Old 09-26-2018, 12:04 PM   #76
leddzepp
Moderator
leddzepp's Avatar
Re: OMG Honda door weatherstripping fits perfect no cutting required !!
If your door won’t shut, remove the seal and use a block of wood and a mallet to bend the pinch weld in slightly. Reinstall seals. Done. Two of my trucks had no issues with the seals, one had to have the pinch weld “adjusted”. This goes for any seal, not just push ons.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 09-26-2018, 12:46 PM   #77
Hvychvy970
Originally Posted by TKCR View Post
Ordered these yesterday. Here goes nothing.
Hvychvy970 is offline   Reply With Quote
Old 09-26-2018, 02:23 PM   #78
Artofdeath
Artofdeath's Avatar
Smile Re: OMG Honda door weatherstripping fits perfect no cutting required !!
Let us know how it works out.
Artofdeath is offline   Reply With Quote
Old 09-26-2018, 07:09 PM   #79
TKCR
TKCR's Avatar
Keep us updated
Old 10-10-2018, 11:45 AM   #80
Hvychvy970
Perfect fit and operation!!!! Stop everything you are doing right now and order these!!!
Old 10-11-2018, 12:43 AM   #81
Red71gmc
Adding this to my list. Who was the guy who figured this out? And how?
Red71gmc is offline   Reply With Quote
Old 10-11-2018, 04:12 PM   #82
4carbcorvair
I ordered stock replacements from Rockauto, $20 for the pair. :shrug:
68 K20 Custom Camper/CST Wrecker.
97 GMC K1500 short bed reg cab.
4carbcorvair is offline   Reply With Quote
Old 10-11-2018, 04:18 PM   #83
Hvychvy970
Let us know how that works out for you.
Old 10-11-2018, 04:19 PM   #84
jfnar
I also got a set back in March. They were too tight when I first put them on but I adjust the doors a little and after a couple months of baking in the summer heat they're pretty good now.
jfnar is offline   Reply With Quote
Old 10-11-2018, 04:31 PM   #85
Hvychvy970
Adjusting the doors will help the doors close but do not help body lines though.
Old 10-11-2018, 04:53 PM   #86
4carbcorvair
Fine. Installed no issues. Is there a reason? Remove old. Glue new on. Not overly difficult. Same style as what I pulled off.
Old 10-11-2018, 05:31 PM   #87
Hvychvy970
That’s great! Could you post a link?
Old 10-11-2018, 05:46 PM   #88
4carbcorvair
https://www.rockauto.com/en/catalog/...therstrip,1430
Old 10-11-2018, 06:23 PM   #89
TKCR
TKCR's Avatar
That's awesome, happy to hear they worked out for you!!
Old 10-12-2018, 07:48 AM   #90
mcbassin
Still Learning
mcbassin's Avatar
Very interesting thread. I put the glue on seals in my truck and have been slamming the doors from the outside for years. I found that if I open the window slightly from the inside the doors shut pretty reasonable.
I think the 69-70 model without the vent in the door frame make them a little more air tight than say the 71-72
mcbassin is offline   Reply With Quote
Old 10-12-2018, 10:36 PM   #91
El Dorado Jim
Originally Posted by leddzepp View Post
Dodge Dakota seals from 86-96 fit like a glove too. I imagine there are many clip on seals that will fit.
that is the ones i used and i was lucky to find a decent pair...but they fit perfect! like they were made for it
El Dorado Jim is offline   Reply With Quote
Old 11-25-2018, 02:06 AM   #92
classicham
interesting thread... I was looking at purchasing a set of door seals from classicparts but now I'm thinking about going with the Honda Civic's. I don't want to be dealing with slamming my doors nor trying to adjust the hinges and what not...
classicham is offline   Reply With Quote
Old 11-25-2018, 01:54 PM   #93
LockDoc
The Older Generation
LockDoc's Avatar
There is no guarantee that you won't have to slam your doors or move the striker plate out no matter which seals you get. Every truck is different so what works for another guy may not work for you, without modifications.....
LockDoc
Leon
Old 11-27-2018, 02:17 AM   #94
classicham
how have these held up? I'm thinking of ordering. Did you have to modify your doors?
1967 C10 SWB Stepside (without the ugly spare tire holder)
1968 c10 SWB Stepside (with the ugly spare tire holder)
Old 11-27-2018, 10:00 AM   #95
Domingo
Tag for later
Domingo is offline   Reply With Quote
Old 11-27-2018, 11:09 AM   #96
Hvychvy970
No mods. Held up fantastic.
Old 02-18-2019, 09:02 PM   #97
rcazwillis
Zane picked up a set from pick and pull for less than $15. 2 minutes to install. They fit perfectly. Door closes as it is supposed to close. No amount of adjusting was going to make the crappy glue on seals work.
Fantastic find by OP. Thanks.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 02-18-2019, 09:58 PM   #98
Sparky dave
Thanks for the civic door strip advice my expensive replacements are junk too.
Sparky dave is offline   Reply With Quote
Old 02-18-2019, 10:28 PM   #99
brian1971
brian1971's Avatar
No problem your welcome, yeah put them on a few more friends trucks since I did this thread.They work so good still can't believe how they fit.
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 07-20-2019, 04:09 PM   #100
Castle09
Any wind noise with these civic weatherstrip??
Castle09 is offline   Reply With Quote
