Old 05-07-2014, 12:03 AM   #851
Bomp
Bomp's Avatar
Re: My '67 Fleetside C10 renew
Or you could use some exhaust adapters.
http://shop.advanceautoparts.com/web...hedFrom=header
Slip'em on and forget'em
Bomp is offline   Reply With Quote
Old 05-07-2014, 08:55 AM   #852
Low Elco
Don't sweat it. I've seen Stainless echo cans welded to aluminized exhaust a buncha times. I asked the guy if he had to do something special for the stainless, he looked at me like I was nuts. I fabbed a conveyor system out of stainless, I used the proper wire and Trimix gas, no biggie at all. Even had to weld some Std steel brackets to it, no problem, still together 7 years later. Getcha some!
Low Elco is offline   Reply With Quote
Old 05-07-2014, 10:35 AM   #853
Vic1947
Vic1947's Avatar
Originally Posted by jlsanborn View Post
Eeks! Looks like that says "trimix". I have the ER308L wire. I prolly can't justify a new bottle just to weld four tubes..... I'm using the CO2/argon blend now. Maybe worth a try?
Not to introduce more confusion, but I've always used 309L and pure argon when TIG welding dissimilar alloys (carbon steel to stainless). I'm not sure the composition of the gas is as important as the purge. The trick with SS is to purge on the backside to prevent sugaring. Attached photo shows what I use to purge the tube but I've seen homemade setups that work great. With the inside and outside of the weld area bathed in inert gas, the weld bead should have a nice golden appearance and require very little filler. I have zero experience with MIG welding this combination. 309L may not be a wire option and trimix may be better suited to the 308L. But I'm like you, I'd at least give it a try. It should be quickly apparent if it was a bad decision. Just clean up the ugly and regroup.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 05-09-2014, 09:11 PM   #854
jlsanborn
jlsanborn's Avatar
Originally Posted by Bennett68C10 View Post
Looking really good with the cab and bed on.
Appreciate you lookin! I wish they were going on for good. Can't wait to see some trim over there!
Originally Posted by mcbassin View Post
Very nice progress! the bed and floor looks great too. Keep up all the hard work.
Thanks Mike! I can picture your truck all done in my mind. The solid red with the wood grain is not something you see around. It's going to be SICK! Git busy on all them wires!!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 05-09-2014, 09:49 PM   #855
jlsanborn
jlsanborn's Avatar
Thanks again Greg! You are also a master of bookmarks! Can you imagine trying to do what we do today without the http://?
I'm excited to see all your hard work over there come together. With all the one-off ideas you've incorporated already, I can only imagine the stuff you've got yet up your sleeve! Propa-props!
Cool! I figger I'm going to load up that stainless wire that I have (which I constantly snip chunks off of for other fixin stuff ) and give it a go. If it's crappy I'll probably just use some good quality clamps.
Final diagnosis on the tiddler?
Thanks Vic! As I was writing my last post I was trying to think of the snappy, ultra clean way you'd approach it. I always appreciate your input, love following your build and have a ton of respect for guys like you that can make such any messy, difficult task look soooo easy. Smarter, not harder is something you've got figgered out friend!
So I have been busy on Chevy trucks. Just not all on the right truck! Ball joints and window regulator in the Silverado - boring. Woke the Crummy up from it's winter slumber. Had to get the front driveline rebuilt after we blowed it up last year. CV rebuild, new slip joint, lengthen 1-1/2" and new universals = $230 YIKES! Battery is POS but we got it rousted and hit the dirt roads on year-old gas. Q-Jet is right on tune and the GovBomb is working sweet! Still have some maintenance to do there because it's firewood season again and we already know where there's another grandpa doug fir waiting for us
C10? I got the cross member half done. Still need to slant the center to match the engine/trans centerline where the trans mount bolts, then weld in some bosses where the bolts go. I'm also going to fab some brackets to tie it to the upper flange of the frame rail. Big Brown dropped off some love too! I think they're going to be plenty loud!! I'm going to fab some angle blocks to set my pinion angle and another 1" drop and a kool c-notch, then on to exhaust.
Old 05-09-2014, 11:47 PM   #856
Bomp
Bomp's Avatar
Holly Smokes,,,,,,,, Them there mufflers aren't what I was a thinkin. Looks like they chopped one of mine in half and made two.
Oh man is that rumble ever gonna beat on the chest cavity when you fire it up.
Old 05-10-2014, 01:11 AM   #857
808_67C10
808_67C10's Avatar
Holy loudness. I am running dual Flowmaster super 40s and they sound amazing unles I drive next to a wall or Ina tunnel. Then, the result is deafness! I dont even turn on my stereo beacuse I wouldnt be able to hear it if I did... Lol
Which mufflers are those?
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 05-10-2014, 01:25 AM   #858
jlsanborn
jlsanborn's Avatar
Muffs are Flowmaster Super 10 Series.
I researched quite a bit and want that crispy sound. 10:1 roller 327 baby! I'll do a balance pipe and tailpipe clear over the axle, out each side. 2-1/2" all the way. Still waffling on where to put the muffs. In front of the member or behind? Pros and cons each way....
Old 05-10-2014, 12:24 PM   #859
808_67C10
808_67C10's Avatar
Dude, I love that 3+3, always wanted a full 4dr truck!
