Old 04-06-2016, 12:47 AM   #151
Gregski
Post Whore
Gregski's Avatar
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
unfortunately that side cover belonged to another customer, but Larry disappeared for a few minutes and reappeared with another side cover, it looked grungy but it too had the pin going all the way through, he said "FIFTY BUCKS"
I said "FOURTY"
He said "FOURTY FIVE"
I said "FOURTY PALEAZE"
He said "DEAL"
he was happy, and I was thrilled!!!
the mystery of the stupid design GM pin was solved!!!
Gregski is offline   Reply With Quote
Old 04-06-2016, 12:49 AM   #152
Gregski
Post Whore
Gregski's Avatar
see how on mine (the cleaner cover) there is no pin sticking out on the bottom below the top pin
and now see how on the corrected / fixed / retrofitted cover (the dirtier one) there is a pin with a snip on washer clipping it through the side cover and holding it in place, the way God intended
Old 04-06-2016, 12:54 AM   #153
Gregski
Post Whore
Gregski's Avatar
and of course once you know the part number you can Google it and we find that a good cover (with the pin sticking out) is for sale on eBay right now for $135 bucks plus another $25 for shipping!!! yaykes The Greg done good gettin' his for $40
Old 04-06-2016, 06:39 AM   #154
walkerb
walkerb's Avatar
Well damn.......... win for Greg but not for us with the hole less covers........
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 04-06-2016, 08:48 AM   #155
Gregski
Post Whore
Gregski's Avatar
maybe not, maybe the scissor pin from the Muncie 4 Speed will work, here's one listed on eBay for $10 bucks, here's what it looks like, sorry don't know the diameter or length
and here's what their side cover looks like
Old 04-06-2016, 08:57 AM   #156
Gregski
Post Whore
Gregski's Avatar
better yet, the Mopar A833 Overdrive version of this transmission is way more popular than our GM one and guess what it uses the exact same side cover part number and all, C-13550-2 (well the new and improved side cover that is, with the pin hole, like we want)
here's a pic
Old 04-06-2016, 01:52 PM   #157
hatzie
Moderator
hatzie's Avatar
Is there any reason not to just bore the hole the rest of the way through the older cover on a milling machine or good tight drillpress?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-06-2016, 02:16 PM   #158
walkerb
walkerb's Avatar
Your right, probably the easiest way to go.....
Old 04-06-2016, 10:37 PM   #159
hatzie
Moderator
hatzie's Avatar
Some oil hardening tool steel and a small lathe like my 7x14 little green monster would come in handy here. There's really not much to that pin. The little Chicom lathes are too expensive now for what they are. Mine was just under $300 in 2000 and after some cleanup and upgrades like the 14" bed it's been a good little machine. Little is the operative word... but pins and bushings fall right into its' tiny work envelope. I can stuff it under the bench after a spraying the unpainted parts with Rustlick 631 on a shelf with an oiled canvas cover. The 16x42 South Bend ain't so portable and I don't like making small pieces on it even using a 3" chuck or collets
Old 04-13-2016, 03:19 PM   #160
Flathead Smith
Flathead Smith's Avatar
so decided to cut out the stick out of my shifter bottom end assembly for two reasons
1. the threads for the ball were broken off on it anyways
2. I did not like the hockey welded in install, even if it was factory
I'm pretty sure that weld on the shifter was not factory, and was added later.
I am fixing to install a cast iron version of one of the A833 transmission in my truck and there is no weld on either one of the two shifters I have. I was originally thinking the shifter was slipped in and then squeezed shut by a pressing operation, but now after seeing the information you posted, I'm thinking it is removable.
________________________________
Another thing to consider if you need a driveshaft. This A833 transmission uses the same 27 spline yoke as a Turbo 350/700R4 (it also uses the same tail-shaft bushing, which is easy to replace... My transmission shop installed mine for $3.00, which included the bushing). I haven't checked this out yet, but there is a chance that the transmission, when bolted to the clutch housing, might have the same length as either one of these two transmissions. If it does, we'll know what truck to look for at the nearest Pick&Pull.
Flathead Smith is offline   Reply With Quote
Old 04-13-2016, 03:45 PM   #161
Keith Seymore
Keith Seymore's Avatar
Unless I'm missing your point I think I already addressed this.
K
Originally Posted by Keith Seymore View Post
Correct. The bottom of the shift handle snaps into the shifter base with no tools, for ease of assembly. There is a notch on the stick that corresponds to the retention tang on the clip.
