Old 04-27-2012, 01:58 AM   #1
tll74
"Junkyard Dog"
tll74's Avatar
Parting out 72 K10
Parting out a 72 Suburban K10 350, TH350, NP205, and 3.73 gear This thread is for all the parts that are common to both the Pu's, Suburban's, and Blazer's. All prices are plus shipping.
All the following parts are hot tanked and dipped.
4x4 trans-tcase cross member. 75.00
Engine cross member. 75.00 this one sold, have 2 more
Shock mounts. 12.50 each
Rear spring hangers with supports. 35.00 each
Front disc brake stone sheilds. 85.00 pair sold
71-early 72 spindle. 50.00
Tie rod with tight ends and straight. 45.00 sold
Rear u-bolt plates. pair 25.00
RH axle 71-early 72 needs u-joint. 65.00
LH axle 71-early 72 inner half only. 35.00
T-case support. Mounts to the t-case and RH frame rail. Needs rubbers. 40.00
T-case adapter rubber mounts complete and original. Nice condition. 30.00 sold
Front spring shackles. 20.00
Chrome T-case shift stick with knob, boot, ring. nice condition. 110.00 sold
LH chrome vent window. Chrome nice, vertical divider rubber bad other rubber driver qaulity. 40.00 sold
RH chrome vent window. DQ rubbers, 45.00
More to come.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
