03-30-2009, 12:29 PM | #1 |
I bombed emissions
So i took my lovely 71 c10 longbed with 327 out of a 69 with weiland intake and 4 bl carb to arizona emissions. so my Hydrocarbons 1st idle = 226,
precondition reading= 237, standard= 380 and my final reading =328 and the standard for passing 450 so i passed that. Now my carbon monoxide 1st idle at 6.52, precondition= 8.19, and my precondition standard at 3.00, final reading is 7.27 and the standard is 5.00 so its a fail. My truck has passed every year before. if any body has some pointers i would appreciate it thanks buys Oh Chevy gods let me pass so I can cruise in style. |
03-30-2009, 12:40 PM | #2 |
It'll Buff Out!
Re: I bombed emissions
Wow. I'm just shocked you have to smog a 71, CA. who I thought was the worst says nothing older then 75 needs to be smogged. I hope someone can help.
Good luck
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
03-30-2009, 12:47 PM | #3 |
I was thinking the same thing. Smog test on a 71, wow guess I won't be moving to AZ anytime soon. In Texas anything older than 25 years doesn't neet smog testing. So any 83 model and older is good to go.
03-30-2009, 12:55 PM | #4 |
Yep Arizona govt thinks they are california. So i have a bran spanking new edelbrock carb 650 thunder series still in the box, Would changing it out help at all (i am just looking for a reason to put this beauty in)
03-30-2009, 01:04 PM | #5 |
It'll Buff Out!
if it were mine, I would start with tune up if its been a while. check your timing. and I always changed my oil the day of smog and get it nice and hot and I run premium gas. How old is the carb on it? if its out of tune that would possibly make a dif. (just speculating)
I'm sure someone will have a better informed idea
03-30-2009, 01:27 PM | #6 |
I know of a way to pass with flying colors and no parts exchanges or tuning is necessary. If you can get methanol (racing fuel) which is pretty easy to get around here but some areas it is hard to find. Get your fuel tank down to about a quarter tank or less of gas. Put in 1-2 gallons of methanol. Go to the emissions place and pass. My dad does this every year on his 86 dodge and every year the emissions people say they have never seen numbers so low. His numbers are half of what brand new cars numbers are when he does this.
Warning: if you put too much methanol in it will run rough or die, if this happens just put a little bit more gas back into the tank until it runs smoothly again. Certain gas stations and parts stores sell methanol; especially if there is a race track nearby. If you cant find it locally there look at places that sell bio-diesel supplies since methanol is the main ingredient in biodiesel after vegetable oil. |
03-30-2009, 01:46 PM | #7 |
I had the same issues in Maricopa in the Phoenix area, I had a new electronic ignition, new plug wires, plugs, air cleaner, timed perfectly to specs (mine's a 250 six) - new carb to spec flow tested and was missing on the idle test - less than 2% off can't remeber the exact numbers but passed on all the other tests. I finally went to auto zone and bought a generic cat and installed it, was about $60 and all tests were off the map. We just have strict benchmarks here. I've done the alcohol and all the tune up idle set tricks - you might get it but with what it all costs not to mention the tests I was ahead buying the cat.
03-30-2009, 01:52 PM | #8 |
blake how did you get it to pass
03-30-2009, 02:11 PM | #9 |
03-30-2009, 02:14 PM | #10 |
oh ok ya i dont have cats on it just cherry bombs
03-30-2009, 02:46 PM | #11 |
Junior Member
The major source of high carbon monoxide emissions is a rich air/fuel mixture. I used to lean out the mixture in my 67 just to pass Tucson testing then richen it back up after the test.
03-30-2009, 02:59 PM | #12 |
Moderator
Put a two-barrel carb on it if you can. That will help.
Everybody thinks Calif. has the toughest emissions laws. That's true if your vehicle is 1976 or newer. If you have a 75 or older, you can do whatever you want to your engine. Dual exhaust, no cat's, headers...all legal. |
03-30-2009, 03:01 PM | #13 |
I was told that Phoenix even has smog checks on motorcycles. You can bet the CA AQMD/CARB, is looking at AZ smog requirement and thinking of ways to implement them in CA.
Just remember, when it comes to smog requirements. CA is first with the state requirements, then the rest of the country gets stuck with the same requirements. The only way CA has backed off the older cars, was by proving that most were owned by car enthusiast, not driven daily, and were kept tuned up better than most cars on the road.
'72 GMC custom camper 350/350 |
03-30-2009, 03:17 PM | #14 |
Moderator
You have to have a smog check, and no catalytic converters are required?
03-30-2009, 03:38 PM | #15 |
Your carb is dumping waaay too much fuel into the engine.
03-30-2009, 03:50 PM | #16 |
so iam going to throw on the new carb tomorrow and lean it out and i am going to take emissions wish me luck
03-30-2009, 03:53 PM | #17 |
Moderator
Make sure you drive around a bit before you take it in. The hotter the engine is, the better chance you have. Good luck!
03-30-2009, 04:06 PM | #18 |
Thanks guys i will keep you updated
03-30-2009, 04:24 PM | #19 |
A friend of mine and perhaps the only guy i trust to work on anything of mine if i cant is good at fixing these issues for the memphis smog inspections. I know he leans them out and changes the oil and ups the timing and puts 93 in them and changes the PCV valve and they usually pass with flying colors. Note use amoco 93. They are the only company that actually has their own tank for their 93 octane gas. all the others get it out of the same tank at the same refineries as the rest of them.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
03-30-2009, 06:21 PM | #20 |
sharp as a marble
I put two mini catalytic converters on a customers 55 Chevy. He was compaining about a fuel smell in his garage. Just for giggles, I cranked up my gas bench ( we do not have emissions test anymore ) and that car was clean enough to pass a late model idle test. I know room under our trucks is tite, but a couple of cats, and the emissions police would leave you alone
03-30-2009, 06:28 PM | #21 |
I'm waiting for your results to see how it went. We don't have emission testing on this side of the Cascades (yet) in Wa. Dad would always make a hot lap down the freeway just before going to the test station with his car when he lived in the Seattle area and had to have his car tested every year.
03-30-2009, 07:21 PM | #22 | |
spirit rider66
Location: pahrump, nevada, in the bowels of the Mojave desert
truck:
:Chevy: If you don't run your own life,, some one else will. to our vets,, welcome home,, and thank you for your service.:Chevy: |
03-30-2009, 07:55 PM | #23 |
Sierra Grande Club
You want to use lower octane gas to lower Carbon Monoxide. The higher the octane rating the more resistant to burning it is. That's why it's resistant to preignition on high compression engines.
You need complete burning of the fuel to pass..... So use low octane for your test. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 03-30-2009 at 07:55 PM. |
03-30-2009, 08:07 PM | #24 |
Resident of Here
If I were you I'd go to a different inspection station, the guy you went to may not have known the rules. Heh, I dont know.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
03-30-2009, 10:03 PM | #25 |
Moderator
I know he is in another state. I have two 72's and have never needed a smog check on them either. I think it is odd that he is required to take an emissions test, and yet it is not required to have cat's on it.
