01-05-2010, 12:46 PM | #76 |
Re: Show your motor...
i want one!!!!!!
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
01-06-2010, 01:21 AM | #77 | |
fan of "Butters" Stotch
Anyone like seeing diesel engines in anything check out this site www.4btswaps.com/
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again |
01-06-2010, 02:10 AM | #78 |
I thought I posted mine,BUT can't find it? My mind is my best friend, I just wish it would visit me more often!! The stock 350 came out of a 68 conversion van that I had & it is hooked up to a 700 trans!
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI. |
01-06-2010, 02:13 AM | #79 |
Here is my 500 hp 406. 5.7 gm pm rods, stock crank, Chapman ported Sportsman II heads, stainless rockers, gmpp alum water pump, fully balanced. Is installed in my 70 Longhorn now. Runs hard.
Phil '70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver '72 short super build 4wd '72 Suburban LT4 coming soon!! |
01-06-2010, 03:44 AM | #80 |
01-06-2010, 10:56 AM | #81 |
They are Doug Thorley Headers and Early Classic Enterprises (ECE) motor mounts. It's the same setup I have on both of my trucks. Clearances are great and both products work as advertised.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-06-2010 at 10:57 AM. |
01-07-2010, 04:45 PM | #82 |
425hp409
Here is the engine I have finished for my 68. It is a Gen 5 454 with original 402 heads, intake & exhaust manifolds, and accessory brackets. I installed a Holley Spreadbore that I rebuilt and I test ran it and made all adjustments on my engine stand, and now am ready to install it in the truck.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
01-10-2010, 11:46 PM | #83 |
Never Ending Projects
Finally got my engine done to the point of needing to install back in the frame.
Went from this, To this,
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... Last edited by chevy_mike; 01-10-2010 at 11:47 PM. |
01-16-2010, 11:41 PM | #84 |
Yeah! Keep em coming
72 SIERRA LB 74 C10 SB 85 C10 SB 75 EL CAMINO SS |
01-16-2010, 11:50 PM | #85 |
lol srsly? And if it's cranking out 500 why are you running flowtechs with 1.5" primaries. Need more like 1-7/8
'72 cheyenne super step, '05 long bed gmc Last edited by '72customdeluxe; 01-16-2010 at 11:50 PM. |
01-17-2010, 01:15 AM | #86 |
BBC 460. Edelbrock aluminum heads. Edelbrock MPFI. Comp hydraulic roller cam. 10:1 compression. Camquest says: 515hp @ 5000; 580tq @ 4000. Going in my 72 K5.
01-17-2010, 05:34 AM | #87 |
Work in progress..
350 cid Edelbrock 650cfm Edeldrock 1" carb spacer Edelbrock EPS Manifold Lunati Bracket Master II Cam / Lifters / Pushrods Comp Cams Roller Rockers Comp Cams Double Roller '906' Iron Vortec Heads Not pictured.. MSD Distributor Cap/Rotor MSD Streetfire Wires I've done about everything I can without pulling the motor. I know if I pull it out I'll tear it completely down and I won't have the money to put it together before summer. This motor was just a O'Reilly's rebuilt motor with maybe 20k on it that I was going to replace a head gasket on.. then replace a head gasket and port and polish the old crap '882' heads on.. then I got new heads, which required a new intake.. Hahaha.. I wonder when I'll be done.
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) Last edited by 420am; 01-17-2010 at 05:37 AM. |
01-17-2010, 01:06 PM | #88 |
PROJECT 7DEUCE
Heres the 454 in my 72 sounds good still have not even drove the damn thing...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-17-2010, 09:26 PM | #89 |
C/10 CLUB MEMBER
-Ron- |
01-18-2010, 12:12 AM | #90 |
Here's mine, i love showing it off, but next winter she will be apart agaoin.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
01-18-2010, 12:14 AM | #91 |
Green is mt fav color
01-18-2010, 12:39 AM | #92 |
Sweet thread, I love SBC but how about some 500+ci BBC
01-18-2010, 01:30 PM | #93 |
68 chevy 350 still under construction
Wade |
01-18-2010, 02:28 PM | #94 |
68stepbed, bigsnookmaster,
What engine paint are you two using? those two motors look awsome. Last edited by dznucks; 01-18-2010 at 02:28 PM. |
01-18-2010, 02:42 PM | #95 |
572/620 in my 67 Stepside:
01-18-2010, 04:34 PM | #96 |
Kvn1011
01-18-2010, 06:37 PM | #97 |
dznucks, I used rattle can touchup paint(MOPAR to match truck color) for my block and heads. The VC's, intake and other bits and pieces, I used DupliColor Cast Coat Iron engine enamel from Advanced Auto Parts.
01-18-2010, 10:22 PM | #98 |
Fitz thats one bad azz motor
01-20-2010, 09:18 AM | #99 |
Thanks 68stepbed
01-23-2010, 09:44 PM | #100 |
