01-23-2013, 12:39 PM | #126 | |
Re: How To: Ruin a Perfectly Good K/5
Also like the Sub build. Nice! |
01-23-2013, 03:44 PM | #127 |
Bummer to hear about the cam - If you stick another flat tappet in it I'd suggest getting a zinc additive from Summit or wherever and adding it to the oil at every change.
Modern oil is short on zinc content which causes these kinds of issues with flat tappet stuff. Edit - another thing to do is avoid idling for extended periods. Low engine speeds reduce the rate of rotation of the lifters. Last edited by Jon01; 01-23-2013 at 03:54 PM. |
01-23-2013, 09:21 PM | #128 |
A guy with a truck
Not certain on the cam, haven't had a chance to dig in and investigate. I do know that it was getting ZERO oil to the rockers on both banks, but holding 60psi. I haven't been able to find anything that would cause this. It was making plenty of racket, too...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-29-2013, 01:12 PM | #129 |
I dont know why you are even worrying about it, just drop in the ls you have and problem solved!
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
01-29-2013, 02:05 PM | #130 |
A guy with a truck
If it were only that easy--I just don't have time to fool with it. I ordered a GM crate for it today along with a new HEI. I'll slap on a rebuilt carb and call it good. Normally, this would be an opportunity for an upgrade, but I have other more pressing priorities.
I got a 'new' to me grill from a local member and stuck it in last night. No more gapped-tooth smile Posted via Mobile Device
01-29-2013, 02:08 PM | #131 |
67-72 parts collector,…
Let me know what kind of break in oil and regular oil you decide to use.
I'm worried about the "zinc issues" with flat tappet cams.
01-29-2013, 02:10 PM | #132 |
A guy with a truck
01-29-2013, 02:36 PM | #133 | |
A guy with a truck
01-29-2013, 05:20 PM | #134 |
Junior Member
Did you get the 260hp,290hp or 330 hp?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
01-29-2013, 06:57 PM | #135 |
A guy with a truck
260. The 290 is the same motor with an old school grind cam for $400 more. If I need a cam, I'll choose my own. Didn't look at the 330. Figured this was better than a questionable local rebuild for $1200...
01-29-2013, 10:02 PM | #136 |
Junior Member
The 260hp is a great deal. the burb has one it and and I am not sure of the mileage but it runs well. I will replace it with the same when it dies.
01-29-2013, 11:06 PM | #137 |
I used Brad Penn break in oil for initial start up and the first 500 miles. Then switched over to the 10w30. No problems and its been about 5000 miles.
Posted via Mobile Device |
01-29-2013, 11:30 PM | #138 |
I used lucal oil break in along with Valvoline VR-1 racing oil because of it's high zinc content. Had no issues with my BBC when I fired it.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-29-2013, 11:42 PM | #139 |
Man sorry to hear about the motor!
-Rus |
01-30-2013, 12:26 AM | #140 | |||
A guy with a truck
Meh, it happens, just REALLY bad timing considering all the other crap that needs to get done in my world right now
01-30-2013, 08:13 AM | #141 |
78K & 79C Jimmys
sweet truck,lucky find, those rims/caps really pop now
now hurry up and wreck a burb....
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-30-2013, 09:20 AM | #142 |
Hey I hear ya on the timing, its never a good time!
-Rus |
01-31-2013, 10:37 PM | #143 |
Still Learning
Another awesome addition to the family Chris. Too bad about the engine. I wondered why you were selling all your LS gear now I see you are going to GB. You have a lot going on bro. Subscribed
01-31-2013, 11:55 PM | #144 |
A guy with a truck
Man, you are not kidding. Such is life...
Parts are starting to trickle in--got my HEI dizzy and wires today, crate motor should be here tomorrow, along with a bunch of gaskets, plugs, etc... Is removing ignition points considered ruining?
02-01-2013, 01:19 AM | #145 |
A guy with a truck
Brand new Jegs HEI unit
Posted via Mobile Device Posted via Mobile Device
02-01-2013, 11:00 AM | #146 |
YES, there are some circles on these forums that are extremely displeased, but.....its your truck
Go for it
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-01-2013, 01:01 PM | #147 |
A guy with a truck
I know there are some guys on the Chevelle and Corvette boards that would cringe. It won't be numbers matching anymore after this weekend. I figure it's just a Blazer and not a super low mileage example. I will try to maintain the original look, for now, but it's a slippery slope
02-01-2013, 01:18 PM | #148 |
Hmmm,...
02-01-2013, 03:12 PM | #149 | |
If you have the room, at least store the block
02-01-2013, 03:14 PM | #150 |
