03-09-2015, 11:06 AM | #151 |
Re: Blake's 67 GMC stepside build
Had forgotten how pissed you were that the panel fit like crap. So you started cutting to make it right...Dad
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-09-2015, 09:47 PM | #152 |
Wow, that panel wasn't even close. Nice job on the save!
03-10-2015, 09:57 AM | #153 |
Thank's guys..
Pic #1. Lower section being tacked in place. ( sorry for fuzzy pics old camera) Pic #2. This was after all the welding was done and test fitting the door. Pic #3. After some metal finish was done. (I used all metal filler on some of this to clean things up a bit) Pic #4. getting door ready for Epoxy primer. Pic #5. Another shot of front.. Till next time ... Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
03-10-2015, 10:18 PM | #154 |
Nice fab work. When I put new panels on and they don't line up I feel like I did something wrong. It's good to see that it's the panels not me. Well I'm sure some of it could be my fault. That is to be expected with aftermarket panels. But either way I feel better knowing that I'm not the only one.
Thanks, Ryan. |
03-11-2015, 09:54 AM | #155 | |
No Sir! You are not the only one...
These companies out there that make these pieces (overseas) dont have the same quality control that the U.S. has, so when the dies get worn out they just keep stamping out parts to make money. Instead of making new dies (very expensive, I get that) but it's this type of thinking that produces the low quality parts. Quote:
03-11-2015, 10:39 AM | #156 |
Pic #1. Epoxy primer on the front side..
Pic #2. And the back.. Pic #3. High build primer front..(using Mar-Hyde) Pic #4. HB on backside.. Pic #5. Passenger door Mark...
03-11-2015, 08:07 PM | #157 |
As bad as the panel was the door came out really nice.
03-11-2015, 08:32 PM | #158 |
Looks great!!
Ryan. |
03-12-2015, 09:19 AM | #159 |
Thank's Doug, It was alot of work getting it to flow properly, but the finished piece came out as needed.
Ryan, Thank's again.. Pic #1. Passenger side door after I put guide coat and sanded. (dark spots low) Pic #2. Drivers side after 1st round of sanding and some poly filler. Pic #3. Passenger side 2nd round of filler and blocking. Pic #4. Drivers side 2nd round filler and blocking..
03-13-2015, 10:03 AM | #160 |
Pic #1. Passenger door in fresh HB
Pic #2. Drivers door in fresh HB. Pic #3. So, I was talking to the customer and he decided he wanted the seam that runs the width of the cab welded. This was after I stripped the primers etc off and used a wire wheel to get down inside the seam.. Pic #4. This was during the welding process. (I used the TIG for this) Pic #5. another shot.. Mark...
03-13-2015, 08:09 PM | #161 |
Dumb question...Is that to have a smooth transition from the back to the top? Or to prevent possible corrosion showing up later?
Looking good Mark. |
03-15-2015, 10:22 AM | #162 |
Actually Doug, that is a great question!!
It is really both, this is known spot for rusting on these trucks. He wanted it smoothed out for a cleaner look but to also prevent from rusting... Mark...
03-16-2015, 09:18 AM | #163 |
Pic #1. This was after all metal work was done and a layer of fiber glass filler was used. And starting to apply body filler.
Pic #2. More bodywork Pic #3. After prime,sand etc. starting to move to the back of the cab. Pic #4. Fresh primer. Mark...
03-16-2015, 09:20 AM | #164 |
Wow progress is looking great!
Red 1968 Chevy C10: 4bbl 350 v8 1984 Chevrolet Corvette Crossfire 350 1987 Chevrolet Camaro 305 4bbl 1993 Chevrolet Cavalier RS Convertible 3.1L V6 1982 Chrysler LeBaron Convertible Marc Cross Edition |
03-16-2015, 08:41 PM | #165 |
That will look nice when all painted.
Ryan. |
03-17-2015, 03:01 AM | #166 |
I kinda like it without the roof seam!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-17-2015, 06:33 AM | #167 |
I agree with Swamprat, it looks way better this way!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
03-17-2015, 09:17 AM | #168 |
It does look good!
03-17-2015, 10:06 AM | #169 |
Red c10, YJ4000, swamprat, Kees and Doug Thank's guys...It is a small custom touch that alot of people may never notice, But that's what Chip Foose is famous for! those subtle changes...
Pic #1. I know it's late on this change but it needed to be done... The seams around windshield HAD to be welded, so here it is.. Pic #2. Passenger side.. Pic #3. Drivers welded. Pic #4. Passenger side welded.
03-18-2015, 09:24 AM | #170 |
First off would like to say sorry for all the boring bodywork!!
Pic #1. backside of cab (I know alot of this will not be seen but couldn't let it go) Pic #2. Also put filler around door opening's to smooth out.. Pic #3. other side. Pic #4. fresh primer..
03-18-2015, 03:58 PM | #171 |
There are no boring pics if it involves Pick up trucks
Bodywork looks great!!
03-18-2015, 09:32 PM | #172 |
I enjoy the pics. It's good to see how you go about making it look good rather than just seeing the end result.
Thanks again, Ryan. |
03-18-2015, 10:19 PM | #173 |
X2. Show us the " boring bodywork" all you want, you do great work.
Scott Last edited by sduckworth13; 03-18-2015 at 10:25 PM. |
03-19-2015, 05:38 AM | #174 |
Body work and priming are two items I haven't learned yet, so I enjoy watching and learning about that process. Please feel free to share all you can. Cab is looking good Mark.
03-19-2015, 09:43 AM | #175 |
Thank you very much Guy's!!!
Bodywork is Not my strong suite, but I make do...My favorite part is the metal work (go figure lol) Pic #1. Back on the firewall....This was after I sanded the first round of High Build. You can see the dark areas (low spots) that need attention Pic #2. After another round of filler etc. (guide coat revealed more low spots) Pic #3. Here is a pic of fresh filler..If you notice it is Very rough looking, this is how I first "cut it" I use an old bandsaw blade or hacksaw blade (for cutting metal) and basically form the area or get it roughed in. Then you can fine tune it as needed. This will speed up the sanding. Pic #4. If you notice here I am using a light blue looking filler. This a poly filler used for finish work and sands really easy and leaves a nice smooth finish. Pic #5. Fresh primer... This firewall was pretty beat up on the upper section and needed alot of work. (prime,sand,fill,sand and repeat.)
