Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-26-2018, 01:20 AM   #801
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
Payment received. I will build and ship your order on Tuesday.
Originally Posted by rincones View Post
Payment sent earlier today.
Old 05-28-2018, 01:44 AM   #802
Budman56
Budman56's Avatar
Payment sent
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 05-28-2018, 11:28 PM   #803
Captainfab
60-66 Nut
Payment received.
Originally Posted by Budman56 View Post
Payment sent
Old 06-30-2018, 11:38 AM   #804
frankinstein
I would like to purchase a steering adapter plate for a 1967 K10 can you PM me your Paypal info.
frankinstein is offline   Reply With Quote
Old 07-01-2018, 12:27 AM   #805
Captainfab
60-66 Nut
PM sent.
Old 07-13-2018, 11:21 PM   #806
mygmctruck1
Got my bracket today , no templet but you said it wouldn’t work for a 68 K1500 4x4 anyhow.
But you did give me a link for installation dimensions , how ever I can not get the link to work ?
Centering the plate as you mentioned in the directions , can I assume just one hole in the frame ( bottom right ) will be used and the rest have to be drilled ?
I currently have no column to reference from , everything is off the frame cab and all .
mygmctruck1 is offline   Reply With Quote
Old 07-14-2018, 12:37 AM   #807
Captainfab
60-66 Nut
I have never installed power steering on a K series truck, That is why I do not have a template or installation instructions specific to the K series frames. Working 80hrs/7 days a week does not allow me time to do that.
I included the '63-'66 C series installation instructions and a basic reference only. It in no way is accurate as to where to place the steering box plate.
Here is the thread I sent you previously with dimensions you will need to install your power steering.
http://www.67-72chevytrucks.com/vboa...=632508&page=6
Old 09-10-2018, 07:33 PM   #808
btburn
Payment sent.
btburn is offline   Reply With Quote
Old 09-10-2018, 11:38 PM   #809
Captainfab
60-66 Nut
I have not received a payment for only a steering box adapter plate since 09-06-18. Did you send me a MO in the mail or did you send a PayPal payment?
Originally Posted by btburn View Post
Payment sent.
Old 09-11-2018, 12:00 AM   #810
btburn
Re-sent it, not sure why it didn't go through from my computer.
Old 09-11-2018, 12:28 AM   #811
Captainfab
60-66 Nut
Payment received for a '63-'66 steering box adapter plate only, no tube and flange.
Old 09-13-2018, 09:43 PM   #812
CousinTone
John, question for you. I’ve got the adapter plate from you a bit ago. I’m finally getting to the job and I’ve been given a gear with 3 mounting holes, it’s appeal is it’s only 2.7 to 3.0 turns lock to lock. Am I able to use this quicker ratio gear with my plate? Appears all 3 line up with 3 of 4 bolt locations. Let me know, I appreciate it very much!!
CousinTone is offline   Reply With Quote
Old 09-13-2018, 11:11 PM   #813
Captainfab
60-66 Nut
I have never seen a '68-'86 C series or a '87-'91 R series truck power steering box with only 3 mounting holes. Has the 4th one just been drilled out as is needed on everyone else's power steering adapter plates? I guess if the 3 that are there line up and the steering shaft lines as well as the pitman arm, it should work?
Old 10-18-2018, 08:43 AM   #814
captinjack
I sent you a pm.
captinjack is offline   Reply With Quote
Old 10-18-2018, 11:23 PM   #815
Captainfab
60-66 Nut
PM replied to......
Old 10-19-2018, 09:21 PM   #816
54Caddy
GM Addicted
54Caddy's Avatar
Plates works with the 500 series CPP gear box correct?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 10-19-2018, 11:37 PM   #817
Captainfab
60-66 Nut
Please be patient. I only have time to log into the forum once a day. I replied to your PM.
Old 10-28-2018, 02:33 AM   #818
captinjack
I sent you a pm
Old 10-28-2018, 01:32 PM   #819
Munnster1984
I have a 1968 gmc k1500 that a need a steering box plate for could you PM me the info please?
Munnster1984 is offline   Reply With Quote
Old 10-28-2018, 11:59 PM   #820
Captainfab
60-66 Nut
I replied to your PM........
Old 10-29-2018, 02:48 AM   #821
captinjack
pm sent
Old 10-29-2018, 11:27 PM   #822
Captainfab
60-66 Nut
I replied to both of your PM's
Old 11-05-2018, 01:42 AM   #823
61zac
I think my eyes are bleeding after reading about 17 pages of the thread. I got to about year 2012 and decided to skip to the end and see if anything ever came about with the 60-62 adapter in the 6 years since.
Also, any idea about a lower ratio (than stock) steering gear? I found a thread listed in this thread - but also from 2012 and all the links are broken.
Thanks a bunch!
61zac is offline   Reply With Quote
Old 11-06-2018, 12:52 AM   #824
Captainfab
60-66 Nut
I do have a power steering plate kit for the '60-'62 frames. However I still do not have installation instructions or a template specific to the '60-'62 frames. There are 3 threads here with info on installing the kit.
http://www.67-72chevytrucks.com/vboa...d.php?t=749608
http://www.67-72chevytrucks.com/vboa...d.php?t=657913
http://www.67-72chevytrucks.com/vboa...d.php?t=683028
Old 11-06-2018, 01:15 PM   #825
61zac
Sweet! Sign me up. I'll take a '61 kit.
Also, I picked up this combo generator / power steering pump yesterday. If I can get it stuffed into the crowded, driver side of my engine bay, any idea if it'll drive the steering gear?
