cal, we get more smog on weekends than a typical weekday. Since people are mowing their lawns on weekends. As bad as So Cal is, it isn't as choked up as the Central Valley, with their Tulley Fog. There, you can only use your fireplace on approved days. If caught using your fireplace on a non-approved day, you can be fined.
'72 GMC custom camper 350/350 |
04-17-2009, 11:13 PM | #60 | |
04-18-2009, 11:28 AM | #61 | |
spirit rider66
Location: pahrump, nevada, in the bowels of the Mojave desert
never again, sorry to hear they are now picking on the week-end warriors who desperately need the exercises.
:Chevy: If you don't run your own life,, some one else will. to our vets,, welcome home,, and thank you for your service.:Chevy: |
04-18-2009, 11:38 AM | #62 | |
spirit rider66
04-18-2009, 11:38 AM | #63 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-18-2009, 11:40 AM | #64 |
Moderator
Oh....Gotcha
04-18-2009, 11:43 AM | #65 |
spirit rider66
hi leddzepp; you still there huh?,, good for you, got everything , except the wiring in the front of the truck done now, going to get off my ole butt today and do some wiring, (gotta git her done)!! about were do you live in riverside just about is good ok :Chevy:
04-18-2009, 11:55 AM | #66 |
Moderator
Hey Seldomseen, I am off of Tyler and Indiana. I remember you said you used to live off of Spruce. My dad used to live off of Spruce before he retired and moved to Lake Havasu City. He has a couple friends that live in Pahrump also.
Wiring is always a lot of fun, isn't it? I am sure you can git 'er done in no time with a few beers out in that hot desert sun! |
04-18-2009, 12:17 PM | #67 | |
spirit rider66
04-18-2009, 12:37 PM | #68 | |
Moderator
I can walk to the Tyler Mall from my house. What's the Galleria? |