Incidentally, the guy that installed these shifters on the assembly line, as well as the M20 shifters, worked for me when I ran the Fender Set area. He also installed the cab running lights and the SPID label.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-09-2016, 09:45 AM   #162
Ziklag
I have one of these transmissions for sale if anyone is interested. 1986 Chevy half ton.
Ziklag is offline   Reply With Quote
Old 05-09-2016, 02:11 PM   #163
Gregski
Post Whore
Gregski's Avatar
hydraulic or mechanical clutch?
Old 05-09-2016, 04:28 PM   #164
trixter99
I have no time for this
trixter99's Avatar
I saw one of these transmissions in a 4wd diesel back in the eighties.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 05-09-2016, 05:00 PM   #165
AnotherWs6
AnotherWs6's Avatar
Tom I hear you, but I've been looking for one in California for over a year and I have only seen one other listed, and it just so happens it was near the same town of Bakersfield, ha ha and that one sold from under my nose for $650 plus $78.16 for shipping on eBay with a Buy It Now option it did come with a bellhousing, but no shifter and linkage.
Like I said earlier I am trying to justify the purchase by saying mine came with the shifter and linkage, bellhousing, pedal assembly (which I may not need) and crossmember.
Does the one for $700 from Car-Part.com ship for free or do you have to pay extra for shipping? Shipping transmissions across the country aint cheap. Fed Ex freight wanted $250 to ship one from Michigan to California.
A hundred bucks or so one way or another, who cares? If it were something sold on Amazon I could see being miffed at not getting a GREAT price, but these things aren't growing on trees still and most importantly - you have it at your home now.
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 05-09-2016, 05:59 PM   #166
1968vetL-71
Junior Member
1968vetL-71's Avatar
It should be a hydraulic if it's an 86. I also have a set up complete hydraulic out of an 87 for sale. It's the harder to find 4 x 4 version though. It's even cast-iron.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 05-09-2016, 10:05 PM   #167
Ziklag
Hydraulic. It also will come with the Hurst shifter and all things in the picture.
Old 05-09-2016, 10:23 PM   #168
Gregski
Post Whore
Gregski's Avatar
very nice, how about the transmission crossmember, I ask because I have yet to see the one for that specific application
Old 05-22-2016, 01:44 PM   #169
1968vetL-71
Junior Member
Thought this was very interesting when i pulled the pedal assy out of the 87 i got my set up from.
Old 06-29-2016, 08:17 PM   #170
Gregski
Post Whore
Gregski's Avatar
some numbers for you after my swap
70 MPH at 2000 RPM
75 MPH at 2250 RPM
I am loving this new 833 overdrive transmission, now I have 4 useable gears not just 3
Old 06-29-2016, 08:28 PM   #171
Jake Wade
Jake Wade's Avatar
Those cruise RPM's are perfect for my taste.
Jake Wade is offline   Reply With Quote
Old 06-29-2016, 09:18 PM   #172
hatzie
Moderator
hatzie's Avatar
These turn a half ton truck into a pretty civilized cruiser and they'll put up with some towing.
Something a lot of folks overlook is that you can ship bulky things on Greyhound for less than the courier services you just have to package them carefully. I've shipped doors and trunk lids on Greyhound after packaging them.
With a transmission or transfer case you need to make sure the oil is drained thoroughly and the box is reinforced enough that it doesn't poke through so you don't get filth on someone elses stuff.
Old 07-16-2016, 08:01 PM   #173
bluek5
bluek5's Avatar
I saw this at a pick-n-pull today. I was wondering if it would be worth getting to save it from the crusher? The side cover is loose, so I suspect it has issues. It is from a 4x4 truck. The shifter is there also.
bluek5 is offline   Reply With Quote
Old 07-16-2016, 09:00 PM   #174
Gregski
Post Whore
Gregski's Avatar
Depends how much they want, if it was complete I would say get it, if it had the shifter and the linkage and tailshaft
See if it has the hydraulic clutch bell housing if so get the bell and the clutch all of it and I'll buy it off of you ha ha
Its a great trsnsmission I love my 2WD
Old 07-16-2016, 09:16 PM   #175
bluek5
bluek5's Avatar
That's weird I thought I posted a picture of the transmission on the previous post. The trans and shifter could probably be had for $150 or less.