I have my mufflers after the crossmember and dumps in front of the rear wheels. If I had it to do over again, I would go out the rear. It sounds awesome but when it bounces off other cars and walls on either side, it is sooooo loud. People roll up their windows at stop lights...
Old 05-11-2014, 05:02 PM   #860
jlsanborn
jlsanborn's Avatar
Yes, the Crummy and I go back a ways. When I finally finish this C10 project it'll be it's turn.
Old 05-11-2014, 05:03 PM   #861
jlsanborn
jlsanborn's Avatar
Shout out to all the Wifeys that let us all piss away money and time on our trucks!
Old 05-12-2014, 08:40 AM   #862
Low Elco
X2! That looks like (gasp) real work on the Crummy! BOOOOO! Glad 'Ol Crum is back on it's feet.
And, the winner in the Shortest Muffler Ever category is... John Sanborn!
I have to say, If I lived at your place, nothing would ever get done. I'd just be standing in the driveway with a beer, watching the scenery like an idiot. It's pretty there!
Old 05-12-2014, 09:38 AM   #863
Dean'smeanmachine
Dean'smeanmachine's Avatar
flowmaster 10s!!! that will sound good, and you will never have to worry about falling asleep while driving
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 05-12-2014, 11:16 AM   #864
808_67C10
808_67C10's Avatar
X2 on standing around and drinking beer!
I honestly can't wait to see Crummy get cleaned up... I have been wanting a 3+3 for a while now. I wouldn't mind a 90s model 4dr but prefer the 80s model.
Old 05-12-2014, 12:57 PM   #865
Low Elco
Oh yeah, if you're blockin' down another inch, and you know your angle needs, blocks are stupid easy to make and shave for angle, especially if you have access to a Bridgeport. Which i bet in your gig a case of beer could make happen. directions here-Post 368.
http://67-72chevytrucks.com/vboard/s...501131&page=15
Old 06-01-2014, 05:42 PM   #866
jlsanborn
jlsanborn's Avatar
My gawd do I need a kick in the azz! I got stuff layin out there and time on my hands but I just can't get on it.
Old 06-01-2014, 09:51 PM   #867
Bomp
Bomp's Avatar
Been there. Better to take a break than git out there when not motivated. Quickest way for me to suffer burn out.
You could clean the shop though. That always gets me turned around.
Broom, dust pan, some lemon fresh Pledge......clean time done......... Put a wrench in my hand!
Old 06-02-2014, 11:19 AM   #868
Molberg
Molberg's Avatar
Nice choice on the super 10's brother... Plan on running them myself. From what I've seen with them.. Best to place them as far behind the cab as possible (less droan at cruising speed) and run your pipes out from under the vehicle. Had "dumps" once under the box. Won't do that again. Lol.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 06-02-2014, 12:43 PM   #869
Low Elco
Yup, when I'm jammed up, I start cleanin. Seems to help.
Old 06-04-2014, 10:28 PM   #870
jlsanborn
jlsanborn's Avatar
My greatest mentor was a machinist / instructor in college (Industrial Fluid Power). Dude ran a tight ship, clean shop and just plain didn't do $hit stupid. He called fart when he smelled fart. Shout out to Ed Willey, you made a dent man. If I had my way, you could serve over-easy eggs under my bench vise. Score an inline yet? I'm tellin' you dude, get one.
Thanks for looking over here man! I've got no first-hand experience but I did look at about a jillion video clips. I want thist thing to sound good. My plan is to have the muffs just past the trailing arms cross member, under the bed and run tail pipes over the axle and out the sides, behind those 295's. I'm also going to use a balance pipe just past the trans.
*uckin $hit-storm in here lately. With the Boy, it's like a truck fixin' convinience store. Gotta teach him to get some skin when he's sorting out OPP! We swept up and all tools are in check. Cross member is basically there and I got a few sheckles to buy some bent pipe for exhaust. Crummy need some love tho and I ain't got much firewood out there
I prolly think about Boppa's 5.3 just about as much as you do Chip. That's gonna be a sweet ride for him and it's just soooo cool that you did that for your Pa. I'd be proud if I could do the same. My Pa has a '75 Silverado that he uses like a dozer. I have some good pics too. I'd love to whip that thing into shape for him. He'd park the 2014 Subaru, I'm sure.
Thanks for hanging in dudes. I WILL FINISH THIS TRUCK and it's gonna be bit*hin!
Old 06-05-2014, 08:21 AM   #871
Low Elco
I have no doubt!
Old 09-20-2014, 10:36 PM   #872
jlsanborn
jlsanborn's Avatar
Ain't been sittin on my rear. Mad firewood season (plus some for the shop!), fixin' everyone else's cars, etc... Everything is stashed away in holding pattern but it's coming soon.
Old 09-22-2014, 10:18 AM   #873
Low Elco
Git them decks cleared! Winter's a comin', you got work to do! How's The Boy?
Old 09-22-2014, 10:58 AM   #874
jlsanborn
jlsanborn's Avatar
The Boy should be seeing Big Brown today we hope, for his new rotating assembly. His heads are rebuilt, ready to go and he's got a fresh four-bolt on the stand already. I'll update Punching Bag with some assembly photos here soon.
Old 09-22-2014, 12:36 PM   #875
Low Elco
Wow... he won't be happy till that rearend shatters like ball bearings on a steel floor!
295/50-15, 327, butternut yellow, dog dish, muncie m20
