Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-12-2010, 10:37 PM   #76
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Re: 68 GMC 4x4 Suburban build up
[QUOTE=70BLAZERX2;4082353]I just put the dana 60 dually front and a 14bolt dually rear under a 69 K/20 frame and built this truck.
The front end was a bolt in.
Nice truck man!
68SWB4x4 is offline   Reply With Quote
Old 07-13-2010, 03:02 PM   #77
70BLAZERX2
Thank you..this ton dually 4x4 will hual 5,000 lbs of gravel and i even made it a dump bed..A few trips to tracker supply..and it was done..Now i need to paint it.
Nice burb...
70BLAZERX2 is offline   Reply With Quote
Old 07-16-2010, 04:35 PM   #78
70rs/ss
70rs/ss's Avatar
Glad to see you are still giving it heck!! I bought that K30 and pulled the drivetrain about a week or two ago and will get the axles next. Anyone want a nice rust free 81 K30, come get it or it'll get crushed!! I am concerned about the front lift? I am sceeerd I'll need a ladder to get in it?! Looking good!!
70rs/ss is offline   Reply With Quote
Old 07-16-2010, 06:27 PM   #79
70BLAZERX2
This is the stock 1969 K/20 top main leaf,and stock 1987 K/30 front springs ,less the top one and look how high i am sitting..It looks great..
Attachment 608739[/QUOTE]
Old 01-05-2011, 02:16 PM   #80
jbclassix
Junk Yartist
jbclassix's Avatar
any updates?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-05-2011, 05:56 PM   #81
70BLAZERX2
mine with 5,320 lbs of gravel..The front 87 sway bar ,i used old shackle for rear leafs ..and bolted it to stock 69 crossmember..rides great.
Would like to see updates too.
Old 01-17-2011, 02:33 AM   #82
plummen
i like it,same thing i want to do to my 56
plummen is offline   Reply With Quote
Old 02-13-2011, 12:27 AM   #83
67chevy1series
67chevy1series's Avatar
cool build i like the buckets! you need to weld a bracket to the back so the arm rest/seat back doesnt flip all the way back... dont know if you thought about it or not...
67chevy1series is offline   Reply With Quote
Old 04-15-2011, 02:42 AM   #84
Mt Man Chad
Mt Man Chad's Avatar
Looks like yours is almost a twin to my recently purchased 68 Chevy 4X4 burb.
Nice truck!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 10-23-2011, 02:30 PM   #85
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Nice truck!
Sweet! Got any pics? TTT to keep me accountable.....
Old 08-29-2014, 01:36 PM   #86
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Life has been crazy busy with competing as a strongman, getting married, starting a business etc but I am going this afternoon to pick up my baby and bring her home from my moms ranch! Time to get serious
Old 08-31-2014, 05:05 PM   #87
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Got it loaded up and just about in the driveway... That might not seem like too big of a deal but it was parked on the side of a huge hill no brakes, no winch, giant burb... Got it done though! Feels good to have it home... Now to get the 454/th400/np205 over here and get this thing going...
Old 10-19-2014, 12:43 AM   #88
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
got the 454 tbi/th400/np205 to the house now... Not sure on the direction I want to go with building it. keep the tbi? throw on a carb? get aluminium heads, etc and build it up really nice? choices....
Old 12-10-2014, 02:33 PM   #89
Jsfucttruck
Well if you want a solid runner with good torque that runs on it's side. Keep the TBI. If you want to make some power, heads, cam, intake and a carb.
Jsfucttruck is offline   Reply With Quote
Old 12-10-2014, 02:42 PM   #90
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
I'm leaning towards the TBI,
It will be awhile before I need to decide anyway though. I got the captnfab parts to put the hydroboost setup on and will do so next week when I recover from surgery
Old 02-17-2015, 10:26 PM   #91
twistedchevy
Bump
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
twistedchevy is offline   Reply With Quote
Old 02-20-2015, 05:12 PM   #92
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Been trying to track down a 14bolt full floater that isn't $600
Put a power brake booster on it and been tightening up some loose ends as I am going to get it running/driving as is with the current 327
Also noticed the hard brake line is busted so I am ordering a all new set of stainless lines and extended stainless steel lines from Inline Tube next week and replacing the sending unit in the gas tank.
Something that concerns me is the clutch won't return maybe the pressure plate is stuck from sitting? All the return springs, etc are hooked up
Old 02-20-2015, 05:47 PM   #93
LockDoc
The Older Generation
LockDoc's Avatar
On the clutch do you mean that the pedal is on the floor? The pressure plate doesn't normally stick unless it goes over center. The clutch disk is what sticks from sitting and in that case it just won't release when you push the pedal down. The pedal still works as it should.
LockDoc
Leon
Old 02-21-2015, 07:15 PM   #94
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
LockDoc
I can press the clutch down and it stays there unless i pull it back up
Thanks!
Old 02-21-2015, 09:18 PM   #95
LockDoc
LockDoc's Avatar
Thanks!
Does it actually release though? Can you have someone roll the truck with the trans in gear and the clutch pushed in? Are you sure all of the linkage is connected? It sounds like the linkage might be disconnected somewhere.
LockDoc
Leon
Old 02-22-2015, 04:20 PM   #96
vectorit
What?
vectorit's Avatar
Kalle, I have a 14 bolt FF that is already set up for a '68 burb.
I'd make you a deal on it if you want to make a trip down to SoCal.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-22-2015, 04:23 PM   #97
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
What gear ratio and where in SoCal? I will probably take you up on that! We visit family in San Diego a few times a year
Old 02-22-2015, 04:25 PM   #98
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
LockDoc
yes it releases, It is not in a spot to be rolled right now, especially without the brakes working lol.
It was disconnected and I found where and reconnected it. I will have to look into it more and deal with getting the brakes working first
Old 02-22-2015, 04:25 PM   #99
vectorit
What?
vectorit's Avatar
I don't know the gear ratio, but I could pull the cover off and figure out.
I am in the Temecula area just off Winchester Rd on I-15.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-22-2015, 04:37 PM   #100
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Sent you a PM
Thanks!
